Home » Modeling » EMF » Too many constants, the constant pool for AlgoIQPackage would exceed 65536 entries(when i am creating variable and enums in ecore,after generating it is throwing too many constants error in my algoIQ Package.)
Too many constants, the constant pool for AlgoIQPackage would exceed 65536 entries [message #1815313] Mon, 30 September 2019 08:35 Go to next message
while creating new variable and ecore i am getting too many constants,the constant pool error and i got suggestion saying If your package is really big, it's probably automated set the GenPackage's "Model-> Initialize by Loading" to true.
but my model--> Initialize by Loading to true is already set to true but still it is throwing me error.please suggest some more solutions.
Re: Too many constants, the constant pool for AlgoIQPackage would exceed 65536 entries [message #1815314 is a reply to message #1815313] Mon, 30 September 2019 08:57 Go to previous messageGo to next message
And you've also set "Model-> Literals Interface" to false as suggested in the answer here?
https://www.eclipse.org/forums/index.php/mv/msg/1100744/1815312/#msg_1815312
Re: Too many constants, the constant pool for AlgoIQPackage would exceed 65536 entries [message #1815352 is a reply to message #1815314] Tue, 01 October 2019 05:45 Go to previous messageGo to next message
Hi Ed,
Thanks for help.
Yes, "Model-> Literals Interface" is set to false, still I am getting this issue.
  • Attachment: Issue.png
    (Size: 50.35KB, Downloaded 119 times)
[Updated on: Tue, 01 October 2019 05:48] by Moderator
Re: Too many constants, the constant pool for AlgoIQPackage would exceed 65536 entries [message #1815357 is a reply to message #1815352] Tue, 01 October 2019 07:21 Go to previous messageGo to next message
Then your model is probably just too big to represent it reasonably in Java; I've never seen a model so big that it had such a problem. Typically the problem is more likely to get too much byte code for a class's initializers or for a method's body. But it's of course possible to have too many features in a single class such that methods like the XyzImpl.eGet will have too much byte code. I.e., it's always possible to exceed limits. A model with literally 65,000 classes + features does not seem within the capacity of a human being to understand. Presumably this Ecore model was mapped from something else as the source because no human being could or would design such a monstrosity. Perhaps this comes from some obscenely big XML Schema? In that case, you should stop to consider if it's really actually sensible to generate Java code for the model for this use case. Who would actually need to write code against such monstrous generated API? You could just use the *.ecore as a dynamic model instead...
I assume this error appears directly on the AlgoIQPackage interface and not in some nested interface; correct me if that's wrong.
Re: Too many constants, the constant pool for AlgoIQPackage would exceed 65536 entries [message #1815361 is a reply to message #1815357] Tue, 01 October 2019 07:37 Go to previous message
Once you exhaust other alternatives, you might want to investigate the variant JET templates in
https://git.eclipse.org/c/ocl/org.eclipse.ocl.git/tree/examples/org.eclipse.ocl.examples.codegen/templates/model
These eliminate almost all of the INT constants replacing them by inline references. Only those needed by extending models are retained and these are placed in individual ClassImpl files rather than all in one PackageImpl.
(See the numeric switch cases in https://git.eclipse.org/c/ocl/org.eclipse.ocl.git/tree/plugins/org.eclipse.ocl.pivot/emf-gen/org/eclipse/ocl/pivot/internal/ClassImpl.java )
NB. The use of alternate templates only works when you use a programmatic invocation of GenModel such as an MWE2 script.
Ed Willink
Previous Topic:I create an xml element by right click to EMF editor. Default values appear but not get saved to xml
Next Topic:Ecore Generate Problem by creating EMF Project
Current Time: Fri Oct 31 08:49:14 EDT 2025
Powered by FUDForum. Page generated in 0.04690 seconds
