| Genmodel warnings with 2019-06 [message #1814950] |
Mon, 23 September 2019 07:15  |
We recently updated from Oxygen.2 (finally) and now I'm getting some warnings when opening my genmodel.
I couldn't get any markers, validating the ecore and genmodel reported no error or warnings and couldn't figure out what those referred to, until I did a text search on "documentedName" that was part of some warnings. I found out it came from a referenced model "viewpoints" from Sirius.
Even when opening the viewpoints genmodel, I get the warnings, but validating that genmodel reports no errors/warnings.
What are these and how can I handle this, other than ignoring or removing from source ? And also why is that being reported at the level of my genmodel?
Alain
[Updated on: Mon, 23 September 2019 07:16] by Moderator
| Re: Genmodel warnings with 2019-06 [message #1815000 is a reply to message #1814997] |
Tue, 24 September 2019 00:01   |
I can only fix a problem that I can reproduce. As I've always said, subpackages are evil and lead to problems.
It appears that 432544 was fixed without an attachment with a test case so I would have had to make up one myself based on the description. Apparently what I made up is not reflective of your actual problem. Further more, when the problem was "fixed," the reporter of the problem never bothered to look at the result, at least until you did 3 releases later.
So if you want me to look at this problem again, you'll need to open a Bugzilla with an attachment of something that reproduces your exact problem. Because the picture I see here
https://www.eclipse.org/forums/index.php?t=getfile&id=36373&
is exactly what I would expect if "motivation" is a blank root package, i.e, one without classifiers that doesn't actually generate a corresponding EPackage in the generated code. But now of course it's not clear to me at all if "motivation" really is a blank root package or not.
Finally, take note that there would not be any "corresponding" changes in the proxy resolution code; that code is generic and would not contain specialized behavior for any model, not even for Ecore. It all boils down too exactly what resources actually exist for the generated model? Perhaps you have multiple root resources because you've put a useless "blank" package in the root of your original single resource and are ultimately trying to use cross references between it's subpackages. But that's not the original test case that I had to synthesize. And that's why I will not look at this problem without an actual test case this time.
You might avoid this problem by splitting your model into multiple *.ecore resources and specifying your *.genmodel to compose those rather than doing the composition via a blank (pointless and error prone) root package, or you might add a dummy classifier (EDataType) to your blank root package so that it's not a blank root package (generating pointless and useless code). Or you open a Bugzilla and actually test the result, with the underlying assumption that I will actually fix it for free in a timely manner. :-P
| Re: Genmodel warnings with 2019-06 [message #1815003 is a reply to message #1815000] |
Tue, 24 September 2019 01:06  |
The URIs of nested packages do change between dynamic and static versions. e.g. the dynamic path A::B::C becomes the static path C when C.java is produced and EcoreUtil finds no reason to mention A::B::.
This is not normally a problem until you mix usage of dynamic and static model access as model transformation tends to do.
IIRC I was trying to improve the fix this in the OCL ProjectMap a few months ago, found it hard and got distracted. It's still on my bug fix in progress stack.
Ed Willink
FUDForum. Page generated in 0.07695 seconds
