Home » Language IDEs » C / C++ IDE (CDT) » The Resume, Step into, Step Over buttons greyed out(Debug C++ code)
The Resume, Step into, Step Over buttons greyed out [message #1814842] Fri, 20 September 2019 01:06 Go to next message
I use Eclipse IDE for Java Developers
Version: 2018-12 (4.10.0)
Build id: 20181214-0600
My MacOS is Mojave Version 10.14.6.
I installed CDT plugins.
The Resume, Step into, Step Over buttons greyed out when I debug the C++ code. See the attachments. Please help.
Re: The Resume, Step into, Step Over buttons greyed out [message #1814873 is a reply to message #1814842] Sat, 21 September 2019 00:58 Go to previous message
It looks like the debugger never actually started.
Normally (at least for me), the Debug view expands the running task
index.php/fa/36348/0/
If your .gbinit file actually exists, there may be something wrong with it.
Try removing it from the debug launcher to see if that's it.
The debug will have debug actions grayed out when not at a breakpoint.
Maybe your startup code (executed before main) is caught in a loop.
This would mean you never reached the breakpoint in main.
There's a view called Debugger Console which lets you see what's happening.
For example,
index.php/fa/36349/0/
Unfortunately, there isn't enough information and
may require your entire configuration to track down the problem.
You could try with a plain vanilla HelloWorld C++ project.
If that doesn't work then you may have uncovered a bug in the debug interface.
[Updated on: Sat, 21 September 2019 01:03] by Moderator
Previous Topic:java.io.IOException: Cannot create pty
Next Topic:Cannot create pty
Current Time: Sun Jul 20 20:56:35 EDT 2025
Powered by FUDForum. Page generated in 0.03835 seconds
