Home » Modeling » TMF (Xtext) » Build in eclipse ok, failing via maven with NoSuchMethodError
Build in eclipse ok, failing via maven with NoSuchMethodError [message #1814539] |
Thu, 12 September 2019 16:49  |
Hi all,
I created an Xcore project to house my model (not using EMF generation -- maintaining EMF model myself). Xcore project name is io.yaktor.dsl.domain.as (the ".as" stands for "abstract syntax"). I added a project reference of io.yaktor.dsl.domain.as to my main Xtext project (io.yaktor.dsl.domain) and to my io.yaktor.dsl.domain.tests project. I also updated my GenerateDomainModel.mwe2 file to reference my xcore file:
module io.yaktor.dsl.domain.GenerateDomain
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
bean = org.eclipse.emf.mwe.utils.StandaloneSetup {
projectMapping = {
path = "${rootPath}/io.yaktor.dsl.domain.as"
projectName = "io.yaktor.dsl.domain.as"
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "io.yaktor.dsl.domain"
rootPath = rootPath
runtimeTest = {
enabled = true
eclipsePlugin = {
enabled = true
eclipsePluginTest = {
enabled = true
web = {
enabled = true
createEclipseMetaData = true
genericIde = {
enabled = true
code = {
encoding = "UTF-8"
lineDelimiter = "\n"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = StandardLanguage {
name = "io.yaktor.dsl.domain.Domain"
fileExtensions = "ydm"
referencedResource = "platform:/resource/io.yaktor.dsl.domain.as/model/domain.xcore"
fragment = ecore2xtext.Ecore2XtextValueConverterServiceFragment2 auto-inject {}
serializer = {
generateStub = false
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// Generates checks for @Deprecated grammar annotations, an IssueProvider and a corresponding PropertyPage
generateDeprecationValidation = true
junitSupport = {
junitVersion = "5"
Everything is building fine within eclipse. Now, I'm trying to build via maven, and getting the following error:
...(snip)...
[ERROR] Cannot resolve project dependencies:
[ERROR] Software being installed: io.yaktor.dsl.domain 1.0.0.qualifier
[ERROR] Missing requirement: io.yaktor.dsl.domain 1.0.0.qualifier requires 'osgi.bundle; org.eclipse.emf.ecore.xcore 1.10.0' but it could not be found
...(snip)...
So, it appears that I needed to update my target file at io.yaktor.dsl.domain.target/io.yaktor.dsl.domain.target.target to include the xcore stuff. At https://download.eclipse.org/modeling/emf/emf/builds/release/2.18/index.html, I see Xcore SDK 1.10.0 & Xcore Library Runtime 1.5.0, which match the versions that I'm seeing installed in the Xtext version of eclipse (see attached).
I appended the 2.18 EMF repo as a location to my target file:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<?pde version="3.8"?>
<target name="io.yaktor.dsl.domain.target" sequenceNumber="1">
<locations>
<location includeAllPlatforms="false" includeConfigurePhase="false" includeMode="planner" includeSource="true" type="InstallableUnit">
<unit id="org.eclipse.jdt.feature.group" version="0.0.0"/>
<unit id="org.eclipse.platform.feature.group" version="0.0.0"/>
<unit id="org.eclipse.pde.feature.group" version="0.0.0"/>
<unit id="org.eclipse.draw2d.feature.group" version="0.0.0"/>
<unit id="org.eclipse.emf.sdk.feature.group" version="0.0.0"/>
<unit id="org.eclipse.xpand" version="0.0.0"/>
<unit id="org.eclipse.xtend" version="0.0.0"/>
<unit id="org.eclipse.xtend.typesystem.emf" version="0.0.0"/>
<repository location="https://download.eclipse.org/releases/2019-06"/>
</location>
<unit id="org.eclipse.emf.mwe2.launcher.feature.group" version="0.0.0"/>
<repository location="https://download.eclipse.org/modeling/emft/mwe/updates/releases/2.10.0/"/>
</location>
<unit id="org.eclipse.xtext.sdk.feature.group" version="0.0.0"/>
<repository location="https://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.18.0/"/>
</location>
<unit id="com.google.gson" version="2.8.2.v20180104-1110"/>
<unit id="org.antlr.runtime" version="3.2.0.v201101311130"/>
<unit id="org.junit" version="4.12.0.v201504281640"/>
<unit id="org.junit.jupiter.api" version="5.4.0.v20190212-2109"/>
<unit id="org.junit.jupiter.engine" version="5.4.0.v20190212-2109"/>
<unit id="org.junit.platform.commons" version="1.4.0.v20190212-2109"/>
<unit id="org.junit.platform.engine" version="1.4.0.v20190212-2109"/>
<unit id="org.junit.platform.launcher" version="1.4.0.v20190212-2109"/>
<unit id="org.junit.platform.runner" version="1.4.0.v20190212-2109"/>
<unit id="org.opentest4j" version="1.1.1.v20190212-2109"/>
<unit id="org.objectweb.asm" version="7.1.0.v20190412-2143"/>
<unit id="org.objectweb.asm.tree" version="7.1.0.v20190412-2143"/>
<repository location="https://download.eclipse.org/modeling/tmf/xtext/updates/orbit/2019-06"/>
</location>
<unit id="org.eclipse.emf.ecore.xcore" version="0.0.0"/>
<unit id="org.eclipse.emf.ecore.xcore.lib" version="0.0.0"/>
<repository location="https://download.eclipse.org/modeling/emf/emf/builds/release/2.18/"/>
</location>
</locations>
</target>
Then I got the following error during the maven build, indicating some kind of version mismatch, as evidence by the NoSuchMethodError at the bottom of the following log:
[INFO] Scanning for projects...
...(snip)...
[INFO] Fetching p2.index from https://download.eclipse.org/modeling/emf/emf/builds/release/2.18/
[INFO] Adding repository https://download.eclipse.org/modeling/emf/emf/builds/release/2.18
[INFO] Resolving dependencies of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/pom.xml
[INFO] Resolving class path of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/pom.xml
[INFO] Computing target platform for MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ide:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ide/pom.xml
[INFO] Resolving dependencies of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ide:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ide/pom.xml
[INFO] Resolving class path of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ide:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ide/pom.xml
[INFO] Computing target platform for MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ui:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ui/pom.xml
[INFO] Resolving dependencies of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ui:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ui/pom.xml
[INFO] Resolving class path of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ui:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ui/pom.xml
[INFO] Computing target platform for MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.feature:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.feature/pom.xml
[INFO] Resolving dependencies of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.feature:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.feature/pom.xml
[INFO] Resolving class path of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.feature:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.feature/pom.xml
[INFO] Computing target platform for MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.repository:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.repository/pom.xml
[INFO] Resolving dependencies of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.repository:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.repository/pom.xml
[INFO] Resolving class path of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.repository:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.repository/pom.xml
[INFO] Computing target platform for MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.tests:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.tests/pom.xml
[INFO] Resolving dependencies of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.tests:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.tests/pom.xml
[INFO] Resolving class path of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.tests:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.tests/pom.xml
[INFO] Computing target platform for MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ui.tests:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ui.tests/pom.xml
[INFO] Resolving dependencies of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ui.tests:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ui.tests/pom.xml
[INFO] Resolving class path of MavenProject: io.yaktor.dsl.domain:io.yaktor.dsl.domain.ui.tests:1.0.0-SNAPSHOT @ /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ui.tests/pom.xml
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Build Order:
[INFO]
[INFO] io.yaktor.dsl.domain.as [jar]
[INFO] io.yaktor.dsl.domain.parent [pom]
[INFO] io.yaktor.dsl.domain [eclipse-plugin]
[INFO] io.yaktor.dsl.domain.ide [eclipse-plugin]
[INFO] io.yaktor.dsl.domain.ui [eclipse-plugin]
[INFO] io.yaktor.dsl.domain.web [war]
[INFO] io.yaktor.dsl.domain.target [eclipse-target-definition]
[INFO] io.yaktor.dsl.domain.feature [eclipse-feature]
[INFO] io.yaktor.dsl.domain.repository [eclipse-repository]
[INFO] io.yaktor.dsl.domain.tests [eclipse-test-plugin]
[INFO] io.yaktor.dsl.domain.ui.tests [eclipse-test-plugin]
[INFO]
[INFO] ---------------< io.yaktor.dsl:io.yaktor.dsl.domain.as >----------------
[INFO] Building io.yaktor.dsl.domain.as 1.0.0-SNAPSHOT [1/11]
[INFO] --------------------------------[ jar ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.6.1:clean (default-clean) @ io.yaktor.dsl.domain.as ---
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/target
[INFO]
[INFO] --- build-helper-maven-plugin:1.9.1:add-source (add-source) @ io.yaktor.dsl.domain.as ---
[INFO] Source directory: /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/src-gen added.
[INFO]
[INFO] --- xtext-maven-plugin:2.17.0:generate (default) @ io.yaktor.dsl.domain.as ---
[INFO] Encoding: UTF-8
[INFO] Compiler source level: 1.8
[INFO] Compiler target level: 1.8
[INFO] Using common types.
[INFO] Collecting source models.
[INFO] Installing type provider.
[INFO] Generating stubs into /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/target/xtext-temp/stubs
[INFO] Compiling stubs located in /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/target/xtext-temp/stubs
[INFO] Installing type provider for stubs.
[INFO] Validate and generate.
[INFO] Starting validation for input: 'domain.xcore'
[INFO] Starting generator for input: 'domain.xcore'
[INFO]
[INFO] --- maven-resources-plugin:2.6:resources (default-resources) @ io.yaktor.dsl.domain.as ---
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/src/main/resources
[INFO]
[INFO] --- maven-compiler-plugin:3.1:compile (default-compile) @ io.yaktor.dsl.domain.as ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ io.yaktor.dsl.domain.as ---
[INFO] skip non existing resourceDirectory /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/src/test/resources
[INFO]
[INFO] --- maven-compiler-plugin:3.1:testCompile (default-testCompile) @ io.yaktor.dsl.domain.as ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.4:test (default-test) @ io.yaktor.dsl.domain.as ---
[INFO] No tests to run.
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ io.yaktor.dsl.domain.as ---
[INFO] Building jar: /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/target/io.yaktor.dsl.domain.as-1.0.0-SNAPSHOT.jar
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ io.yaktor.dsl.domain.as ---
[INFO] Installing /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/target/io.yaktor.dsl.domain.as-1.0.0-SNAPSHOT.jar to /Users/matthewadams/.m2/repository/io/yaktor/dsl/io.yaktor.dsl.domain.as/1.0.0-SNAPSHOT/io.yaktor.dsl.domain.as-1.0.0-SNAPSHOT.jar
[INFO] Installing /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/pom.xml to /Users/matthewadams/.m2/repository/io/yaktor/dsl/io.yaktor.dsl.domain.as/1.0.0-SNAPSHOT/io.yaktor.dsl.domain.as-1.0.0-SNAPSHOT.pom
[INFO]
[INFO] ----------< io.yaktor.dsl.domain:io.yaktor.dsl.domain.parent >----------
[INFO] Building io.yaktor.dsl.domain.parent 1.0.0-SNAPSHOT [2/11]
[INFO] --------------------------------[ pom ]---------------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ io.yaktor.dsl.domain.parent ---
[INFO]
[INFO] --- tycho-source-plugin:1.4.0:plugin-source (plugin-source) @ io.yaktor.dsl.domain.parent ---
[INFO]
[INFO] --- tycho-source-feature-plugin:1.4.0:source-feature (source-feature) @ io.yaktor.dsl.domain.parent ---
[INFO]
[INFO] --- tycho-p2-plugin:1.4.0:p2-metadata (attach-p2-metadata) @ io.yaktor.dsl.domain.parent ---
[INFO]
[INFO] --- maven-install-plugin:2.4:install (default-install) @ io.yaktor.dsl.domain.parent ---
[INFO] Installing /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/pom.xml to /Users/matthewadams/.m2/repository/io/yaktor/dsl/domain/io.yaktor.dsl.domain.parent/1.0.0-SNAPSHOT/io.yaktor.dsl.domain.parent-1.0.0-SNAPSHOT.pom
[INFO]
[INFO] -------------< io.yaktor.dsl.domain:io.yaktor.dsl.domain >--------------
[INFO] Building io.yaktor.dsl.domain 1.0.0-SNAPSHOT [3/11]
[INFO] ---------------------------[ eclipse-plugin ]---------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ io.yaktor.dsl.domain ---
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/xtend-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.tests/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.ide/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.ui/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.ui.tests/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.web/src-gen (includes = [**/*], excludes = [])
[INFO]
[INFO] --- tycho-packaging-plugin:1.4.0:build-qualifier (default-build-qualifier) @ io.yaktor.dsl.domain ---
[INFO] The project's OSGi version is 1.0.0.201909122031
[INFO]
[INFO] --- tycho-packaging-plugin:1.4.0:validate-id (default-validate-id) @ io.yaktor.dsl.domain ---
[INFO]
[INFO] --- tycho-packaging-plugin:1.4.0:validate-version (default-validate-version) @ io.yaktor.dsl.domain ---
[INFO]
[INFO] --- exec-maven-plugin:1.4.0:java (mwe2Launcher) @ io.yaktor.dsl.domain ---
Sep 12, 2019 3:31:45 PM org.eclipse.emf.mwe.utils.StandaloneSetup addProjectMapping
INFO: Registering project io.yaktor.dsl.domain.as at 'file:/Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.as/'
0 INFO XtextGenerator - Initializing Xtext generator
Sep 12, 2019 3:31:46 PM org.eclipse.emf.mwe.utils.StandaloneSetup addRegisterGeneratedEPackage
INFO: Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
Sep 12, 2019 3:31:46 PM org.eclipse.emf.mwe.utils.StandaloneSetup registerMapping
WARNING: Skipping conflicting project com.google.guava at 'archive:file:/Users/matthewadams/.m2/repository/com/google/guava/guava/27.1-jre/guava-27.1-jre.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/com.google.guava/21.0.0.v20170206-1425/com.google.guava-21.0.0.v20170206-1425.jar!/' instead.
WARNING: Skipping conflicting project com.google.inject at 'archive:file:/Users/matthewadams/.m2/repository/com/google/inject/guice/3.0/guice-3.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/com.google.inject/3.0.0.v201605172100/com.google.inject-3.0.0.v201605172100.jar!/' instead.
WARNING: Skipping conflicting project javax.inject at 'archive:file:/Users/matthewadams/.m2/repository/javax/inject/javax.inject/1/javax.inject-1.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/javax.inject/1.0.0.v20091030/javax.inject-1.0.0.v20091030.jar!/' instead.
WARNING: Skipping conflicting project com.ibm.icu at 'archive:file:/Users/matthewadams/.m2/repository/com/ibm/icu/icu4j/52.1/icu4j-52.1.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/com.ibm.icu/64.2.0.v20190507-1337/com.ibm.icu-64.2.0.v20190507-1337.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.xtext at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/xtext/org.eclipse.xtext/2.19.0/org.eclipse.xtext-2.19.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.xtext/2.18.0.v20190603-1042/org.eclipse.xtext-2.18.0.v20190603-1042.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.xtext.xbase at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/xtext/org.eclipse.xtext.xbase/2.19.0/org.eclipse.xtext.xbase-2.19.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.xbase/2.18.0.v20190603-1025/org.eclipse.xtext.xbase-2.18.0.v20190603-1025.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.equinox.common at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/platform/org.eclipse.equinox.common/3.10.400/org.eclipse.equinox.common-3.10.400.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.equinox.common/3.10.400.v20190516-1504/org.eclipse.equinox.common-3.10.400.v20190516-1504.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.xtext.xbase.lib at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/xtext/org.eclipse.xtext.xbase.lib/2.19.0/org.eclipse.xtext.xbase.lib-2.19.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.xbase.lib/2.18.0.v20190603-0326/org.eclipse.xtext.xbase.lib-2.18.0.v20190603-0326.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.xtext.util at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/xtext/org.eclipse.xtext.util/2.19.0/org.eclipse.xtext.util-2.19.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.util/2.18.0.v20190603-1042/org.eclipse.xtext.util-2.18.0.v20190603-1042.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.xtend.lib at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/xtend/org.eclipse.xtend.lib/2.19.0/org.eclipse.xtend.lib-2.19.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.xtend.lib/2.18.0.v20190603-0326/org.eclipse.xtend.lib-2.18.0.v20190603-0326.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.osgi at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/platform/org.eclipse.osgi/3.14.0/org.eclipse.osgi-3.14.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.osgi/3.14.0.v20190517-1309/org.eclipse.osgi-3.14.0.v20190517-1309.jar!/' instead.
WARNING: Skipping conflicting project org.apache.commons.cli at 'archive:file:/Users/matthewadams/.m2/repository/commons-cli/commons-cli/1.2/commons-cli-1.2.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.apache.commons.cli/1.2.0.v201404270220/org.apache.commons.cli-1.2.0.v201404270220.jar!/' instead.
WARNING: Skipping conflicting project org.apache.commons.logging at 'archive:file:/Users/matthewadams/.m2/repository/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.apache.commons.logging/1.2.0.v20180409-1502/org.apache.commons.logging-1.2.0.v20180409-1502.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.codegen at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.codegen/2.11.0/org.eclipse.emf.codegen-2.11.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.codegen/2.16.0.v20190418-0907/org.eclipse.emf.codegen-2.16.0.v20190418-0907.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.common at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.common/2.12.0/org.eclipse.emf.common-2.12.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.common/2.16.0.v20190528-0845/org.eclipse.emf.common-2.16.0.v20190528-0845.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.codegen.ecore at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.codegen.ecore/2.12.0/org.eclipse.emf.codegen.ecore-2.12.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.codegen.ecore/2.18.0.v20190528-0725/org.eclipse.emf.codegen.ecore-2.18.0.v20190528-0725.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.ecore at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.ecore/2.12.0/org.eclipse.emf.ecore-2.12.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.ecore/2.18.0.v20190528-0845/org.eclipse.emf.ecore-2.18.0.v20190528-0845.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.ecore.xmi at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.ecore.xmi/2.12.0/org.eclipse.emf.ecore.xmi-2.12.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.ecore.xmi/2.16.0.v20190528-0725/org.eclipse.emf.ecore.xmi-2.16.0.v20190528-0725.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.mwe2.runtime at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.mwe2.runtime/2.11.0/org.eclipse.emf.mwe2.runtime-2.11.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.runtime/2.10.0/org.eclipse.emf.mwe2.runtime-2.10.0.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.xtext.common.types at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/xtext/org.eclipse.xtext.common.types/2.19.0/org.eclipse.xtext.common.types-2.19.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.xtext.common.types/2.18.0.v20190603-1025/org.eclipse.xtext.common.types-2.18.0.v20190603-1025.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.mwe.core at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.mwe.core/1.5.0/org.eclipse.emf.mwe.core-1.5.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe.core/1.4.0/org.eclipse.emf.mwe.core-1.4.0.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.mwe.utils at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.mwe.utils/1.5.0/org.eclipse.emf.mwe.utils-1.5.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe.utils/1.4.0/org.eclipse.emf.mwe.utils-1.4.0.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.emf.mwe2.lib at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/emf/org.eclipse.emf.mwe2.lib/2.11.0/org.eclipse.emf.mwe2.lib-2.11.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.emf.mwe2.lib/2.10.0/org.eclipse.emf.mwe2.lib-2.10.0.jar!/' instead.
WARNING: Skipping conflicting project org.eclipse.xtend.lib.macro at 'archive:file:/Users/matthewadams/.m2/repository/org/eclipse/xtend/org.eclipse.xtend.lib.macro/2.19.0/org.eclipse.xtend.lib.macro-2.19.0.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.eclipse.xtend.lib.macro/2.18.0.v20190603-0326/org.eclipse.xtend.lib.macro-2.18.0.v20190603-0326.jar!/' instead.
WARNING: Skipping conflicting project org.objectweb.asm at 'archive:file:/Users/matthewadams/.m2/repository/org/ow2/asm/asm/7.1/asm-7.1.jar!/' and using 'archive:file:/Users/matthewadams/.m2/repository/p2/osgi/bundle/org.objectweb.asm/7.1.0.v20190412-2143/org.objectweb.asm-7.1.0.v20190412-2143.jar!/' instead.
Sep 12, 2019 3:31:46 PM org.eclipse.emf.mwe.utils.StandaloneSetup addProjectMapping
INFO: Registering project io.yaktor.dsl.domain at 'file:/Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/'
INFO: Registering project io.yaktor.dsl.domain.tests at 'file:/Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.tests/'
INFO: Registering project io.yaktor.dsl.domain.ide at 'file:/Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ide/'
INFO: Registering project io.yaktor.dsl.domain.ui at 'file:/Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ui/'
INFO: Registering project io.yaktor.dsl.domain.ui.tests at 'file:/Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.ui.tests/'
INFO: Registering project io.yaktor.dsl.domain.web at 'file:/Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain.web/'
Sep 12, 2019 3:31:46 PM org.eclipse.emf.mwe.utils.StandaloneSetup setResourceSet
INFO: Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
Sep 12, 2019 3:31:47 PM org.eclipse.emf.mwe.utils.GenModelHelper registerGenModel
INFO: Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
INFO: Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
INFO: Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
INFO: Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
1374 ERROR Mwe2Launcher - org.eclipse.emf.codegen.ecore.genmodel.GenModel.clearCache()V
java.lang.NoSuchMethodError: org.eclipse.emf.codegen.ecore.genmodel.GenModel.clearCache()V
at org.eclipse.emf.ecore.xcore.util.XcoreJvmInferrer.inferDeepStructure(XcoreJvmInferrer.java:234)
at org.eclipse.emf.ecore.xcore.resource.XcoreModelAssociator$2.process(XcoreModelAssociator.java:176)
at org.eclipse.emf.ecore.xcore.resource.XcoreModelAssociator$2.process(XcoreModelAssociator.java:1)
at org.eclipse.xtext.util.concurrent.IUnitOfWork$Void.exec(IUnitOfWork.java:37)
at org.eclipse.xtext.util.OnChangeEvictingCache.execWithoutCacheClear(OnChangeEvictingCache.java:128)
at org.eclipse.emf.ecore.xcore.resource.XcoreModelAssociator.installDerivedState(XcoreModelAssociator.java:171)
at org.eclipse.xtext.resource.DerivedStateAwareResource.installDerivedState(DerivedStateAwareResource.java:243)
at org.eclipse.xtext.xbase.resource.BatchLinkableResource.getContents(BatchLinkableResource.java:148)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.each(XtextGeneratorResourceSetInitializer.java:169)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.registerGenModels(XtextGeneratorResourceSetInitializer.java:155)
at org.eclipse.xtext.xtext.generator.XtextGeneratorResourceSetInitializer.initialize(XtextGeneratorResourceSetInitializer.java:44)
at org.eclipse.xtext.xtext.generator.XtextGeneratorLanguage.initialize(XtextGeneratorLanguage.java:218)
at org.eclipse.xtext.xtext.generator.StandardLanguage.initialize(StandardLanguage.java:189)
at org.eclipse.xtext.xtext.generator.XtextGenerator.initialize(XtextGenerator.java:185)
at org.eclipse.xtext.xtext.generator.XtextGenerator.checkConfigurationInternal(XtextGenerator.java:139)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent2.checkConfiguration(AbstractWorkflowComponent2.java:22)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.preInvoke(Mwe2Bridge.java:68)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.preInvoke(AbstractWorkflowComponent.java:207)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.preInvoke(AbstractCompositeWorkflowComponent.java:30)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:102)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:62)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:78)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:36)
at org.codehaus.mojo.exec.ExecJavaMojo$1.run(ExecJavaMojo.java:293)
at java.lang.Thread.run(Thread.java:748)
What did I miss or what am I doing wrong?
Thanks in advance,
Matthew
Re: Build in eclipse ok, failing via maven with NoSuchMethodError [message #1814552 is a reply to message #1814551] |
Fri, 13 September 2019 03:00   |
Note that EMF actually does semi-regular builds that run all the tests against all platform versions as far back as Helios so it's currently Xtext that has the narrower bounds than does EMF itself. This is why I regularly get grumpy about deprecated APIs and even more so about deleted APIs in the platform. I desire to given consumers the broadest range of possibilities.
Moreover, note that by tested, I mean all normal tests run, including org.eclipse.emf.test.codegen.ecore.xtext and org.eclipse.emf.test.ecore.xcore, both of which test the Xtext integration. So there really are tests that verify that EMF actually works within the specified bounds in the MANIFEST.MFs, including even with older versions of Xtext, e.g., 2.15, that are needed for compatibility with such old target platforms due to the more restricted bounds in newer versions of Xtext.
Re: Build in eclipse ok, failing via maven with NoSuchMethodError [message #1814586 is a reply to message #1814556] |
Fri, 13 September 2019 11:03   |
Well, I'm glad this spurred a discussion here and in https://github.com/eclipse/xtext/issues/1282. Not sure why things should be different on the maven side from the eclipse side. Personally, I'd strive to ensure that both maven & eclipse were using the exact same artifacts to ensure consistent builds. I do like that the xtext-dev-bom uses exact versions, a practice that I employ & encourage others to.
In any event, what do you recommend I do right now? I read Christian's recommendation of overriding certain maven artifacts for all EMF plugins in my maven build. Exactly which maven artifacts, and, for each artifact, which version would be preferred? Whatever the latest version is?
Thanks again for your help, folks. :)
Current Time: Fri Sep 26 05:46:28 EDT 2025
Powered by FUDForum. Page generated in 0.09483 seconds
