Home » Language IDEs » C / C++ IDE (CDT) » (Fixed) Enable g++ compiler warnings
(Fixed) Enable g++ compiler warnings [message #1814425] Wed, 11 September 2019 05:23 Go to next message
I'm working in multiple C++ projects in one workspace. All projects are not managed by Eclipse. They are imported as "Existing Code as Makefile Project".
The projects are packaged and built by Maven. Maven calls make at some point. make calls g++ with
-Wall -Wextra -Wshadow -Wnon-virtual-dtor -pedantic -Wold-style-cast -Wcast-align -Wunused -Woverloaded-virtual -Wpedantic -Wconversion -Wsign-conversion -Wlogical-op -Wuseless-cast -Wdouble-promotion -Wformat=2
Now I've noticed that sometimes, probably after the build, Eclipse displays compiler warnings. I think the warnings are somehow read from the artifacts. I'm talking about warnings like:
  • conversion to 'int' from 'mytype {aka unsigned int}' may change the sign of the result [-Wsign-conversion]
  • conversion to 'int' from 'double' may alter its value [-Wconversion]
  • 'var' should be initialized in the member initialization list [-Weffc++]
After I clean a project that displayed these warnings the warnings are gone. I have to build that project to get these warnings back. But it does not work for most projects. Only some projects display these warnings.
How can I enable these warnings for all projects?
index.php/fa/36270/0/
  • Attachment: warnings.png
    (Size: 56.72KB, Downloaded 798 times)
[Updated on: Wed, 11 September 2019 06:46] by Moderator
Re: Enable g++ compiler warnings [message #1814428 is a reply to message #1814425] Wed, 11 September 2019 06:43 Go to previous message
Ok, I found my error. Eclipse parses the log output of the build process and displays the found warnings and errors after the build. In most cases I opened a terminal and built in the terminal. In that case Eclipse isn't able to parse the output, of course. Now I know that I have to build all projects with Eclipse.
I didn't know that Eclipse parses the log output. After I know it I see how stupid it was to build from terminal.
[Updated on: Wed, 11 September 2019 06:45] by Moderator
Previous Topic:Compiler intrinsic #defines not recognized by text editor for AVX2
Next Topic:unresolved inclusion
Current Time: Mon Jul 21 02:34:16 EDT 2025
Powered by FUDForum. Page generated in 0.65756 seconds
