Home » Language IDEs » ServerTools (WTP) » Tomat 4.1 in Eclipse 3.2
Tomat 4.1 in Eclipse 3.2 [message #181417] |
Wed, 11 October 2006 06:35  |
Originally posted by: torgeir.objectplanet.com
I can't get Tomcat started within Eclipse 3.2, due to OutOfMemoryError.
I have increased memory for Eclipse (512mb), and for Tomcat in launch
configuration. Added the option
-Xmx512m
I can't find any logs anywhere to investigate further. In the console, I get
this:
Oct 11, 2006 11:27:17 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on port 8080
Starting service Tomcat-Standalone
Apache Tomcat/4.1.30
Exception during startup processing
at
at
at java.lang.reflect.Method.invoke(Method.java:324)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:20 3)
Caused by: java.lang.OutOfMemoryError
How can I turn on more debugging in either tomcat or Eclipse?
Torgeir.
Re: Tomat 4.1 in Eclipse 3.2 [message #181454 is a reply to message #181441] |
Wed, 11 October 2006 11:37   |
That folder does not exist on my system. I have listed all folders in the
eclipse plugin folder below.
I installed Java 1.5, and ran both Eclipse and Tomcat on this java version,
and it worked!
But if anyone have had the same problem, and found the solution, I would
sure like to know.
Torgeir.
com.ibm.icu.source_3.4.5
com.lowagie.itext_1.3.0.v20060909-0630
com.quantum.Quantum_3.0.1
com.quantum.dbunit_3.0.1
com.quantum.flatfiles_3.0.1
com.quantum.help_3.0.1
de.jave.eclipse.labeldecorator_1.0.2
org.apache.ant_1.6.5
org.apache.axis_1.3.0.v200608161946
org.apache.batik.pdf_1.6.0.v20060613-1220
org.apache.batik_1.6.0.v20060613-1220
org.apache.cactus_1.7.2.v200606181221
org.apache.commons.codec_1.3.0.v20060629-0630
org.apache.commons_logging_1.0.4.v200608011657
org.apache.derby.core_10.1.2.1
org.apache.jakarta_log4j_1.2.8.v200607172048
org.apache.lucene_1.4.103.v20060601
org.apache.wsil4j_1.0.0.v200608161946
org.apache.xerces_2.8.0.v200606131651
org.eclipse.birt.chart.cshelp_2.1.1.v20060925-0939
org.eclipse.birt.chart.runtime_2.1.1.v20060921-1226
org.eclipse.birt.chart_2.1.1.v20060921-1226
org.eclipse.birt.cshelp_2.1.1.v20060921-1226
org.eclipse.birt.data.oda_2.1.1.v20060922-1058
org.eclipse.birt.example_2.1.1.v20060921-1226
org.eclipse.birt.report.data.oda.jdbc_2.1.1.v20060922-1058
org.eclipse.birt.report.data.oda.sampledb_2.1.1.v20060922-10 58
org.eclipse.birt.report.designer.ui_2.1.1.v20060922-1058
org.eclipse.birt.report.designer_2.1.1.v20060921-1226
org.eclipse.birt.report.engine.fonts_2.1.1.v20060926-0959
org.eclipse.birt.report.runtime_2.1.1.v20060921-1226
org.eclipse.birt.report.viewer_2.1.1.v20060926-0959
org.eclipse.birt_2.1.1.v20060921-1226
org.eclipse.core.runtime.compatibility.registry_3.2.1.R32x_v 20060907
org.eclipse.datatools.connectivity.db.generic.ui_0.9.1.20060 8251
org.eclipse.datatools.connectivity.db.generic_0.9.1.20060825 1
org.eclipse.datatools.connectivity.dbdefinition.derby_0.9.0. 200605101
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC_ 0.9.0.200605101
org.eclipse.datatools.connectivity.sqm.core.ui_0.9.1.2006082 51
org.eclipse.datatools.connectivity.sqm.server.ui_0.9.1.20060 8251
org.eclipse.datatools.connectivity.ui.dse_0.9.1.200608251
org.eclipse.datatools.connectivity.ui_0.9.1.200608251
org.eclipse.datatools.connectivity_0.9.1.20060831
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n_0.9.0.200605231
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition_0. 9.0.200605231
org.eclipse.datatools.enablement.ibm.db2.luw.profile_0.9.1.2 00608311
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n_0.9.0.200605231
org.eclipse.datatools.enablement.ibm.informix.dbdefinition_0 .9.0.200605231
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition _0.9.0.200605231
org.eclipse.datatools.enablement.mysql.dbdefinition_0.9.0.20 0605231
org.eclipse.datatools.enablement.mysql.profile_0.9.1.2006083 11
org.eclipse.datatools.enablement.oracle.dbdefinition_0.9.0.2 00605231
org.eclipse.datatools.enablement.oracle.profile_0.9.1.200609 191
org.eclipse.datatools.enablement.sybase.ase.dbdefinition_0.9 .0.200605231
org.eclipse.datatools.enablement.sybase.ase.profile_0.9.1.20 0608311
org.eclipse.datatools.lpg_1.0.0.200608021
org.eclipse.datatools.modelbase.dbdefinition_0.9.0.200605101
org.eclipse.datatools.modelbase.edit_0.9.0.200608311
org.eclipse.datatools.modelbase.sql.query_0.9.0.200608311
org.eclipse.datatools.modelbase.sql.xml.query_0.9.0.20060831 1
org.eclipse.datatools.modelbase.sql_0.9.0.200605101
org.eclipse.datatools.sqltools.parsers.sql.lexer_0.9.0.20060 8311
org.eclipse.datatools.sqltools.parsers.sql.query_0.9.0.20060 8311
org.eclipse.datatools.sqltools.parsers.sql.xml.query_0.9.0.2 00608311
org.eclipse.datatools.sqltools.parsers.sql_0.9.0.200608311
org.eclipse.help.webapp_3.2.1.R321_v20060803
org.eclipse.hyades.analysis.engine_4.2.0.v200606131519
org.eclipse.hyades.execution.win32.x86_4.2.0.v200606131519
org.eclipse.hyades.execution_4.2.2.v200609010912
org.eclipse.hyades.logging.adapter_4.2.1.v200608241753
org.eclipse.hyades.logging.core.sample_4.1.100.v200606131519
org.eclipse.hyades.logging.core_4.2.2.v200609010912
org.eclipse.hyades.logging.parsers_4.2.1.v200608241753
org.eclipse.hyades.perfmon_4.2.0.v200606131519
org.eclipse.hyades.probekit_4.2.1.v200607310100
org.eclipse.hyades.resources.database_4.1.100.v200606190100
org.eclipse.hyades.sdb_4.1.101.v200608302257
org.eclipse.hyades.statistical.ui_4.2.0.v200606131519
org.eclipse.hyades.test.core_4.2.2.v200609010912
org.eclipse.hyades.test.tools.core_4.2.1.v200607310100
org.eclipse.jdt.debug_3.2.1.r321_v20060731
org.eclipse.jdt.junit.runtime_3.2.1.r321_v20060721
org.eclipse.jdt.junit_3.2.1.r321_v20060810
org.eclipse.jdt.source_3.2.1.r321_v20060905-R4CM1Znkvre9wC-
org.eclipse.jst.server.generic.jboss_1.5.1.v200609140551
org.eclipse.jst.server.generic.jonas_1.5.0.v200606130315
org.eclipse.jst.server.generic.oc4j_1.5.0.v200606130315
org.eclipse.jst.server.generic.weblogic_1.5.1.v200609141504
org.eclipse.jst.server.websphere.core_1.0.101.v200609140551
org.eclipse.jst.ws.consumption_1.0.102.v200609220223
org.eclipse.pde.build_3.2.1.r321_v20060823
org.eclipse.pde.source_3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG
org.eclipse.platform.source.win32.win32.x86_3.2.1.r321_v2006 0921-b_XVA-INSQSyMtx
org.eclipse.platform.source_3.2.1.r321_v20060921-b_XVA-INSQS yMtx
org.eclipse.platform_3.2.0.v20060601
org.eclipse.rcp.source.win32.win32.x86_3.2.1.r321_v20060801- 2ekW2BxmcpPUOoq
org.eclipse.rcp.source_3.2.1.r321_v20060801-2ekW2BxmcpPUOoq
org.eclipse.sdk_3.2.1.r321_v20060705
org.eclipse.tomcat_4.1.130.v20060601
org.eclipse.tptp.monitoring.report.birt.ui_4.2.0.v2006061315 19
org.eclipse.tptp.platform.agentcontroller_4.1.100.v200608311 555
org.eclipse.tptp.platform.collection.framework_4.1.100.v2006 06131519
org.eclipse.tptp.platform.execution_4.2.1.v200607310100
org.eclipse.tptp.platform.models_4.2.2.v200609061117
org.eclipse.tptp.platform.report.birt.ui_4.2.0.v200606131519
org.eclipse.tptp.platform.report.core_4.1.101.v200607310100
org.eclipse.tptp.platform.report.ui_4.1.100.v200606131519
org.eclipse.tptp.test.report.birt_4.2.0.v200606131519
org.eclipse.tptp.test.samples_4.1.101.v200607310100
org.eclipse.tptp.trace.report.birt.ui_4.2.0.v200606131519
org.eclipse.ui.intro.universal_3.2.1.R321_v20060905
org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400
org.eclipse.wst.command.env_1.0.102.v200608222020
org.eclipse.wst.rdb.core.ui_1.0.106.v200608212221
org.eclipse.wst.rdb.outputview_1.0.106.v200608142103
org.eclipse.wst.rdb.server.extensions_1.0.104.v200609181831
org.eclipse.wst.rdb.sqleditor_1.0.105.v200609192136
org.eclipse.wst.ws.explorer_1.0.102.v200609132055
org.graysky.eclipse.logwatcher_1.4.0.1
org.junit4_4.1.0.1
org.junit_3.8.1
org.mozilla.rhino_1.6.0.v20060629-0630
org.muermann.gotofile_1.3.4
org.tigris.subversion.javahl.win32_1.1.7
org.uddi4j_2.0.5.v200608231542
org.w3c.sac_1.3.0.v20060629-0630
org.wsdl4j_1.4.0.v200607181917
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:egiurl$bkr$1@utils.eclipse.org...
> What you describe should work. What is the contents of the ".launch" file
> for this server found under the
> ".metadata\.plugins\org.eclipse.debug.core\.launches" directory in your
> workspace?
> Cheers,
> Larry
>> -Xmx512m
>> get
>> this:
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> Thanks
>> Torgeir.
Re: Tomat 4.1 in Eclipse 3.2 [message #181461 is a reply to message #181454] |
Wed, 11 October 2006 12:17   |
Note that the launch configuration file would be under
"<workspace>\.metadata\.plugins\..." instead of
"<install>\eclipse\plugins\...". None of the subdirectories will have
version numbers. Something may have been odd in the launch
configuration file that made "-Xmx512m" not have the desired effect.
Larry
Torgeir Lund wrote:
> Hello,
> and it worked!
> sure like to know.
> Torgeir.
> org.junit4_4.1.0.1
> org.junit_3.8.1
>> workspace?
>> Cheers,
>> Larry
>>> -Xmx512m
>>> get
>>> this:
>>> at
>>> at
>>> Thanks
>>> Torgeir.
Re: Tomat 4.1 in Eclipse 3.2 [message #181470 is a reply to message #181461] |
Wed, 11 October 2006 12:56   |
Currently, it contains the below, but it is after I switched to java 1.5
(from 1.4.2_10), and configured the server to use Java 1.5 as well
I couldn't tell if this file would contain any problem, though.
Torgeir.
<launchConfiguration
type="org.eclipse.jst.server.tomcat.core.launchConfigurationType ">
<booleanAttribute key="org.eclipse.jdt.launching.DEFAULT_CLASSPATH"
value="false"/>
<stringAttribute key="server-id" value="10_11_06_11_54_AM0"/>
<listAttribute key="org.eclipse.jdt.launching.CLASSPATH">
<listEntry value="<?xml version="1.0"
encoding="UTF-8"?>
 ;<runtimeClasspathEntry
containerPath="org.eclipse.jdt.launching.JRE_CONTAI NER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMTyp e/JDK
1.5.08" path="2" type="4"/> "/>
encoding="UTF-8"?>
externalArchive="C:/Program Files/Apache Group/Tomcat
4.1/bin/bootstrap.jar" path="3"
type="2"/> "/>
encoding="UTF-8"?>
externalArchive="C:/Program Files/Java/jdk1.5.0_08/lib/tools.jar"
path="3" type="2"/> "/>
</listAttribute>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS"
value="start"/>
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS"
value="-Xmx256m -XX:MaxPermSize=128m -Dcatalina.base="C:\Documents and
Settings\Torgeir
Lund\workspace\.metadata\.plugins\org.eclipse.wst.server.cor e\tmp0" -Dcatalina.home="C:\Program
Files\Apache Group\Tomcat 4.1" -Djava.endorsed.dirs="C:\Program
Files\Apache Group\Tomcat 4.1\common\endorsed""/>
<stringAttribute key="org.eclipse.jdt.launching.JRE_CONTAINER"
value=" org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.inte rnal.debug.ui.launcher.StandardVMType/JDK
1.5.08"/>
<booleanAttribute key="org.eclipse.debug.core.appendEnvironmentVariables"
value="true"/>
</launchConfiguration>
news:egj5ej$jib$1@utils.eclipse.org...
> version numbers. Something may have been odd in the launch configuration
> Cheers,
> Larry
> Torgeir Lund wrote:
>> Hello,
>> version, and it worked!
>> sure like to know.
>> Torgeir.
>> org.junit4_4.1.0.1
>> org.junit_3.8.1
>>> file for this server found under the
>>> workspace?
>>> Cheers,
>>> Larry
>>>> -Xmx512m
>>>> I get
>>>> this:
>>>> at
>>>> at
>>>> Thanks
>>>> Torgeir.
Re: Tomat 4.1 in Eclipse 3.2 [message #181479 is a reply to message #181470] |
Wed, 11 October 2006 13:24  |
The contents looks fine of course, since it's working. I don't know of
a reason that what you did before wouldn't have worked unless there was
a typo or some such error.
Larry
> Torgeir.
> value="false"/>
> encoding="UTF-8"?>
> encoding="UTF-8"?>
> type="2"/> "/>
> encoding="UTF-8"?>
> </listAttribute>
> value="start"/>
> Settings\Torgeir
> 1.5.08"/>
> value="true"/>
>> Cheers,
>> Larry
>> Torgeir Lund wrote:
>>> Hello,
>>> sure like to know.
>>> Torgeir.
>>> org.junit4_4.1.0.1
>>> org.junit_3.8.1
>>>> workspace?
>>>> Cheers,
>>>> Larry
>>>>> -Xmx512m
>>>>> I get
>>>>> this:
>>>>> at
>>>>> at
>>>>> Thanks
>>>>> Torgeir.
Current Time: Wed Jul 23 20:40:57 EDT 2025
Powered by FUDForum. Page generated in 0.03919 seconds
