Maven build from existing .ecore/.genmodel? [message #1814110] |
Tue, 03 September 2019 19:29  |
Hi all,
I'm resurrecting an old xtext project. My strategy is to use the tooling to create a new one (using the latest version of Xtext), then copy the existing dsl (*.xtext file) source into the new project. Everything is looking pretty good, but it appears that the maven pom files are not generating Java sources from the .ecore/.genmodel files.
I'm deducing this because when I generate from the IDE (open .genmodel, expand root node, right click on first node, then "Generate Model Sources"), then go to the command line and run just "mvn package", it builds ok. However, if I issue "mvn clean package", the build fails because the Java EMF files are not being generated.
How do I configure my pom to generate Java EMF sources during the generate-sources phase? The existing pom is pretty much exactly as it was generated by the eclipse project creation wizard. Portion of pom.xml:
<plugin>
<groupId>org.codehaus.mojo</groupId>
<artifactId>exec-maven-plugin</artifactId>
<version>1.4.0</version>
<executions>
<execution>
<id>mwe2Launcher</id>
<phase>generate-sources</phase>
<goals>
<goal>java</goal>
</goals>
</execution>
</executions>
<configuration>
<mainClass>org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher</mainClass>
<arguments>
<argument>/${project.basedir}/src/io/yaktor/dsl/domain/GenerateDomain.mwe2</argument>
<argument>-p</argument>
<argument>rootPath=/${project.basedir}/..</argument>
</arguments>
<classpathScope>compile</classpathScope>
<includePluginDependencies>true</includePluginDependencies>
<cleanupDaemonThreads>false</cleanupDaemonThreads><!-- see https://bugs.eclipse.org/bugs/show_bug.cgi?id=475098#c3 -->
</configuration>
<dependencies>
<dependency>
<groupId>org.eclipse.emf</groupId>
<artifactId>org.eclipse.emf.mwe2.launch</artifactId>
<version>2.10.0</version>
</dependency>
<dependency>
<groupId>org.eclipse.xtext</groupId>
<artifactId>org.eclipse.xtext.common.types</artifactId>
<version>${xtextVersion}</version>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.xtext.generator</artifactId>
</dependency>
<dependency>
<artifactId>org.eclipse.xtext.xbase</artifactId>
</dependency>
<dependency>
<artifactId>xtext-antlr-generator</artifactId>
<version>2.1.1</version>
</dependency>
</dependencies>
</plugin>
<plugin>
<groupId>org.eclipse.xtend</groupId>
<artifactId>xtend-maven-plugin</artifactId>
</plugin>
Matthew
Re: Maven build from existing .ecore/.genmodel? [message #1814139 is a reply to message #1814114] |
Wed, 04 September 2019 11:57   |
Ok, but it's not happening:
$ mvn clean package
[INFO] -------------< io.yaktor.dsl.domain:io.yaktor.dsl.domain >--------------
[INFO] Building io.yaktor.dsl.domain 1.0.0-SNAPSHOT
[INFO] ---------------------------[ eclipse-plugin ]---------------------------
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ io.yaktor.dsl.domain ---
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/target
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/xtend-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.tests/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.ide/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.ui/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.ui.tests/src-gen (includes = [**/*], excludes = [])
[INFO] Deleting /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/../io.yaktor.dsl.domain.web/src-gen (includes = [**/*], excludes = [])
[INFO]
[INFO] --- tycho-packaging-plugin:1.4.0:build-qualifier (default-build-qualifier) @ io.yaktor.dsl.domain ---
[INFO] The project's OSGi version is 1.0.0.201909032314
[INFO]
[INFO] --- tycho-packaging-plugin:1.4.0:validate-id (default-validate-id) @ io.yaktor.dsl.domain ---
[INFO]
[INFO] --- tycho-packaging-plugin:1.4.0:validate-version (default-validate-version) @ io.yaktor.dsl.domain ---
[INFO]
[INFO] --- exec-maven-plugin:1.4.0:java (mwe2Launcher) @ io.yaktor.dsl.domain ---
0 INFO XtextGenerator - Initializing Xtext generator
Sep 03, 2019 4:14:57 PM org.eclipse.emf.mwe.utils.StandaloneSetup addRegisterGeneratedEPackage
INFO: Adding generated EPackage 'org.eclipse.xtext.common.types.TypesPackage'
Sep 03, 2019 4:14:57 PM org.eclipse.emf.mwe.utils.StandaloneSetup registerMapping
INFO: Using resourceSet registry. The registered Packages will not be registered in the global EPackage.Registry.INSTANCE!
Sep 03, 2019 4:14:58 PM org.eclipse.emf.mwe.utils.GenModelHelper registerGenModel
INFO: Registered GenModel 'http://www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
INFO: Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
INFO: Registered GenModel 'http://www.eclipse.org/xtext/xbase/Xbase' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
INFO: Registered GenModel 'http://www.eclipse.org/xtext/common/JavaVMTypes' from 'platform:/resource/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel'
INFO: Registered GenModel 'http://www.yaktor.io/dsl/domain' from 'platform:/resource/io.yaktor.dsl.domain/model/domain.genmodel'
1139 INFO XtextGenerator - Generating io.yaktor.dsl.domain.Domain
7503 INFO XtextGenerator - Generating common infrastructure
7516 INFO Workflow - Done.
[INFO]
[INFO] --- xtend-maven-plugin:2.18.0:compile (default) @ io.yaktor.dsl.domain ---
[INFO]
[INFO] --- maven-resources-plugin:2.4.3:resources (default-resources) @ io.yaktor.dsl.domain ---
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] skip non existing resourceDirectory /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/src/main/resources
[INFO]
[INFO] --- tycho-compiler-plugin:1.4.0:compile (default-compile) @ io.yaktor.dsl.domain ---
[INFO] Compiling 17 source files to /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/target/classes
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 36.229 s
[INFO] Finished at: 2019-09-03T16:15:10-07:00
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-compiler-plugin:1.4.0:compile (default-compile) on project io.yaktor.dsl.domain: Compilation failure: Compilation failure:
[ERROR] /Users/matthewadams/dev/yaktor/yaktor-dsl-xtext/io.yaktor.dsl.domain.parent/io.yaktor.dsl.domain/src-gen/io/yaktor/dsl/domain/serializer/DomainSemanticSequencer.java:[7]
[ERROR] import io.yaktor.dsl.domain.ecore.domain.AmountField;
[ERROR] ^^^^^^^^^^^^^^^^^^^^^^^^^^
$ ls -al src-gen/io/yaktor/dsl/domain/ # no ecore folder!
total 64
drwxr-xr-x 10 matthewadams staff 320 Sep 3 16:15 .
drwxr-xr-x 3 matthewadams staff 96 Sep 3 16:15 ..
-rw-r--r-- 1 matthewadams staff 9323 Sep 3 16:15 AbstractDomainRuntimeModule.java
-rw-r--r-- 1 matthewadams staff 13075 Sep 3 16:15 Domain.xtextbin
-rw-r--r-- 1 matthewadams staff 1194 Sep 3 16:15 DomainStandaloneSetupGenerated.java
drwxr-xr-x 3 matthewadams staff 96 Sep 3 16:15 parser
drwxr-xr-x 3 matthewadams staff 96 Sep 3 16:15 scoping
drwxr-xr-x 4 matthewadams staff 128 Sep 3 16:15 serializer
drwxr-xr-x 3 matthewadams staff 96 Sep 3 16:15 services
drwxr-xr-x 4 matthewadams staff 128 Sep 3 16:15 validation
Class io.yaktor.dsl.domain.ecore.domain.AmountField is a defined in file model/domain.ecore. When I look in target/classes, there are no classes in io/yaktor/dsl/domain/ecore/domain. Here is my .mwe2 file:
module io.yaktor.dsl.domain.GenerateDomain
import org.eclipse.xtext.xtext.generator.*
import org.eclipse.xtext.xtext.generator.model.project.*
var rootPath = ".."
Workflow {
component = XtextGenerator {
configuration = {
project = StandardProjectConfig {
baseName = "io.yaktor.dsl.domain"
rootPath = rootPath
runtimeTest = {
enabled = true
eclipsePlugin = {
enabled = true
eclipsePluginTest = {
enabled = true
web = {
enabled = true
createEclipseMetaData = true
genericIde = {
enabled = true
code = {
encoding = "UTF-8"
lineDelimiter = "\n"
fileHeader = "/*\n * generated by Xtext \${version}\n */"
language = StandardLanguage {
name = "io.yaktor.dsl.domain.Domain"
fileExtensions = "ydm"
referencedResource = "platform:/resource/io.yaktor.dsl.domain/model/domain.genmodel"
serializer = {
generateStub = false
validator = {
// composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
// Generates checks for @Deprecated grammar annotations, an IssueProvider and a corresponding PropertyPage
generateDeprecationValidation = true
junitSupport = {
junitVersion = "5"
Anyone have any tips here?
FUDForum. Page generated in 0.09768 seconds
