Home » Eclipse Projects » Oomph » Oomph launching with preselected product and project(Launching oomph with a preselected product and a preslected project.setup file)
Oomph launching with preselected product and project [message #1814026] Mon, 02 September 2019 01:18 Go to next message
Hello Oomph-Team,
i have written a setup-file for oomph, which let the user select any allready cloned maven project.
<setup:Project
xmi:version="2.0"
xmlns:git="http://www.eclipse.org/oomph/setup/git/1.0"
xmlns:maven="http://www.eclipse.org/oomph/setup/maven/1.0"
xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
xsi:schemaLocation="http://www.eclipse.org/oomph/setup/git/1.0 http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/models/Git.ecore http://www.eclipse.org/oomph/setup/maven/1.0 http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/models/Maven.ecore"
name="mavenimport"
label="MavenImport">
<setupTask
xsi:type="setup:VariableTask"
name="github.fork.name"
defaultValue="devonfw-forge"
storageURI="scope://Workspace"
label="Fork Name"/>
<setupTask
name="github.repo.name"
defaultValue="jump-the-queue-v2"
label="Repository Name"/>
<setupTask
name="github.remote.uri"
label="Remote URL (HTTPS/SSH)">
<choice
value="https://github.com/${github.fork.name}/${github.repo.name}.git"
label="HTTPS"/>
<choice
value="ssh://github.com/${github.fork.name}/${github.repo.name}.git"
label="SSH"/>
</setupTask>
<setupTask
xsi:type="maven:MavenImportTask">
<sourceLocator
rootFolder="${git.clone.location}/java/"
locateNestedProjects="true"/>
<description>Imports Maven projects contained in the cloned Repo.</description>
</setupTask>
<stream name="master"
label="Master">
<description>Branch to check out.</description>
</stream>
<logicalProjectContainer
xsi:type="setup:ProjectCatalog"
href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']"/>
<description>This imports any project.</description>
</setup:Project>
I would like to launch these project using the commandline with the product (2019-06), but i do not want to click the first two selection in the wizard.
Is there some sort of modification to these setup-file and some sort of command line parameter i can use to do that, so that the eclipse-installer selects these two choices automatically without me having to select and submit my choices in the wizard?
Best Regards
Re: Oomph launching with preselected product and project [message #1814030 is a reply to message #1814026] Mon, 02 September 2019 03:15 Go to previous messageGo to next message
This can be accomplished with a Configuration:
https://wiki.eclipse.org/Eclipse_Oomph_Authoring#Automation_and_Specialization_with_Configurations
You can find several examples of those in use:
https://ci.eclipse.org/emf/
https://ci.eclipse.org/oomph/
https://wiki.eclipse.org/Eclipse_Platform_SDK_Provisioning#Apply_the_Platform_SDK_Configuration
Configuration URIs specified on the command line will be processed automatically the same as if you dragged and dropped it onto the installer.
Re: Oomph launching with preselected product and project [message #1814036 is a reply to message #1814030] Mon, 02 September 2019 05:09 Go to previous messageGo to next message
Thank you for your help.
I wrote a small configuration, choosing automatically the 2019-06 product. But now i am a bit lost (i am pretty new to this). Maybe you could help me out again?
<setup:Configuration
xmi:version="2.0"
label="Target Platform Latest Released">
<installation
name="eclipse.target.platform.latest.released.installation"
label="Latest Release (2019-06) Installation">
<productVersion
href="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.java']/@versions[name='latest.released']"/>
<description>The Java (2019-06) development environment installation provides the full development environment for working Java.</description>
</installation>
<description>THe Java Development Environment configuration provides the full development environment for working on Maven project.</description>
</setup:Configuration>
Now i would like to import my project.setup file and nothing i tried worked. Could you provide me with a good link or tip, how to get that done?
Kind Regards
Re: Oomph launching with preselected product and project [message #1814037 is a reply to message #1814036] Mon, 02 September 2019 05:15 Go to previous messageGo to next message
I may should add that i am executing it with:
call eclipse-inst -vm "C:\Users\software\java\bin" https://raw.githubusercontent.com/dhelmke/NewAsciidocFiles/master/setups/my.automated.products.setup
and it workes by choosing the right product.
Re: Oomph launching with preselected product and project [message #1814040 is a reply to message #1814037] Mon, 02 September 2019 05:45 Go to previous messageGo to next message
Your configuration doesn't have a workspace. The wizard for creating a configuration creates both an installation and a workspace. In the workspace you can reference the projects stream(s). Like the EMF one does:
    xmi:version="2.0"
    label="EMF Development Environment">
  <installation
      name="emf.development.environment.installation"
      label="EMF Development Environment Installation">
    <productVersion
        href="index:/org.eclipse.setup#//@productCatalogs[name='org.eclipse.products']/@products[name='epp.package.committers']/@versions[name='latest']"/>
    <description>The EMF development environment installation provides the full development environment for working with EMF and XSD.</description>
  </installation>
  <workspace
      name="emf.development.environment.workspace"
      label="EMF Development Environment Workspace">
    <setupTask
        name="eclipse.target.platform"
        value="2019-09"/>
    <stream
        href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='emf']/@projects[name='core']/@streams[name='master']"/>
    <stream
        href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='emf']/@projects[name='gwt']/@streams[name='master']"/>
    <stream
        href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='emf']/@projects[name='rap']/@streams[name='master']"/>
    <stream
        href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='emf']/@projects[name='xcore']/@streams[name='master']"/>
    <stream
        href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='xsd']/@streams[name='master']"/>
    <description>The EMF/XSD development environment workspace includes the Core, RAP, GWT, Xcore, ODA, Releng, and XSD.</description>
  </workspace>
  <description>THe EMF Development Environment configuration provides the full development environment for working on EMF.</description>
Re: Oomph launching with preselected product and project [message #1814043 is a reply to message #1814040] Mon, 02 September 2019 05:58 Go to previous messageGo to next message
Thank your for your quick reply. I came across that source myself, but that is more for allready existing projects. I did not found a scource how to import a new project into the eclise-installer?
Sorry for asking again. I copied the workspace and it runs without exception and i used the line:
<project href="https://raw.githubusercontent.com/dhelmke/NewAsciidocFiles/master/setups/MavenImport.setup#/"/>
to import my project, but it is not that easy. Do you have maybe another source, where i culd look that one up?
Best Regards
Re: Oomph launching with preselected product and project [message #1814052 is a reply to message #1814043] Mon, 02 September 2019 06:33 Go to previous messageGo to next message
I hope you don't get tiered of me, it's all new to me. I am now so far that my setup-file looks like-,
xmi:version="2.0"
<installation
<productVersion
</installation>
<setup:WorkspaceTask
id="workspace"/>
<workspace
name="clipse.target.platform.latest.released.workspace"
label="Latest Release (2019-06) Workspace">
<setupTask
value="2019-06"
<setupTask/>
<setupTask
xsi:type="setup:ResourceCreationTask"
content="MAX_RECENT_WORKSPACES=5&#xD;&#xA;RECENT_WORKSPACES=${workspace.location|property}&#xD;&#xA;RECENT_WORKSPACES_PROTOCOL=3&#xD;&#xA;SHOW_WORKSPACE_SELECTION_DIALOG=true&#xD;&#xA;eclipse.preferences.version=1"
targetURL="configuration:/.settings/org.eclipse.ui.ide.prefs"/>
<stream
href="index:/org.eclipse.setup#//@projectCatalogs[name='org.eclipse']/@projects[name='epp']/@projects[name='MavenImport']/@streams[name='master']"/>
</workspace>
But my project is not imported. What iam doing wrong here?
Any help is welcome.
Re: Oomph launching with preselected product and project [message #1814056 is a reply to message #1814052] Mon, 02 September 2019 08:11 Go to previous messageGo to next message
How are you editing this file? A workspace can't contain a project so what is this doing in there?
Best to edit with the Seutp Editor so that you create valid content. You'd use Load Resource... from the context menu to load you MavenImport.setup using the URI like you have, and then you can edit the Workspace's stream property to add the reference to that Project's Stream. (I think you can drag the stream and drop it on the Workspace too.)
Re: Oomph launching with preselected product and project [message #1814062 is a reply to message #1814056] Mon, 02 September 2019 11:15 Go to previous messageGo to next message
Thank you for your reply-.
I think these topic is interesting, I will continue to work on it.
Best Regards
Re: Oomph launching with preselected product and project [message #1814319 is a reply to message #1814062] Mon, 09 September 2019 08:21 Go to previous message
It works now.
Kind regards
Previous Topic:Hosting own index
Next Topic:Defining source and Javadoc location for JRE task
Current Time: Mon Jul 21 07:30:34 EDT 2025
Powered by FUDForum. Page generated in 0.31118 seconds
