Home » Modeling » TMF (Xtext) » Reference an object from parent model
Reference an object from parent model [message #1814035] Mon, 02 September 2019 04:57 Go to next message
I have the following DSL grammar. Please ignore the parts that are not defined in this snippet because they are not relevant in this context.
Context:
	'context' name=CTXT_FQN ('extends' parentContext=[Context|CTXT_FQN] )? '{'
	('data-dictionary' '{'
	attributes+=(Attribute)*
	('entity-catalog' '{'
	entities+=Entity*
Attribute:
	AttributeSimpleType | AttributeEntityType;
AttributeSimpleType:
	name=ID type=(AttributeBaseType | AttributeStringType | AttributeDecimalType) funcName=STRING (desc=STRING)? ';';
Entity:
	name=ID funcName=STRING (desc=STRING)? ('extends' parentEntity=[Entity|ENTITY_FQN])? '{'
	features+=Feature*
Feature:
	(type=FeatureAttributeType | FeatureEntityType)
	(mandatory?='mandatory')?
	(identifier?='identifier')?
	(affinity?='affinity')?
FeatureAttributeType:
	(type=[AttributeSimpleType|ID]|type=[AttributeSimpleType|ATTRIBUTE_FQN]);
terminal VERSION:
    INT '.' INT '.' INT;
terminal CTXT_FQN:
    ID '-' VERSION ;
terminal ENTITY_FQN:
	CTXT_FQN'.'ID;
terminal ATTRIBUTE_FQN:
	CTXT_FQN'.'ID;
What I'm trying to achieve is to be able to define a feature for an entity with an attribute that is available either in my current context, either in the parent context of my current context.
I will try to give you a little example to make it more clear.
context Base_Context-1.0.0  extends Another_Context-1.0.0{
    data-dictionary {
        attribute1 integer 'attribute1' "Description1";
        attribute2 boolean 'attribute2' "" ;
    entity-catalog {
        entity1 'entity1'{
             attribute1
            Another_Context-1.0.0.attribute_anotherContext -> the part that I'm struggling with
context Another_Context-1.0.0{
    data-dictionary {
        attribute_anotherContext integer 'attribute' "Description";
What I've tried so far was to create my own scope provider like below (and many other forms), but I didn't manage to make it work.
class MyDslScopeProvider extends AbstractMetamodelDslScopeProvider {
	val ePackage = MetamodelDslPackage.eINSTANCE;
	override getScope(EObject context, EReference reference){
		if(reference == ePackage.featureAttributeType_Type){
			return scopeForFeature(context,reference)
		return super.getScope(context,reference)
	def protected IScope scopeForFeature(EObject context, EReference reference){
		val List<Attribute> attributes=newArrayList;
		val container = context.eContainer.eContainer as Context
		setFeatures(container, attributes);
		return Scopes::scopeFor(attributes, [QualifiedName.create((it.eContainer as Context).name.split("\\.")).append(it.name)],IScope.NULLSCOPE);
        def protected void setFeatures(Context context, List<Attribute> attributes){
		attributes.addAll(context.attributes);
		if(context.parentContext!==null){
			setFeatures(context.parentContext,attributes);
I can provide more details if needed.
Any suggestion would be more than welcomed.
Thank you!
Kind Regards,
Alexandra
Re: Reference an object from parent model [message #1814045 is a reply to message #1814035] Mon, 02 September 2019 06:06 Go to previous messageGo to next message
your grammar is incomplete but it looks like the ATTRIBUTE_FQN and ENTITY_FQN overlap and thus the ATTRIBUTE_FQN can never match.
(there is a error message regarding this if you run the workflow)
=> what about merging the two
Re: Reference an object from parent model [message #1814059 is a reply to message #1814045] Mon, 02 September 2019 08:56 Go to previous messageGo to next message
Hi Christian,
Thank you for the quick reply.
I didn't realized that they are overlapping and this can create a big mess.
Anyway, I made the following changes but I'm still not able to achieve my goal.
	CTXT_FQN'-'ID;
		if(reference == ePackage.featureAttributeType_Type && context instanceof Entity){
		val container = context.eContainer as Context
		return Scopes::scopeFor(attributes, [QualifiedName.create((it.eContainer as Context).name+"-"+it.name)],IScope.NULLSCOPE);
Re: Reference an object from parent model [message #1814061 is a reply to message #1814059] Mon, 02 September 2019 09:57 Go to previous messageGo to next message
QualifiedName.create((it.eContainer as Context).name+"-"+it.name) is bad if the name contains a .
you have to create the segments in a way that a single segment does not contain a .
why didnt you keep the previous grammar and scoping and replace both FQN with this one:
terminal GENERAL_FQN:
CTXT_FQN'.'ID;
Re: Reference an object from parent model [message #1814073 is a reply to message #1814061] Tue, 03 September 2019 02:07 Go to previous message
I'm clearly a newbie. :)
CTXT_FQN'.'ID;
-> this one works like a charm.
Thank you very much for your help! I really appreciate your implication on Xtext section.
Previous Topic:Couldn't resolve reference to Field 'x'
Next Topic:Xtext / Xtend 2.19 Release
Current Time: Mon Jul 21 05:01:20 EDT 2025
Powered by FUDForum. Page generated in 0.08799 seconds
