Home » Eclipse Projects » Eclipse Scout » Form closing icon (X) presentation also for inactive forms
Form closing icon (X) presentation also for inactive forms [message #1811147] Tue, 27 August 2019 10:10 Go to next message
In my Eclipse Scout application I have many forms with:
	protected int getConfiguredDisplayHint() {
	    return IForm.DISPLAY_HINT_VIEW;
	protected boolean getConfiguredClosable() {
		return true;
But the form closing icon (X) is only displayed on the one, active form in application desktop, not for all open forms at the same time.
Can this be changed to make this icon also appear on inactive forms?
Re: Form closing icon (X) presentation also for inactive forms [message #1811285 is a reply to message #1811147] Fri, 30 August 2019 02:48 Go to previous message
Hi Krzysztof
Currently there's no way to activate the "X" for closable forms on inactive forms.
However, there's a context-menu (right click) that allows to close all tabs or all other tabs (see attachment).
If you're brave you could try to make some adjustments on Scout's JavaScript/CSS framework code. You could disable this CSS rule here ".simple-tab.closable .closer" - which hides the "X" for inactive tabs. Now you can close inactive tabs, but I'm not sure if this has any side-effects.
Previous Topic:Scout Explorer and setting up a connection to MySQL
Next Topic:Lookup Call
Current Time: Sun Aug 31 01:16:28 EDT 2025
Powered by FUDForum. Page generated in 0.03789 seconds
