Home » Modeling » Papyrus » Papyrus SysML Tutorial (version 0.1.3)(Papyrus SysML Tutorial (version 0.1.3))
Papyrus SysML Tutorial (version 0.1.3) [message #1807841] Mon, 10 June 2019 13:41 Go to next message
Continued development of Papyrus SysML Tutorial.... added internal block diagram with some signals, some value types , and measures of effectiveness... the Black Box analysis is concluded ..... I will start the White Box analysis next
Re: Papyrus SysML Tutorial (version 0.1.3) [message #1808241 is a reply to message #1807841] Thu, 20 June 2019 04:27 Go to previous messageGo to next message
Hello Ben, we took an eye at the tutorial you have proposed. Thank you for your contribution.
We are currently working on making Papyrus easier to learn in the context of Systems Engineering using embedded tutorials, cheatsheets or alike. Should we use your proposal and content, we would get back to you.
Best regards
Theo for the Papyrus team
Re: Papyrus SysML Tutorial (version 0.1.3) [message #1811047 is a reply to message #1808241] Sun, 25 August 2019 20:30 Go to previous messageGo to next message
Hi together,
this tutorial is really good and it helps to let me understand sysml in Papyrus. Is there a place where I can find more of them?
Best,
Michael
Re: Papyrus SysML Tutorial (version 0.1.3) [message #1811099 is a reply to message #1811047] Mon, 26 August 2019 17:18 Go to previous messageGo to next message
There's also a tutorial named "Getting Started with Papyrus UML Light" at: https://wiki.eclipse.org/Getting_Started_with_Papyrus_UMLLight
And three for Papyrus for Real Time at https://wiki.eclipse.org/Papyrus-RT/User#Tutorials
[Updated on: Mon, 26 August 2019 17:23] by Moderator
Re: Papyrus SysML Tutorial (version 0.1.3) [message #1821831 is a reply to message #1821817] Thu, 20 February 2020 15:17 Go to previous messageGo to next message
Hello Sophie,
Yes I used a similar workflow example (a car climate control unit) based on the Cameo System Modeler Book of Knowledge. My company has a license for Cameo and therefore I was able to read it. Unfortunately it is copyrighted so i cannot provide it and it is probably not on the web as you have discovered. It would not help you with Papyrus as the example only tells you how to do things in Cameo anyway.
v/r,
Ben
Re: Papyrus SysML Tutorial (version 0.1.3) [message #1826988 is a reply to message #1821831] Tue, 05 May 2020 14:50 Go to previous messageGo to next message
Ben,
Awesome work. Could you add some material on ports and data flows?
I'm trying to learn SysML using Papyrus and am having difficulty with ports and flows. I've used FlowPorts with connectors previously without issue. I noticed in your tutorial you didn't use ports at all but stuck with ItemFlows. Could you add some coverage of ports? Specifically FlowPorts, Ports, FullPorts, and ProxyPorts. I have an older SysML book that covers FlowPorts and (UML) Ports only. If I had some examples then I could tell if what I'm doing is incorrect or if I'm hitting a bug. What few examples exist in the wild pertain to commercial tools.
Thank you!
G. J.
[Updated on: Tue, 05 May 2020 15:35] by Moderator
Re: Papyrus SysML Tutorial (version 0.1.3) [message #1831050 is a reply to message #1826988] Mon, 10 August 2020 14:17 Go to previous message
Many of you have enjoyed my initial tutorial on modeling with SysML in Papyrus. The tutorial became too big to post here so I have given the files to a friend to publish for me on Kindle. It is free for Prime members and $9.95 to buy should you choose. Link is below. Enjoy.
https://www.amazon.com/Practical-Guide-Systems-Modeling-Papyrus-ebook/dp/B08F5JNX92/ref=sr_1_4?dchild=1&keywords=sysml&qid=1596807933&s=digital-text&sr=1-4
Previous Topic:Last try
Next Topic:table problem
Current Time: Mon Nov 03 16:33:09 EST 2025
Powered by FUDForum. Page generated in 0.03897 seconds
