Home » Newcomers » Newcomers » Eclipse won't install - JRE detection failure (Windows)(Unable to install Eclipse, because the Eclipse Installer generates a JRE-related error message and refuses to continue)
Eclipse won't install - JRE detection failure (Windows) [message #1810879] Wed, 21 August 2019 05:12 Go to next message
I just downloaded the most recent version of the Eclipse Installer (https://www.eclipse.org/downloads/download.php?file=/oomph/epp/2019-06/R/eclipse-inst-win64.exe) from your website.
Prior to that, I installed an (unofficial) OpenJDK build (https://github.com/ojdkbuild/ojdkbuild/releases/download/java-12-openjdk-12.0.2.9-1/java-12-openjdk-12.0.2.9-1.windows.ojdkbuild.x86_64.msi).
After installation, the command "java -version" generates the following output:
openjdk version "12.0.2-ojdkbuild" 2019-07-16
OpenJDK Runtime Environment 19.3 (build 12.0.2-ojdkbuild+9)
OpenJDK 64-Bit Server VM 19.3 (build 12.0.2-ojdkbuild+9, mixed mode, sharing)
(Note: the "-d64" switch does not seem to be supported by my JRE.
Immediately after attempting to run the Eclipse Installer, I get the following messagebox:
Eclipse Installer
A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run Eclipse Installer. No Java virtual machine was found after searching the following locations: C:\Program Files\ojdkbuild\java-12-openjdk-12.0.2-1" --\bin
OK
The JRE folder displayed in this message seems to be incorrect. What am I doing wrong here? Is there a way to explicitly specify the correct JRE folder for the installer?
Operating system: Microsoft Windows [Version 10.0.18362.295]
(Note: I do not even want to consider using a Java SE runtime environment from Oracle.)
Thank You very much in advance.
Re: Eclipse won't install - JRE detection failure (Windows) [message #1810899 is a reply to message #1810879] Wed, 21 August 2019 09:21 Go to previous messageGo to next message
You could try the -vm argument, i.e., this run the installer with this specific VM on my machine
./eclipse-inst.exe -vm C:\\Program\ Files\\Java\\jdk1.8.0_121\\bin
. Here I've used a bash shell, hence the double \\ but you get the idea...
Re: Eclipse won't install - JRE detection failure (Windows) [message #1810903 is a reply to message #1810899] Wed, 21 August 2019 10:04 Go to previous message
Hi Ed. Thanks for the response. Nice tip about the -vm installer option. I will keep it in mind.
However, I didn't need to use that option, because shortly after posting my message, I had been able to continue my installation. It seemed, that when I clicked the downloaded installer from within my browser's (Firefox) recent downloads, I got that strange error. But if I executed the installer by double clicking it in an Explorer window, it worked just fine. (I use a 64-bit Firefox version as well, so that should not be the issue. Very strange...)
Anyway, I am able now to dive into Eclipse. Thanks again. :)
[Updated on: Wed, 21 August 2019 10:05] by Moderator
Previous Topic:MQTT test broker name change
Next Topic:User Specified Entries in XML Catalog Are Ignored
Current Time: Sun Jul 27 09:04:09 EDT 2025
Powered by FUDForum. Page generated in 0.09572 seconds
