Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Loop over empty OrderedSet creates empty lines(Or: How to ask if something != null)
[Acceleo] Loop over empty OrderedSet creates empty lines [message #1810144] Thu, 01 August 2019 06:43 Go to next message
I'm generating a .yaml file from an Xtext model and I have too many empty lines in it. In my template I print some properties that I get in an OrderedSet. During generation I get the following warning:
Invalid loop iteration at line 27 in Module generateDeployment for block for (aContainer.properties). Last recorded value of self was null.
in
[for (aProperty : Property | aContainer.properties)]
    [aProperty.printProperties()/]
[/for]
'aContainer.properties' is the OrderedSet, which is null sometimes. I'm pretty sure that this triggers the warning.
I would like to use "!= null" or "!oclIsUndefined" but I can't find a "not" operation anywhere.
I know that I can remove the empty lines in a post process, but I really don't want the warnings because the user will see them.
Thanks in advance,
Saphira
EDIT:
so (something <> null) is working, I put it in front of every loop. Is there maybe a better way?
[Updated on: Thu, 01 August 2019 06:59] by Moderator
Re: [Acceleo] Loop over empty OrderedSet creates empty lines [message #1810155 is a reply to message #1810144] Thu, 01 August 2019 11:49 Go to previous message
There are surely many different ways. Which is 'better' would require analysis of more of your code. However using a not-null guard to protect against null usage is a pretty standard idiom in many languages, so I suspect most alternatives would just be obscure.
Ed Willink
Previous Topic:[acceleo] Standalone compiler (ant task)
Next Topic:[Acceleo] allInstances operator not available?
Current Time: Mon Jul 21 03:10:19 EDT 2025
Powered by FUDForum. Page generated in 0.27401 seconds
