Using JUnit to test Viatra transformations [message #1809750] |
Mon, 22 July 2019 10:41  |
I want to test a viatra project using JUnit plug-in tests. But I get errors such as:
java.lang.NullPointerException: System default backend not found
at java.util.Objects.requireNonNull(Objects.java:228)
at org.eclipse.viatra.query.runtime.api.ViatraQueryEngineOptions.getSystemDefaultBackend(ViatraQueryEngineOptions.java:75)
at org.eclipse.viatra.query.runtime.api.ViatraQueryEngineOptions.access$4(ViatraQueryEngineOptions.java:71)
at org.eclipse.viatra.query.runtime.api.ViatraQueryEngineOptions$Builder.getDefaultBackend(ViatraQueryEngineOptions.java:173)
at org.eclipse.viatra.query.runtime.api.ViatraQueryEngineOptions$Builder.build(ViatraQueryEngineOptions.java:162)
at org.eclipse.viatra.query.runtime.api.ViatraQueryEngineOptions.getDefault(ViatraQueryEngineOptions.java:105)
at org.eclipse.viatra.query.runtime.api.ViatraQueryEngineManager.getQueryEngine(ViatraQueryEngineManager.java:86)
at org.eclipse.viatra.query.runtime.api.ViatraQueryEngine.on(ViatraQueryEngine.java:70)
at fr.tpt.mem4csd.mtbench.aadl2aadl.viatra.tests.AbstractAadl2AadlTest.executeAadl2AadlTransformation(AbstractAadl2AadlTest.java:143)
at fr.tpt.mem4csd.mtbench.aadl2aadl.viatra.tests.Aadl2AadlTest.testAadl2Aadl(Aadl2AadlTest.java:18)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.run(JUnit4TestReference.java:86)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:538)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:760)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:460)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:206)
I found this old page https://wiki.eclipse.org/VIATRA/Query/UserDocumentation/HeadlessExecution#Running_JUnit_plug-in_tests_supported_by_VIATRA_Query_queries but it misses the documentation about the use of viatra + juint
Is that possible to test a viatra transformation with Junit ?
Re: Using JUnit to test Viatra transformations [message #1809753 is a reply to message #1809750] |
Mon, 22 July 2019 11:24   |
Hi Hana,
it is possible to run VIATRA queries and transformations in JUnit; the error message refers to a configuration issue, most likely caused by missing dependencies. More specifically, this behaviour was introduced in v2.0 [1] that changes the order of a few internal dependencies.
To fix the issue, you have to ensure that the classpath should have the `org.eclipse.viatra.query.runtime`, the `org.eclipse.viatra.query.runtime.rete` and the `org.eclipse.viatra.query.runtime.localsearch` bundles on the Java classpath. More specifically:
1. If you are working with Eclipse plugins, ensure all three mentioned bundles are present to the required plugins section. If you generate a new VIATRA project, the wizard ensures this.
2. If you aim to use VIATRA in a headless environment, you could rely on the `org.eclipse.viatra` : `viatra-query-runtime` Maven dependency to access every required dependency. [2]
I hope this was helpful; if not, feel free to ask for clarification.
Zoltán
[1] https://www.eclipse.org/viatra/documentation/releases.html#_dependency_updates_in_query_runtime
[2] https://www.eclipse.org/viatra/documentation/query-tools.html#_repository
FUDForum. Page generated in 0.37064 seconds
