Result after running Executable [message #1809858] |
Wed, 24 July 2019 20:05  |
I am having a strange issue that I cant seem to solve. I am compiling a test suite for TTCN3 and after compiling all the executable does is print out "test start". I have tried compiling the demo example and it correctly prints out "TTCN-3 Host Controller (parallel mode), version CRL 113 200/6 R6A" when run. I am also able to run the test cases on the eclipse plugin.
The test suite I am working on is also able to correctly run and compile on a colleagues PC with Cygwin and he receives the correct result. I am compiling this suite on a windows VM with virtual box and I am using cygwin. If you need anymore information please let me know. They are also being compiled using the TTCN3-Parallel option. Any help is greatly appreciated I'm sort of at a loss.
Also I tried looking at the exec running with gdb and it seems to be failing some sort of checksum when running. Not sure if that really helps.
Images of me trying to run. (btw Im not actually trying to run the test suites here Im only demonstrating that my executable seems to be compiling incorrectly.)
Re: Result after running Executable [message #1809907 is a reply to message #1809858] |
Thu, 25 July 2019 09:57   |
Hi Matthew,
your test.exe was compiled in single mode, thus it could run simple. But its output is strange. A typical single mode titan executable produces an output like this:
$ ./TR_2019_07_ttcn2cpp.exe
TTCN-3 Test Executor (single mode), version CRL 113 200/6 R6A
Execution of control part in module IntX started.
Test case tc_intx_unsigned started.
Test case tc_intx_unsigned finished. Verdict: pass
Test case tc_intx_signed started.
Test case tc_intx_signed finished. Verdict: pass
Test case tc_intx_2scompl started.
Test case tc_intx_2scompl finished. Verdict: pass
Test case tc_intx_record_of started.
Test case tc_intx_record_of finished. Verdict: pass
Test case tc_intx_record started.
Warning: f_dec_intx_rec_part(): Data remained at the end of the stream after successful decoding: 'A0'O
Test case tc_intx_record finished. Verdict: pass
Test case tc_intx_decode_error started.
Test case tc_intx_decode_error finished. Verdict: pass
Execution of control part in module IntX finished.
Verdict statistics: 0 none (0.00 %), 6 pass (100.00 %), 0 inconc (0.00 %), 0 fail (0.00 %), 0 error (0.00 %).
Test execution summary: 6 test cases were executed. Overall verdict: pass
Your demo.exe was compiled in parallel mode. It can be run this way (see UserGuide.pdf/Chapter 4.4):
ttcn3_start demo your.cfg
(If you had installed "expect")
If you don't have expect, the more complicated method should be folllowed according to 4.4
Best regards
Jeno Balasko, Titan Team, Ericsson
Re: Result after running Executable [message #1809935 is a reply to message #1809922] |
Thu, 25 July 2019 16:03  |
I figured out the issue there the file system im working with is large and I forgot to exclude a test file written that contained a main function that printed 'test start" you can close this thread if you want to.
FUDForum. Page generated in 0.04006 seconds
