Home » Modeling » TMF (Xtext) » Access to the fields of a package (Tree structure)
Access to the fields of a package (Tree structure) [message #1809878] Thu, 25 July 2019 05:31 Go to next message
Hello xTexters,
I have a question concerning this code :
grammar org.xtext.metalist.Metalist with org.eclipse.xtext.common.Terminals
generate metalist "http://www.xtext.org/metalist/Metalist"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
METALIST:
packages+=Package+;
Package:
	'_¡' name=packageName
	nb=nbField '®'
	(fields+=Fields)+
Fields:
	{Fields} numField  '¡' name=field? '¡'
(packageName and field are simple IDs)
This is the structure of the declaration of a package and its fields. (definition dedicated DSL)
Now i'd like to have the fields parsed and content assisted according to the package they are contained in.
I'd need to use something of the form "package.field" in many statement so i created this rule in my main DSL
PackageFieldExpression:
	pack=[ML::Package|MAJID] ('.' field=[ML::Fields|MAJID])?
I can already access to my package easily but i can' access the fields corresponding to the package, having couple of errors.
Do you know how i could achieve this ? I tried may solutions including this one : https://stackoverflow.com/questions/21306822/xtext-dsl-reference-to-attribute that seemed similar to my situation but it didn't solve it.
Thank u
[Updated on: Thu, 25 July 2019 06:12] by Moderator
Re: Access to the fields of a package (Tree structure) [message #1809883 is a reply to message #1809878] Thu, 25 July 2019 05:41 Go to previous messageGo to next message
How does your scope provider look like
Is AbstractDeclarativeScopeProvider the parent class
Re: Access to the fields of a package (Tree structure) [message #1809887 is a reply to message #1809883] Thu, 25 July 2019 06:16 Go to previous messageGo to next message
For the moment, my ScopeProvider looks lite this :
package org.xtext.itl.scoping
import org.xtext.itl.iTL.PackageFieldExpression
import org.eclipse.xtext.scoping.IScope
import org.eclipse.emf.ecore.EReference
import org.eclipse.xtext.scoping.Scopes
class ITLScopeProvider extends AbstractITLScopeProvider {
    def IScope scope_PackageFieldExpression_field(PackageFieldExpression dat, EReference ref) {
        return Scopes.scopeFor(dat.pack.fields)
Is it ok to replace my parent class AbstractITLScopeProvider with AbstractDeclarativeScopeProvider ?
Re: Access to the fields of a package (Tree structure) [message #1809889 is a reply to message #1809887] Thu, 25 July 2019 06:27 Go to previous messageGo to next message
I works great with what you suggested thank you i missread! Modyfing this extend class won't cause any problem?
Re: Access to the fields of a package (Tree structure) [message #1809893 is a reply to message #1809889] Thu, 25 July 2019 07:08 Go to previous messageGo to next message
no it wont.
but you are encoraged to implement the existing scope provider class by overriding getScope and if else on context and ereference parameters
Re: Access to the fields of a package (Tree structure) [message #1809902 is a reply to message #1809893] Thu, 25 July 2019 08:55 Go to previous messageGo to next message
Allright, got it, thank you.
I have another related question. Is it the same way to operate for this kind of rule ?
AddOccStatement: {AddOccStatement} ('ADDOCC') addocPack=[ML::Package] (('PARENT') parentPack=[ML::Package])? (('WITH') fieldAssignList=FieldAssignList)?;
FieldAssign  : fieldToAssign=[ML::Fields] compareOperator compare=data ;
FieldAssignSingle: => list+=FieldAssign (',' list+=FieldAssign)* ;
FieldAssignList: (list+=FieldAssignSingle)+;
I came up to this so far :
 def IScope scope_AddOccStatement_fieldToAssign(AddOccStatement dat, EReference ref) {
        return Scopes.scopeFor(dat.addocPack.fields)
But it doesn' seem to work out since the fields are
in an inner rule of an inner rule
[Updated on: Thu, 25 July 2019 09:00] by Moderator
Re: Access to the fields of a package (Tree structure) [message #1809909 is a reply to message #1809902] Thu, 25 July 2019 10:15 Go to previous message
yes and no. there are two problems. scoping vs content assist.
for scoping scope_FieldAssign_fieldToAssign(FieldAssign ctx, EReference r) // this is cause objects are created lazy (after the assignment
but the scope provider will ask for
scope_FieldAssign_fieldToAssign(AddOccStatement ctx, EReference r) too (it will walk up the parents until it finds something
Previous Topic:Multiple QualifiedProviders within a DSL language
Next Topic:Model meta elements and their instances?
Current Time: Wed Jul 23 13:30:33 EDT 2025
Powered by FUDForum. Page generated in 0.26628 seconds
