Home » Modeling » TMF (Xtext) » Exception when referencing between Resources in same ResourceSet
Exception when referencing between Resources in same ResourceSet [message #1809794] Tue, 23 July 2019 09:43 Go to next message
I'm adding two (in this small example, otherwise a lot more) objects to my "main" Model programmatically (with MyDslFactory). One of them is saved in a different Resource which is in the same ResourceSet as the original one (I checked). The other one is saved in the "main" Model and contains a reference to the first object. Here an example grammar with model files:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Model:
	elements+=Element*;
Element:
	First | Second;
First:
	'first' name=ID;
Second:
	'second' item=Reference;
Reference:
	'refers' reference=[First];
initial model (example.mydsl):
first object
second refers object
how the model should look like afterwards (example.mydsl):
first object
second refers newObject
and newObject.mydsl :
first newObject
I'm able to create and save 'newObject' to a new resource 'newObject.mydsl' but when I try to save the "main" model with the added 'second refers newObject' I get a RuntimeException:
java.lang.RuntimeException: No EObjectDescription could be found in Scope Reference.reference for Model.elements[0]->First'newObject'
Semantic Object: Model.elements[2]->Second.item->Reference
URI: file:/C:/Users/flug/runtime-EclipseXtext/example/example.mydsl
EStructuralFeature: myDsl::Reference.reference
Here the code I'm executing (see also the whole project attached)
	public static void createNewObject(IPath path) {
		Injector injector = MydslActivator.getInstance().getInjector(MydslActivator.ORG_XTEXT_EXAMPLE_MYDSL_MYDSL);
		XtextResourceSet resourceSet = injector.getInstance(XtextResourceSet.class);
		resourceSet.addLoadOption(XtextResource.OPTION_RESOLVE_ALL, Boolean.TRUE);
		URI modelURI = URI.createFileURI(path.toString());
		Resource resource = resourceSet.getResource(modelURI, true);
		Model model = (Model) resource.getContents().get(0);
		Model modelForObject = MyDslFactory.eINSTANCE.createModel();
		First newObject = MyDslFactory.eINSTANCE.createFirst();
		newObject.setName("newObject");
		modelForObject.getElements().add(newObject);
		URI objectURI = modelURI.trimSegments(1).appendSegment("newObject.mydsl");
		Resource objectResource = resourceSet.createResource(objectURI);
		objectResource.getContents().add(modelForObject);
		try {
			objectResource.save(Collections.EMPTY_MAP);
		} catch (IOException e) {
			e.printStackTrace();
		Reference reference = MyDslFactory.eINSTANCE.createReference();
		reference.setReference(newObject);
		Second second = MyDslFactory.eINSTANCE.createSecond();
		second.setItem(reference);
		model.getElements().add(second);
		try {
			resource.save(Collections.EMPTY_MAP);
To trigger the exception you have to start 'org.xtext.example.mydsl' as an eclipse plugin, add the 'example' project attached to your workspace (or create a new file and copy the "initial model" above), right click on 'example.mydsl' -> 'Create New Object'. The Exception won't be visibly thrown (at least not for me). To actually read it I have to set a breakpoint at the second save() call and "walk" to the exception in debug mode (tips for printing it in the console are very much appreciated).
So my question is: Why is the Reference not working and how do I get it to work?
Please ask for further explanations if my question isn't clear enough. Thanks in advance for your help.
Saphira
Re: Exception when referencing between Resources in same ResourceSet [message #1809795 is a reply to message #1809794] Tue, 23 July 2019 09:47 Go to previous messageGo to next message
in eclipse the "resourceSet" works only if you make use of XtextLiveScopeResourceSetProvider to obtain a resourcset or at least make use of LiveScopeResourceSetInitializer
[Updated on: Tue, 23 July 2019 09:47] by Moderator
Re: Exception when referencing between Resources in same ResourceSet [message #1809799 is a reply to message #1809795] Tue, 23 July 2019 10:15 Go to previous messageGo to next message
@Christian: I'm not sure that you've written what you really mean.
In Eclipse, ResourceSets are widely used in many modeling applications following an initial new ResourceSetImpl, and wherever sensible you should add new facilities to an existing ResourceSet, rather than creating a new one.
Xtext introduced the XtextResourceSet and SynchronizedXtextResourceSet that do good things for the Xtext tooling, but which are largely hidden from the modeling side of Xtext-based applications.
I'm never quite sure what injection does so I can only suspect that your
is creating a new ResourceSet rather than accessing an old one. It is certainly using an XtextResourceSet where I would expect a pre-existing ResourceSet would be more appropriate.
Ed Willink
Re: Exception when referencing between Resources in same ResourceSet [message #1809800 is a reply to message #1809795] Tue, 23 July 2019 10:17 Go to previous messageGo to next message
Hi Christian,
thanks for your quick reply. I tried
XtextResourceSet resourceSet = (XtextResourceSet) injector.getInstance(XtextLiveScopeResourceSetProvider.class).get(project);
which didn't change anything. Then I tried injecting it to my handler (org.xtext.example.mydsl.ui.MyDslExecutableExtensionFactory:org.xtext.example.mydsl.ui.handlers.CreateNewObjectHandler) and
	@Inject
	XtextLiveScopeResourceSetProvider provider;
but it was null. Sorry I'm not that familliar with Injection. Is there a documentation for the XtextLiveScopeResourceSetProvider somewhere?
Thanks a lot,
Saphira
Re: Exception when referencing between Resources in same ResourceSet [message #1809804 is a reply to message #1809800] Tue, 23 July 2019 11:53 Go to previous messageGo to next message
You can ask the injector for the stuff
Alternatively you should change the handler declaration to
class="xxx.MyDslExecutableExtensionFactory:xxx.MyHandler"
In the Plugin. XML to get injection running
See other usages of mydslexecutableextensionfactor in mydsl Ui Plugin.xml
Re: Exception when referencing between Resources in same ResourceSet [message #1809962 is a reply to message #1809804] Fri, 26 July 2019 10:35 Go to previous messageGo to next message
do you mean
by Quote:
? Using this still won't change anything.
So I changed my handler declaration and the injection works fine. But I still get the same error.
Re: Exception when referencing between Resources in same ResourceSet [message #1809965 is a reply to message #1809962] Fri, 26 July 2019 11:12 Go to previous messageGo to next message
yes the uri stuff you do is terrible suspiciously too
public class MyDslHandler extends AbstractHandler {
	@Inject
	XtextLiveScopeResourceSetProvider rsp;
	public Object execute(ExecutionEvent event) throws ExecutionException {
		ISelection selection = HandlerUtil.getCurrentSelection(event);
        if (selection instanceof IStructuredSelection) {
            IStructuredSelection structuredSelection = (IStructuredSelection) selection;
            Object firstElement = structuredSelection.getFirstElement();
            if (firstElement instanceof IFile) {
            	IFile file = (IFile) firstElement;
            	URI modelURI = URI.createPlatformResourceURI(file.getFullPath().toString(), true);
            	XtextResourceSet resourceSet = (XtextResourceSet) rsp.get(file.getProject());
            	URI objectURI = modelURI.trimSegments(1).appendSegment("newObject."+file.getFileExtension());
            	try {
            	try {
            	// TODO Auto-generated method stub
        return null;
Re: Exception when referencing between Resources in same ResourceSet [message #1809967 is a reply to message #1809965] Fri, 26 July 2019 11:52 Go to previous message
Thanks a lot! Sorry that you had to spell it out. Didn't know that you need a PlatformResourceURI.
The XtextLiveScopeResourceSetProvider seems to be important (there are a few posts here asking about it), but I didn't find it when I was looking through Xtext documentation. Maybe it could be mentioned here?
Previous Topic:Model meta elements and their instances?
Next Topic:Creating multiple XText Eclipse editors for one extension
Current Time: Sat Jul 26 11:54:10 EDT 2025
Powered by FUDForum. Page generated in 0.09859 seconds
