Throw error in generator [message #1809744] |
Mon, 22 July 2019 07:01  |
Greetings everyone !
I am trying to generate code, i have to do lot of validation(just throw error) and it should be performed only just prior to generation.
I have created a class with all validation logics inside DeepValidation class
class DeepValidation extends AbstractMemDesignValidator
def init(IResourceDescriptions resDescription)
//Initializations for validation
@Check(CheckType.NORMAL)
def validation()
// Validation logics
I am invoking the above validation in my code generation logic, the function just halts at
error('Error', obj, Package.Literals.FEATURE)
neither it proceed further nor throws error. The code just halts here !
Background.
1) I have defined proper Grammer
2) I have defined validations, which was working fine.
3) I have defined generator and I was able to generate code properly as expected
Points to consider:
1) I have multiple dsl files (a.dsl, b.dsl, ...)
2) I have multiple grammers in my project ( a.dsl1, b.dsl1, .... a.dsl2, b.dsl2, ....)
My Questions:
1) What is going wrong ? Can't I throw error from generator package ? What is your suggestion ?
Ans: ....
2) I am Injecting IResourceDescriptions in my Generator class
class Generator extends AbstractGenerator implements IGenerator2
@Inject
IResourceDescriptions resourceDescription
override doGenerate(Resource input, IFileSystemAccess2 fsa, IGeneratorContext context)
var CSourceGenerator sourceCodeGenerator = new CSourceGenerator()
sourceCodeGenerator.SourceCodeGenerator(resourceDescription, fsa)
resourceDescription is loaded(with all data from all dsl files) only after a change in resource. What should I do to load data into resourceDescription immediately after the tool starts ?
Ans: ...
** I am basically from embedded domain, novice in xtext & xtend **
Mit freundlichen Grüßen / Regards
Maha
FUDForum. Page generated in 1.06247 seconds
