Home » Newcomers » Newcomers » How to install plugin manually? (SOLVED)
How to install plugin manually? (SOLVED) [message #1809677] Fri, 19 July 2019 22:15 Go to next message
Im trying to install the Floggy plugin from Marketplace, but this seems to no longer work, see gif of install error.
The developer site also provides manual download of the plugin: link (at the bottom) but I don't know how to install it properly.
When I copy the files to <Eclipse install>/plugins I do see a "Floggy -> Add Floggy nature" menu entry, but when I enable it I get the following error:
https://i.imgur.com/FZgxp3F.jpg
[Updated on: Sat, 20 July 2019 15:46] by Moderator
Re: How to install plugin manually? [message #1809697 is a reply to message #1809677] Sat, 20 July 2019 11:06 Go to previous messageGo to next message
Your Java installation is not sufficient for Eclipse use.
Eclipse needs JDK (Java Development Kit) instead of JRE (Java Runtime Environment).
Please complete your Java installation.
Re: How to install plugin manually? (SOLVED) [message #1809698 is a reply to message #1809697] Sat, 20 July 2019 11:31 Go to previous messageGo to next message
Thanks for reply.
It's configured to use JDK 1.7.0.17, still getting above error.
https://i.imgur.com/aTQtey7.jpg
[Updated on: Sat, 20 July 2019 15:42] by Moderator
Re: How to install plugin manually? (SOLVED) [message #1809699 is a reply to message #1809698] Sat, 20 July 2019 15:43 Go to previous message
Solved.
The place where I had to specify JDK instead of JRE is Preferences -> Java -> Installed JREs.
No more error now, thank you for pointing me in the right direction!
Previous Topic:Report designer giving error while opening
Next Topic: LoadLibrary("C:\\Program Files\\Java\\jdk-12.0.2\\bin\\server\\jvm.dll");
Current Time: Thu Nov 06 20:32:54 EST 2025
Powered by FUDForum. Page generated in 0.42053 seconds
