Re: Package with uri 'http:///org/eclipse/epf/uma/resourcemanager.ecore' not found [message #1809739 is a reply to message #1809726] |
Mon, 22 July 2019 05:03  |
Laurent Goubet wrote on Mon, 22 July 2019 09:33
EMF Compare requires the models to be loadable. If you don't have the necessary plugins in your environnement for the models to be opened and loaded as EMF models, then EMF Compare will not work.
Ok.
10 hours to compare is not normal, so I'll assume either the setup is wrong (models can't be completely loaded and/or the plugins aren't properly installed), or there is an issue with the maximum memory allocated to eclipse that prevent the comparison to end.
In this case the plugins are not installed at all, so they are our main suspect.
Thanks a lot for the feedback!
FUDForum. Page generated in 0.24179 seconds
