No LSP suggestions when keywords are separate parser rules [message #1809205] |
Thu, 11 July 2019 09:46  |
I'm sure this has been asked and answered before so I apologize in advance.
I created a DSL which has a repeating pattern like With Class, Expect Property. Thus, initially I defined those rules simply something like:
ClassBlock:
'With' 'Class' // ...
PropertyBlock:
modifier=('With' | 'Expect') 'Class' // ...
This works fine but multiple parser rules will contain the Expect and With keywords, so I thought it was sane to put them in their own rules:
WithModifier: 'With';
ExpectModifier: 'Expect';
ClassBlock:
WithModifier 'Class' // ...
PropertyBlock:
modifier=(WithModifier | ExpectModifier) 'Class' // ...
Unfortunately, as soon as I did that, they stop being suggested by Language Server. Why is that?
Bonus question: Why do they additionally stop being keywords when the modifier rules are changed into terminals?
Tom
Re: No LSP suggestions when keywords are separate parser rules [message #1809635 is a reply to message #1809634] |
Fri, 19 July 2019 03:31   |
ähmm no
when i change hydra to
grammar org.xtext.example.mydsl.Hydra with org.eclipse.xtext.common.Terminals
generate hydra "http://testing.hypermedia.app/dsl/hydra"
Model:
"model" name=ID;
and rerun the workflow
then i get
org.junit.ComparisonFailure: expected:<[package -> package [[0, 0] .. [0, 0]]
type -> type [[0, 0] .. [0, 0]]
Sample Snippet -> type ${1|A,B,C|} {
}] [[0, 0] .. [0, 0]]
> but was:<[With Class -> With Class] [[0, 0] .. [0, 0]]
at org.junit.Assert.assertEquals(Assert.java:115)
at org.junit.Assert.assertEquals(Assert.java:144)
at org.eclipse.xtext.testing.AbstractLanguageServerTest.assertEquals(AbstractLanguageServerTest.java:1304)
at org.eclipse.xtext.testing.AbstractLanguageServerTest.testCompletion(AbstractLanguageServerTest.java:1047)
at org.xtext.example.mydsl.tests.CompletionTest.testCompletion_01(CompletionTest.java:29)
at org.junit.platform.commons.util.ReflectionUtils.invokeMethod(ReflectionUtils.java:628)
at org.junit.jupiter.engine.execution.ExecutableInvoker.invoke(ExecutableInvoker.java:117)
at org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.lambda$invokeTestMethod$7(TestMethodTestDescriptor.java:184)
at org.junit.platform.engine.support.hierarchical.ThrowableCollector.execute(ThrowableCollector.java:73)
at org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.invokeTestMethod(TestMethodTestDescriptor.java:180)
at org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.execute(TestMethodTestDescriptor.java:127)
at org.junit.jupiter.engine.descriptor.TestMethodTestDescriptor.execute(TestMethodTestDescriptor.java:68)
at org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$5(NodeTestTask.java:135)
at org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$7(NodeTestTask.java:125)
at org.junit.platform.engine.support.hierarchical.Node.around(Node.java:135)
at org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$8(NodeTestTask.java:123)
at org.junit.platform.engine.support.hierarchical.NodeTestTask.executeRecursively(NodeTestTask.java:122)
at org.junit.platform.engine.support.hierarchical.NodeTestTask.execute(NodeTestTask.java:80)
at java.util.ArrayList.forEach(ArrayList.java:1257)
at org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService.invokeAll(SameThreadHierarchicalTestExecutorService.java:38)
at org.junit.platform.engine.support.hierarchical.NodeTestTask.lambda$executeRecursively$5(NodeTestTask.java:139)
at org.junit.platform.engine.support.hierarchical.SameThreadHierarchicalTestExecutorService.submit(SameThreadHierarchicalTestExecutorService.java:32)
at org.junit.platform.engine.support.hierarchical.HierarchicalTestExecutor.execute(HierarchicalTestExecutor.java:57)
at org.junit.platform.engine.support.hierarchical.HierarchicalTestEngine.execute(HierarchicalTestEngine.java:51)
at org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:229)
at org.junit.platform.launcher.core.DefaultLauncher.lambda$execute$6(DefaultLauncher.java:197)
at org.junit.platform.launcher.core.DefaultLauncher.withInterceptedStreams(DefaultLauncher.java:211)
at org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:191)
at org.junit.platform.launcher.core.DefaultLauncher.execute(DefaultLauncher.java:137)
at org.eclipse.jdt.internal.junit5.runner.JUnit5TestReference.run(JUnit5TestReference.java:89)
at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:41)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:541)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:763)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:463)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:209)
and not a npe
FUDForum. Page generated in 0.35813 seconds
