Home » Modeling » Papyrus » How to declare a const const-pointer?
How to declare a const const-pointer? [message #1808928] Thu, 04 July 2019 12:11 Go to next message
Hi all,
I just stumbled over the (admittedly somewhat academic) topic of how does one declare a const pointer to a (non-)const type for C/C++, i.e. something like
char const* foo;
(Again, note that here the pointer is const, but not the data pointed to.) When generating code, I always end up with
const char* foo;
regardless of the order of the <Ptr>- and <Const>-stereotypes applied.
Martin Friedrich
[Updated on: Thu, 04 July 2019 12:13] by Moderator
Re: How to declare a const const-pointer? [message #1808937 is a reply to message #1808928] Thu, 04 July 2019 13:26 Go to previous messageGo to next message
Dear Martin,
the code generator does not properly support this case - it does not take the order of the stereotype application into account. If you think that this is an important limitation, please post a bug.
A (quite ugly) is not to apply the <Const> stereotype and use the "declaration" attribute of the <Ptr> stereotype, i.e. assign the string "const*".
Ansgar
Re: How to declare a const const-pointer? [message #1809037 is a reply to message #1808937] Sat, 06 July 2019 14:20 Go to previous message
Hi Ansgar,
thanks for your fast reply and the proposed workaround. I have sent a bug report to the papyrus-bugzilla.
I wonder if a similar issue exists for the volatile or mutable stereotypes?
Bye,
Martin
Previous Topic:Papyrus 4.4 is available
Next Topic:Change the way a property is shown into Model Explorer
Current Time: Sat Jul 26 11:45:04 EDT 2025
Powered by FUDForum. Page generated in 0.04070 seconds
