Moka Statemachines - NullPointerException [message #1808664] |
Fri, 28 June 2019 07:01  |
Hey,
i try to use papyrus with moka to execute a statemachine model.
It starts and i see the highlights of the current elements but when it reaches the first state element, i get a "NullPointerException".
I tried it with the model attached in this post (and set the statemachine to active, as mention below).
I also tried it with the test cases in this github repository: git.eclipse.org/gitroot/papyrus/org.eclipse.papyrus-moka.git
but in both cases I get the same error.
I'm using Papyrus 1.0 with eclipse oxygen and Java version ojdk 1.8.0_212.
What can I do to get it work?
Thanks and greetings
Steffen
Re: Moka Statemachines - NullPointerException [message #1808901 is a reply to message #1808664] |
Thu, 04 July 2019 05:14   |
First of all, are you sure you are using a Papyrus 1.0 on an oxygen Eclipse ? This might be a source of error. Moreover, Oxygen is an old version, it should be better, if it is possible, to use a newest version.
Regarding the post you mention, did you also see the response to that post ? Since the model attach to the post is not totally correct in order to be simulated, the state machine should be an active element.
HTH,
Pauline
FUDForum. Page generated in 0.04841 seconds
