Home » Modeling » TMF (Xtext) » Cross referenced element name is getting replaced
Cross referenced element name is getting replaced [message #1808634] Fri, 28 June 2019 01:27 Go to next message
In my xtext project i am overriding qualifiedName() method from IQualifiedNameProvider.
As per my requirement i am returning element's path because if two elements have same name but present in different path xtext is not able to differentiate.
here my problem is on saving the editor, xtext is replacing the path to elemet's name, and it will give error couldn't resolve reference.
How i can avoid replacing. please any one can help.
Thanks!!
Re: Cross referenced element name is getting replaced [message #1808635 is a reply to message #1808634] Fri, 28 June 2019 01:38 Go to previous messageGo to next message
Hi, can you please give more details (grammar + model snippet) and what you mean by replacing (is it replacing caused by implicit imports like the parent name / first part of the name is the same)
Re: Cross referenced element name is getting replaced [message #1808638 is a reply to message #1808635] Fri, 28 June 2019 02:04 Go to previous messageGo to next message
Thanks for quick replay.
For example i am returning the name form qualifiedName() like this - "ElementName1 [/parentContainer1/parentContainer2/ElementName1]"
but after saving the file in editor it will display only "ElementName1".
I want to dispaly full path, how i can achieve that.
Re: Cross referenced element name is getting replaced [message #1808639 is a reply to message #1808638] Fri, 28 June 2019 02:10 Go to previous messageGo to next message
what do you mean by save? serialize?
Re: Cross referenced element name is getting replaced [message #1808641 is a reply to message #1808639] Fri, 28 June 2019 02:15 Go to previous messageGo to next message
Save means here saving the dirty xtext editor, to save the edited contents
Re: Cross referenced element name is getting replaced [message #1808642 is a reply to message #1808641] Fri, 28 June 2019 02:32 Go to previous messageGo to next message
xtext does nothing on save
=> there must be something in your code
e.g. do you have a custom IXtextEditorCallback?
Re: Cross referenced element name is getting replaced [message #1808643 is a reply to message #1808642] Fri, 28 June 2019 02:51 Go to previous messageGo to next message
Yes i have. i am extending NatureAddingEditorCallback class and overrided afterCreatePartControl(). in that method i am not implementing any thing.
Because i do not want the dialog "Convert to xtext project".
Re: Cross referenced element name is getting replaced [message #1808644 is a reply to message #1808643] Fri, 28 June 2019 02:59 Go to previous message
Yes but Xtext does nothing on save
Maybe you have something installed activated
That edits eg text files on save
Previous Topic:boolean assignment operator not working as expected
Next Topic:Hover information support in Xtext Web editor
Current Time: Thu Jul 17 05:46:20 EDT 2025
Powered by FUDForum. Page generated in 0.20718 seconds
