Home » Modeling » TMF (Xtext) » boolean assignment operator not working as expected(XText boolean assignment operator)
boolean assignment operator not working as expected [message #1808611] Thu, 27 June 2019 15:54 Go to next message
LogicalRealRangeConstraint returns logical::RealRangeConstraint /*hidden (WS)*/:
    'rrc' name=ID (description=STRING)?    ('('|lowerBoundInclusive?='[') lowerBound=REAL? ':' upperBound=REAL? (')'|upperBoundInclusive?=']')
The above rule is one of many in my XText DSL. The syntax
is meant to say that if a user specifies '[', then lowerBoundInclusive will be set to true, but if the users specifies '(' then lowerBoundInclusive will be set to false. The syntax
should do a similar thing for upperBoundInclusive.
This does not appear to work as desired. The syntax does limit the choices for lowerBoundInclusive to either '[' or '(' but lowerBoundInclusive is set to true regardless of which one is used. Similarly for upperBoundInclusive.
What is wrong here?
Re: boolean assignment operator not working as expected [message #1808612 is a reply to message #1808611] Thu, 27 June 2019 16:01 Go to previous messageGo to next message
hi, how do you test that? the following gives false to me:
class MyDslParsingTest {
	@Inject
	ParseHelper<LogicalRealRangeConstraint> parseHelper
	@Test
	def void loadModel() {
		val result = parseHelper.parse('''
			rrc x "y" (1:1)
		Assertions.assertNotNull(result)
		val errors = result.eResource.errors
		Assertions.assertTrue(errors.isEmpty, '''Unexpected errors: «errors.join(", ")»''')
		println(result.lowerBoundInclusive)
		println(result.upperBoundInclusive)
do you have a custom manual metamodel with different default values?
Re: boolean assignment operator not working as expected [message #1808613 is a reply to message #1808612] Thu, 27 June 2019 16:06 Go to previous messageGo to next message
There is a custom metamodel that I can't change (it is supplied to me). The defaults in it are true:
package face.v30.face.datamodel.logical.impl;
import face.v30.face.datamodel.logical.LogicalPackage;
import face.v30.face.datamodel.logical.RealRangeConstraint;
import java.lang.Boolean;
import org.eclipse.emf.common.notify.Notification;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.impl.ENotificationImpl;
 * <!-- begin-user-doc -->
 * An implementation of the model object '<em><b>Real Range Constraint</b></em>'.
 * <!-- end-user-doc -->
 * <p>
 * The following features are implemented:
 * </p>
 * <ul>
 *   <li>{@link face.v30.face.datamodel.logical.impl.RealRangeConstraintImpl#getLowerBound <em>Lower Bound</em>}</li>
 *   <li>{@link face.v30.face.datamodel.logical.impl.RealRangeConstraintImpl#getUpperBound <em>Upper Bound</em>}</li>
 *   <li>{@link face.v30.face.datamodel.logical.impl.RealRangeConstraintImpl#isLowerBoundInclusive <em>Lower Bound Inclusive</em>}</li>
 *   <li>{@link face.v30.face.datamodel.logical.impl.RealRangeConstraintImpl#isUpperBoundInclusive <em>Upper Bound Inclusive</em>}</li>
 * </ul>
 * @generated
public class RealRangeConstraintImpl extends RealConstraintImpl implements RealRangeConstraint {
	 * The default value of the '{@link #getLowerBound() <em>Lower Bound</em>}' attribute.
	 * @see #getLowerBound()
	 * @generated
	 * @ordered
	protected static final float LOWER_BOUND_EDEFAULT = 0.0F;
	 * The cached value of the '{@link #getLowerBound() <em>Lower Bound</em>}' attribute.
	 * @generated
	 * @ordered
	protected float lowerBound = LOWER_BOUND_EDEFAULT;
	 * The default value of the '{@link #getUpperBound() <em>Upper Bound</em>}' attribute.
	 * @see #getUpperBound()
	 * @generated
	 * @ordered
	protected static final float UPPER_BOUND_EDEFAULT = 0.0F;
	 * The cached value of the '{@link #getUpperBound() <em>Upper Bound</em>}' attribute.
	 * @generated
	 * @ordered
	protected float upperBound = UPPER_BOUND_EDEFAULT;
	 * The default value of the '{@link #isLowerBoundInclusive() <em>Lower Bound Inclusive</em>}' attribute.
	 * @see #isLowerBoundInclusive()
	 * @generated
	 * @ordered
	protected static final boolean LOWER_BOUND_INCLUSIVE_EDEFAULT = true;
	 * The cached value of the '{@link #isLowerBoundInclusive() <em>Lower Bound Inclusive</em>}' attribute.
	 * @generated
	 * @ordered
	protected boolean lowerBoundInclusive = LOWER_BOUND_INCLUSIVE_EDEFAULT;
	 * The default value of the '{@link #isUpperBoundInclusive() <em>Upper Bound Inclusive</em>}' attribute.
	 * @see #isUpperBoundInclusive()
	 * @generated
	 * @ordered
	protected static final boolean UPPER_BOUND_INCLUSIVE_EDEFAULT = true;
	 * The cached value of the '{@link #isUpperBoundInclusive() <em>Upper Bound Inclusive</em>}' attribute.
	 * @generated
	 * @ordered
	protected boolean upperBoundInclusive = UPPER_BOUND_INCLUSIVE_EDEFAULT;
	 * @generated
	protected RealRangeConstraintImpl() {
		super();
	 * @generated
	protected EClass eStaticClass() {
		return LogicalPackage.Literals.REAL_RANGE_CONSTRAINT;
	 * @generated
	public float getLowerBound() {
		return lowerBound;
	 * @generated
	public void setLowerBound(float newLowerBound) {
		float oldLowerBound = lowerBound;
		lowerBound = newLowerBound;
		if (eNotificationRequired())
			eNotify(new ENotificationImpl(this, Notification.SET, LogicalPackage.REAL_RANGE_CONSTRAINT__LOWER_BOUND, oldLowerBound, lowerBound));
	 * @generated
	public float getUpperBound() {
		return upperBound;
	 * @generated
	public void setUpperBound(float newUpperBound) {
		float oldUpperBound = upperBound;
		upperBound = newUpperBound;
			eNotify(new ENotificationImpl(this, Notification.SET, LogicalPackage.REAL_RANGE_CONSTRAINT__UPPER_BOUND, oldUpperBound, upperBound));
	 * @generated
	public boolean isLowerBoundInclusive() {
		return lowerBoundInclusive;
	 * @generated
	public void setLowerBoundInclusive(boolean newLowerBoundInclusive) {
		boolean oldLowerBoundInclusive = lowerBoundInclusive;
		lowerBoundInclusive = newLowerBoundInclusive;
			eNotify(new ENotificationImpl(this, Notification.SET, LogicalPackage.REAL_RANGE_CONSTRAINT__LOWER_BOUND_INCLUSIVE, oldLowerBoundInclusive, lowerBoundInclusive));
	 * @generated
	public boolean isUpperBoundInclusive() {
		return upperBoundInclusive;
	 * @generated
	public void setUpperBoundInclusive(boolean newUpperBoundInclusive) {
		boolean oldUpperBoundInclusive = upperBoundInclusive;
		upperBoundInclusive = newUpperBoundInclusive;
			eNotify(new ENotificationImpl(this, Notification.SET, LogicalPackage.REAL_RANGE_CONSTRAINT__UPPER_BOUND_INCLUSIVE, oldUpperBoundInclusive, upperBoundInclusive));
	 * @generated
	public Object eGet(int featureID, boolean resolve, boolean coreType) {
		switch (featureID) {
			case LogicalPackage.REAL_RANGE_CONSTRAINT__LOWER_BOUND:
				return getLowerBound();
			case LogicalPackage.REAL_RANGE_CONSTRAINT__UPPER_BOUND:
				return getUpperBound();
			case LogicalPackage.REAL_RANGE_CONSTRAINT__LOWER_BOUND_INCLUSIVE:
				return isLowerBoundInclusive();
			case LogicalPackage.REAL_RANGE_CONSTRAINT__UPPER_BOUND_INCLUSIVE:
				return isUpperBoundInclusive();
		return super.eGet(featureID, resolve, coreType);
	 * @generated
	public void eSet(int featureID, Object newValue) {
				setLowerBound((Float)newValue);
				return;
				setUpperBound((Float)newValue);
				return;
				setLowerBoundInclusive((Boolean)newValue);
				return;
				setUpperBoundInclusive((Boolean)newValue);
				return;
		super.eSet(featureID, newValue);
	 * @generated
	public void eUnset(int featureID) {
				setLowerBound(LOWER_BOUND_EDEFAULT);
				return;
				setUpperBound(UPPER_BOUND_EDEFAULT);
				return;
				setLowerBoundInclusive(LOWER_BOUND_INCLUSIVE_EDEFAULT);
				return;
				setUpperBoundInclusive(UPPER_BOUND_INCLUSIVE_EDEFAULT);
				return;
		super.eUnset(featureID);
	 * @generated
	public boolean eIsSet(int featureID) {
				return lowerBound != LOWER_BOUND_EDEFAULT;
				return upperBound != UPPER_BOUND_EDEFAULT;
				return lowerBoundInclusive != LOWER_BOUND_INCLUSIVE_EDEFAULT;
				return upperBoundInclusive != UPPER_BOUND_INCLUSIVE_EDEFAULT;
		return super.eIsSet(featureID);
	 * @generated
	public String toString() {
		if (eIsProxy()) return super.toString();
		StringBuilder result = new StringBuilder(super.toString());
		result.append(" (lowerBound: ");
		result.append(lowerBound);
		result.append(", upperBound: ");
		result.append(upperBound);
		result.append(", lowerBoundInclusive: ");
		result.append(lowerBoundInclusive);
		result.append(", upperBoundInclusive: ");
		result.append(upperBoundInclusive);
		result.append(')');
		return result.toString();
} //RealRangeConstraintImpl
Re: boolean assignment operator not working as expected [message #1808614 is a reply to message #1808613] Thu, 27 June 2019 16:09 Go to previous messageGo to next message
maybe you can use a custom DefaultEcoreElementsFactory
and do something like
public class MyDslDefaultEcoreElementFactory extends DefaultEcoreElementFactory {
public EObject create(EClassifier classifier) {
EObject created = super.create(classifier);
if (created instanceof LogicalRealRangeConstraint) {
((LogicalRealRangeConstraint)created).setLowerBoundInclusive(false);
((LogicalRealRangeConstraint)created).setUpperBoundInclusive(false);
return created;
if this has bad side effects (e.g. on serialization needs to be tested, maybe there customization is needed too)
Re: boolean assignment operator not working as expected [message #1808615 is a reply to message #1808613] Thu, 27 June 2019 16:09 Go to previous messageGo to next message
Is there some way to get the equivalent of ?= that will set a value to false if it is consumed?
Re: boolean assignment operator not working as expected [message #1808616 is a reply to message #1808615] Thu, 27 June 2019 16:10 Go to previous messageGo to next message
Thanks for your rapid response Christian. I'll add the factory change you suggest.
Re: boolean assignment operator not working as expected [message #1808617 is a reply to message #1808616] Thu, 27 June 2019 16:18 Go to previous messageGo to next message
i am not aware of a feature for that in the grammar
Re: boolean assignment operator not working as expected [message #1808619 is a reply to message #1808617] Thu, 27 June 2019 16:28 Go to previous messageGo to next message
maybe you can use a different grammar pattern + a value converter
generate myDsl "http://www.xtext.org/example/mydsl1/MyDsl"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
LogicalRealRangeConstraint /*hidden (WS)*/:
	'rrc' name=ID (description=STRING)? lowerBoundInclusive=LOWER_BOUND_INCLUSIVE
	lowerBound=INT? ':' upperBound=INT?
	upperBoundInclusive=UPPER_BOUND_INCLUSIVE;
LOWER_BOUND_INCLUSIVE returns ecore::EBoolean:
UPPER_BOUND_INCLUSIVE returns ecore::EBoolean:
package org.xtext.example.mydsl1;
import org.eclipse.xtext.common.services.DefaultTerminalConverters;
import org.eclipse.xtext.conversion.IValueConverter;
import org.eclipse.xtext.conversion.ValueConverter;
import org.eclipse.xtext.conversion.ValueConverterException;
import org.eclipse.xtext.nodemodel.INode;
public class MyDslValueConverters extends DefaultTerminalConverters {
	@ValueConverter(rule = "LOWER_BOUND_INCLUSIVE")
	public IValueConverter<Boolean> LOWER_BOUND_INCLUSIVE() {
		return new IValueConverter<Boolean>() {
			public Boolean toValue(String string, INode node) throws ValueConverterException {
				return "[".equals(string);
			public String toString(Boolean value) throws ValueConverterException {
				if (Boolean.TRUE.equals(value)) {
					return "[";
				return "(";
	@ValueConverter(rule = "UPPER_BOUND_INCLUSIVE")
	public IValueConverter<Boolean> UPPER_BOUND_INCLUSIVE() {
				return "]".equals(string);
					return "]";
				return ")";
Re: boolean assignment operator not working as expected [message #1808621 is a reply to message #1808619] Thu, 27 June 2019 16:58 Go to previous messageGo to next message
The first approach (the derived DefaultEcoreElementFactory) works and does not appear to cause problems with serialization. I haven't had time to try the second approach yet.
Thanks again!
Re: boolean assignment operator not working as expected [message #1808632 is a reply to message #1808621] Fri, 28 June 2019 01:25 Go to previous messageGo to next message
I've hit this problem too when I've tried to use a default-true Boolean literal with Xtext. I've had the flexibility to change the metamodel / model reader to workaround the problem. Your less flexible case makes clear that this is arguably an Xtext bug....
An unsettable EMF Boolean has three values internally, true, false, unset. The unset value is only detectable by using eIsSet().
Once a default is supplied, the external view of the Boolean is explicitly-true, explicitly-false, implicitly-default.
The Xtext grammar supports only two values. explicitly-true, implicitly-default.
With a false default, the Xtext grammar gives explicitly-true, implicitly-false which is useable.
With a true default, the Xtext grammar gives explicitly-true, implicitly-true which is not useable.
Therefore the Xtext parser should replace true assignments to Booleans that are default true, with false assignments on all alternative control paths. Or Xtext should support three values ?= for explicitly true, ~= for explicitly false, nothing for default.
(The problem just gets worse if the EMF Boolean is not-unsettable removing the internally unset value).
Ed Willink
Re: boolean assignment operator not working as expected [message #1808633 is a reply to message #1808632] Fri, 28 June 2019 01:27 Go to previous message
@Ed issue + PR welcome
Previous Topic:Reorder a model via formatter2 or validation and quick fix
Next Topic:Cross referenced element name is getting replaced
Current Time: Mon May 12 15:35:29 EDT 2025
Powered by FUDForum. Page generated in 0.04639 seconds
