Re: Eclipse Installer error [message #1808536 is a reply to message #1808512] |
Wed, 26 June 2019 08:18   |
I wasn't able to get the installer menu to run at all, it would fail after downloading the eclipse.exe file. Downloading the .zip has seemed to work though. When I open it, it asks to select a directory as a workspace, is this correct?
I was able to grab the .log from the temporary file. It is pasted below, as well as attached on here.
(osgi.native.osname~=linux)(osgi.native.processor~=ppc64le))(&(osgi.native.osname~=linux)(osgi.native.processor~=x86))(&(osgi.native.osname~=linux)(osgi.native.processor~=x86-64))(&(osgi.native.osname~=linux)(osgi.native.processor~=arm))(&(osgi.native.osname~=linux)(osgi.native.processor~=armel))(&(osgi.native.osname~=linux)(osgi.native.processor~=aarch64))(&(osgi.native.osname~=linux)(osgi.native.processor~=ia64))(&(osgi.native.osname~=linux)(osgi.native.processor~=sparcv9))(&(osgi.native.osname~=linux)(osgi.native.processor~=mips64el))(&(osgi.native.osname~=linux)(osgi.native.processor~=S390x))(&(osgi.native.osname~=freebsd)(osgi.native.processor~=x86))(&(osgi.native.osname~=freebsd)(osgi.native.processor~=x86-64))(&(osgi.native.osname~=openbsd)(osgi.native.processor~=x86))(&(osgi.native.osname~=openbsd)(osgi.native.processor~=x86-64))(&(osgi.native.osname~=macosx)(|(osgi.native.processor~=x86)(osgi.native.processor~=x86-64)(osgi.native.processor~=ppc))))"
NLS missing message: ModuleResolutionReport_UnresolvedReq in: org.eclipse.osgi.internal.messages.ExternalMessagesImport-Package: com.sun.jna.platform.win32; version="[4.1.0,5.0.0)"
-> Export-Package: com.sun.jna.platform.win32; bundle-symbolic-name="com.sun.jna.platform"; bundle-version="4.5.1.v20180403-1933"; version="4.5.1"; uses:="com.sun.jna,com.sun.jna.platform,com.sun.jna.platform.win32.COM,com.sun.jna.ptr,com.sun.jna.win32"
com.sun.jna.platform [6]
NLS missing message: ModuleResolutionReport_UnresolvedReq in: org.eclipse.osgi.internal.messages.ExternalMessagesImport-Package: com.sun.jna; version="[4.5.1,4.6.0)"
-> Export-Package: com.sun.jna; bundle-symbolic-name="com.sun.jna"; bundle-version="4.5.1.v20180403-1933"; version="4.5.1"
NLS missing message: ModuleResolutionReport_UnresolvedReq in: org.eclipse.osgi.internal.messages.ExternalMessagesImport-Package: com.sun.jna.ptr; version="[4.5.1,4.6.0)"
-> Export-Package: com.sun.jna.ptr; bundle-symbolic-name="com.sun.jna"; bundle-version="4.5.1.v20180403-1933"; version="4.5.1"; uses:="com.sun.jna"
at org.eclipse.osgi.container.Module.start(Module.java:457)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$1.run(ModuleContainer.java:1820)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$2$1.execute(EquinoxContainerAdaptor.java:150)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1813)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1769)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1735)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1661)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
!ENTRY org.eclipse.oomph.setup.installer 4 0 2019-06-25 15:58:26.169
!MESSAGE Could not initialize class org.eclipse.oomph.jreinfo.JREManager
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.oomph.jreinfo.JREManager
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.createContent(SimpleVariablePage.java:344)
at org.eclipse.oomph.setup.internal.installer.SimpleInstallerPage.<init>(SimpleInstallerPage.java:91)
at org.eclipse.oomph.setup.internal.installer.SimpleVariablePage.<init>(SimpleVariablePage.java:267)
at org.eclipse.oomph.setup.internal.installer.SimpleInstallerDialog.createUI(SimpleInstallerDialog.java:254)
at org.eclipse.oomph.setup.internal.installer.AbstractSimpleDialog.show(AbstractSimpleDialog.java:139)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.run(InstallerApplication.java:250)
at org.eclipse.oomph.setup.internal.installer.InstallerApplication.start(InstallerApplication.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:567)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:660)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597)
at org.eclipse.equinox.launcher.Main.run(Main.java:1468)
Re: Eclipse Installer error [message #1808572 is a reply to message #1808536] |
Wed, 26 June 2019 22:45  |
It's all very mysterious. It looks like the OSGi framework is failing to load JNI (Java Native Interface). E.g., even eclipse.ecf.provider.filetransfer.httpclient45.win32 appears to have failures starting/loading. The JREManager uses JREInfo which has a JNI fragment for reading the system registry (to find all your Java installations), and that appears to not work either. But I tried installing JDK 12.0.1 on my machine and am able to run the installer with that version of Java and no log file is produced, so there doesn't appear to be anything problematic about that JDK implementation in and of itself.
If downloading the zip works, then yes, it will first prompt for a workspace directory before launching. I fear though that once launched it's likely to fail the same way as the installer (because the installer is just an Eclipse application), but if that works, then at least you can get started an avoid this problem because I'm at a loss for what else to suggest (other than specifying the -vm argument to use a different JDK)...
FUDForum. Page generated in 0.08448 seconds
