Home » Modeling » TMF (Xtext) » Graphical view for Xtext(How to generate diagram from Xtext DSL?)
Graphical view for Xtext [message #1724858] Fri, 26 February 2016 10:13 Go to next message
I am developing DSL using Xtext and i am hoping to be able to generate graphical diagram/view based on my DSL code. (I do not want a graphical editor). However, the graphical view is not describing the AST itself instead it is based on some custom diagramming and layout algorithm.
MY DSL example code will looks like this:
create_domain domain1 {
     element: u1
create_domain domain2 {
    element: u1/u11
create_domain domain3{
   element: u1/u12
And my desired graphical view would looks like this:
http://i.imgur.com/1rTv9nw.png
From my code, "create_domain" will create a rectangle shape (it can be any custom shape, doesn't have to be rectangle) with its name above it. The hierarchy is based on the "element" defined for each domain. The "/" sign indicates the child of a parent domain. Thus, u11 and u12 is the child of u1 which is shown in the diagram above.
My problem now is that i do not know which kind of graphical framework or tools should i go for to achieve something like this as well as integrating with Xtext. I had been looking into Graphitti, GMF, JavaFx, Kieler and etc but i am still lost. So, I am hoping to get some guidance on what kind of approach or direction should i proceed.
I would really really appreciate for any guidance that is given to me considering i am still a newbie in this field. Thanks in advance.
Hanli
Re: Graphical view for Xtext [message #1724859 is a reply to message #1724858] Fri, 26 February 2016 10:26 Go to previous messageGo to next message
Hi i Found Fxdiagram quite handy for such a task. And of corse it uses
JavaFX and Kieler
https://github.com/JanKoehnlein/FXDiagram
[Updated on: Fri, 26 February 2016 10:31] by Moderator
Re: Graphical view for Xtext [message #1725019 is a reply to message #1724859] Mon, 29 February 2016 02:50 Go to previous messageGo to next message
Congratulations you don't want a graphical editor. The latter would be pretty tedious to synchronize.
FXDiagram is a good fit, especially when you want the diagram to be shown in the same Eclipse workbench as the model.
For your case it boils down to creating and registering a diagram configuration with a node mapping, a label mapping and a connection mapping. More documentation on FXDiagram can be found here. Or feel free to ask specific questions on this thread.
The dumbest solution if the above is too complicated would be to generate a Graphviz dot file. This is fine for documenting but not integrated in the workbench.
Re: Graphical view for Xtext [message #1726417 is a reply to message #1725019] Sun, 13 March 2016 06:38 Go to previous messageGo to next message
Hi Jan Koehnlein,
This may a dumb question but may i know how to or where to customize all the configuration needed to develop my own diagrams?
I installed everything properly but it seems now i can only use the FXdiagram and play around on the examples given. Am i missing something?
Hanli Smile
Re: Graphical view for Xtext [message #1726617 is a reply to message #1725019] Tue, 15 March 2016 03:06 Go to previous messageGo to next message
Another question, how do i use my own custom Xtext language together with the diagram configuration?
Han Li Smile
Re: Graphical view for Xtext [message #1726712 is a reply to message #1726617] Tue, 15 March 2016 17:23 Go to previous messageGo to next message
You have to implement your own mapping. See http://jankoehnlein.github.io/FXDiagram/hla.html
You can also have a look at the examples to get a deeper understanding, e.g.
https://github.com/JanKoehnlein/FXDiagram/blob/master/de.fxdiagram.xtext.domainmodel/src/de/fxdiagram/xtext/domainmodel/DomainmodelDiagramConfig.xtend
or
https://github.com/JanKoehnlein/FXDiagram/blob/master/de.fxdiagram.xtext.fowlerdsl/src/de/fxdiagram/xtext/fowlerdsl/StatemachineDiagramConfig.xtend
Re: Graphical view for Xtext [message #1808265 is a reply to message #1726712] Thu, 20 June 2019 14:53 Go to previous messageGo to next message
Hi Hanli,
Do you find the solution for visualizing DSL code? I try to solve the same problem and I need some help.
Re: Graphical view for Xtext [message #1808281 is a reply to message #1808265] Fri, 21 June 2019 01:36 Go to previous message
Hi Layan,
you can convert your Xtext DSL into a Graphviz *.dot file and use the Eclipse GEF DOT Plugin to visualize the *.dot file on the Eclipse Workbench UI.
Some examples how to achieve that are available under:
- blog post: Eclipse GEF DOT Graphical Views on Xtext DSLs
- recorded talk on the EclipseCon Europe 2018: Eclipse GEF DOT Graphviz Authoring Environment in Eclipse
Tamas
Previous Topic:Classes responsible for Syntax Coloring
Next Topic:Saving AST of xText runtime model as an ecore model
Current Time: Sun Jul 20 21:46:37 EDT 2025
Powered by FUDForum. Page generated in 0.05519 seconds
