Home » Modeling » M2T (model-to-text transformation) » [Acceleo] For loop generate extra white line iterating on Set<Association>
[Acceleo] For loop generate extra white line iterating on Set<Association> [message #1807722] Thu, 06 June 2019 12:17 Go to next message
i have a really strange problem on my generated code. If i use the following function directly in mtl file with [file] tag i have no problem while if i use it in a template and i call it in [file] mtl i get this strange behavior.
Acceleo add a white line on each code line. I have tried with separator, trim but nothing changed.
Can you please help me?
Function:
[template public genChildGetterSetter(aClass : Class)]
[for(a : Association | aClass.getChildAssociations())]
 * @return the [aClass.getChildClass(a).name.toUpperFirst()/]
public Collection<[aClass.getChildClass(a).name/]> get[aClass.getTheChildPropertyName(a).toUpperFirst()/](){
	return [aClass.getTheChildPropertyName(a)/];
[/for]
[/template]
GetChildAssociations():
[query public getChildAssociations(arg0 : Class) : Set(Association)
	= invoke('it.mice.acceleogenerator.javaservice.AssociationJavaUtils', 'getChildAssociations(org.eclipse.uml2.uml.Class)', Sequence{arg0})
Result:
 * @return the ProdottoPerOrdine
public Collection<ProdottoPerOrdine> getTheProdottoPerOrdine(){
	return theProdottoPerOrdine;
Expected:
Re: [Acceleo] For loop generate extra white line iterating on Set<Association> [message #1807762 is a reply to message #1807722] Fri, 07 June 2019 12:28 Go to previous messageGo to next message
My recollection is that getting whitespace exactly right from non-trivial control structures is difficult if not impossible even if very long lines are used. IIRC the Acceleo documentation used to recommend a separate prettifying phase if you have very strong layout requirements.
Ed Willink
Re: [Acceleo] For loop generate extra white line iterating on Set<Association> [message #1807808 is a reply to message #1807762] Mon, 10 June 2019 04:17 Go to previous messageGo to next message
Thank you for the answer but my question is opposite, i don't want that white lines. I really cannot understand why they are generated. Is it an acceleo's bug?
Re: [Acceleo] For loop generate extra white line iterating on Set<Association> [message #1807813 is a reply to message #1807808] Mon, 10 June 2019 05:32 Go to previous message
IMHO, anything that makes a tool unduly painful to use is an ergonomic bug, so yes it is at least an ergonomic bug.
The Acceleo documentation has extensive descriptions on when whitespace is generated, so you might be able to pin down which description is inconsistent with its implementation. If this identifies a simple bug it might be fixed; Acceleo is being maintained but not actively developed.
More realistically, you might abandon attempts to contort your Acceleo source code layout to get the whitespace right and instead generate many gratuitous new lines and then put the output through a very simple blank line filter. Where you really want a blank line you could arrange to mark it so that your blank filter converts it to a clean blank line.
Ed Willink
Previous Topic:M2T Ecore2XML / Ecore2JSON Tutorial/Guide/Help
Next Topic:Runner : Acceleo Plug-in Applications
Current Time: Sun Nov 09 06:38:35 EST 2025
Powered by FUDForum. Page generated in 0.03412 seconds
