Home » Eclipse Projects » WindowBuilder » Preference page initialize error(Formlayout preference page fails)
Preference page initialize error [message #1807784] Sun, 09 June 2019 06:53 Go to next message
When you click on Window->Preferences->WindowBuilder->SWT->Layout->FormLayout I get an error.
This error has been happening to me for years now and with many different version of eclipse and windowbuilder.
The last version that works for me is the Mars.2 version.
Can someone correct or tell how to fix this?
!ENTRY org.eclipse.equinox.registry 4 1 2019-05-03 12:00:07.291
!MESSAGE Unable to create the selected preference page.
!STACK 0
java.lang.ExceptionInInitializerError
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:206)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:934)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:246)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:63)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:284)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceNode.createPage(WorkbenchPreferenceNode.java:51)
at org.eclipse.jface.preference.PreferenceDialog.createPage(PreferenceDialog.java:1279)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.createPage(FilteredPreferenceDialog.java:361)
at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1166)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(FilteredPreferenceDialog.java:675)
at org.eclipse.jface.preference.PreferenceDialog$5.lambda$0(PreferenceDialog.java:660)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:72)
at org.eclipse.jface.preference.PreferenceDialog$5.selectionChanged(PreferenceDialog.java:657)
at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:874)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.ui.internal.JFaceUtil.lambda$0(JFaceUtil.java:47)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:176)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:871)
at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1240)
at org.eclipse.jface.viewers.StructuredViewer.lambda$0(StructuredViewer.java:1263)
at org.eclipse.swt.events.SelectionListener$1.widgetSelected(SelectionListener.java:84)
at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:265)
at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:260)
at org.eclipse.jface.util.OpenStrategy$1.lambda$1(OpenStrategy.java:430)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:40)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:185)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3919)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3550)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:823)
at org.eclipse.jface.window.Window.open(Window.java:799)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.open(WorkbenchPreferenceDialog.java:214)
at org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPreferencesAction.java:66)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:474)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:568)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4131)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1055)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3944)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3547)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1173)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:566)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:661)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597)
at org.eclipse.equinox.launcher.Main.run(Main.java:1476)
at org.eclipse.wb.internal.rcp.preferences.layout.FormLayoutPreferencePage.<clinit>(FormLayoutPreferencePage.java:67)
... 65 more
!ENTRY org.eclipse.equinox.registry 4 1 2019-05-03 12:00:40.074
!STACK 0
java.lang.NoClassDefFoundError: Could not initialize class org.eclipse.wb.internal.rcp.preferences.layout.FormLayoutPreferencePage
at org.eclipse.jface.viewers.StructuredViewer.setSelection(StructuredViewer.java:1719)
at org.eclipse.jface.viewers.TreeViewer.setSelection(TreeViewer.java:1084)
at org.eclipse.jface.preference.PreferenceDialog.selectSavedItem(PreferenceDialog.java:990)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.selectSavedItem(FilteredPreferenceDialog.java:727)
at org.eclipse.jface.preference.PreferenceDialog.lambda$0(PreferenceDialog.java:350)
at org.eclipse.jface.preference.PreferenceDialog.createContents(PreferenceDialog.java:347)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1099)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.createDialogOn(WorkbenchPreferenceDialog.java:105)
at org.eclipse.ui.dialogs.PreferencesUtil.createPreferenceDialogOn(PreferencesUtil.java:195)
at org.eclipse.ui.dialogs.PreferencesUtil.createPreferenceDialogOn(PreferencesUtil.java:119)
at org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPreferencesAction.java:65)
Re: Preference page initialize error [message #1807811 is a reply to message #1807784] Mon, 10 June 2019 04:51 Go to previous message
I have opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=548095 , please follow there.
It should be easy to fix, I will take a look
[Updated on: Mon, 10 June 2019 04:53] by Moderator
Previous Topic:ContenPane smaller than JFrame
Next Topic:Update To 1.9.2
Current Time: Fri Jun 06 22:31:02 EDT 2025
Powered by FUDForum. Page generated in 0.03149 seconds
