Cannot open git-receive-pack when pushing with egit, git-upload-pack when pulling [message #1807570] |
Mon, 03 June 2019 15:40  |
Hi everyone,
I'm trying to push and pull to a Github repo using Egit 4.11 (stuck on an IBM-branded version of Luna, this is the version I could get to install without issues) and am having trouble with Git push where I get an error saying it cannot open git-receive-pack:
Can't connect to any repository: https://github.*************.git (https://github.*************.git: cannot open git-receive-pack)
Looking at the error log, I get the following messages:
An exception occurred during push on URI https://github.*************.git:
org.eclipse.jgit.api.errors.TransportException: https://github.*************.git: cannot open git-receive-pack
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:180)
at org.eclipse.egit.core.op.PushOperation.run(PushOperation.java:215)
at org.eclipse.egit.ui.internal.push.PushJob.performJob(PushJob.java:84)
at org.eclipse.egit.ui.internal.jobs.RepositoryJob.run(RepositoryJob.java:57)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.jgit.errors.TransportException: https://github.*************.git: cannot open git-receive-pack
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:584)
at org.eclipse.jgit.transport.TransportHttp.openPush(TransportHttp.java:435)
at org.eclipse.jgit.transport.PushProcess.execute(PushProcess.java:160)
at org.eclipse.jgit.transport.Transport.push(Transport.java:1344)
at org.eclipse.jgit.api.PushCommand.call(PushCommand.java:169)
... 4 more
Caused by: javax.net.ssl.SSLException: Received fatal alert: protocol_version
at com.ibm.jsse2.k.a(k.java:25)
at com.ibm.jsse2.k.a(k.java:3)
at com.ibm.jsse2.at.b(at.java:49)
at com.ibm.jsse2.at.a(at.java:573)
at com.ibm.jsse2.at.i(at.java:73)
at com.ibm.jsse2.at.a(at.java:357)
at com.ibm.jsse2.at.startHandshake(at.java:723)
at com.ibm.net.ssl.www2.protocol.https.c.afterConnect(c.java:215)
at com.ibm.net.ssl.www2.protocol.https.d.connect(d.java:34)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1561)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1489)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:491)
at com.ibm.net.ssl.www2.protocol.https.b.getResponseCode(b.java:80)
at org.eclipse.jgit.transport.http.JDKHttpConnection.getResponseCode(JDKHttpConnection.java:108)
at org.eclipse.jgit.util.HttpSupport.response(HttpSupport.java:205)
at org.eclipse.jgit.transport.TransportHttp.connect(TransportHttp.java:498)
... 8 more
There's another entry from the same time, but just says the exception stack trace is not available.
When I try to do a pull, I get this:
https://github.*************.git: cannot open git-upload-pack
org.eclipse.jgit.api.errors.TransportException: https://github.*************.git: cannot open git-upload-pack
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:252)
at org.eclipse.jgit.api.PullCommand.call(PullCommand.java:290)
at org.eclipse.egit.core.op.PullOperation$1.run(PullOperation.java:200)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2313)
at org.eclipse.egit.core.op.PullOperation.execute(PullOperation.java:232)
at org.eclipse.egit.ui.internal.pull.PullOperationUI.execute(PullOperationUI.java:176)
at org.eclipse.egit.ui.internal.pull.PullOperationUI.access$0(PullOperationUI.java:168)
at org.eclipse.egit.ui.internal.pull.PullOperationUI$1.runInWorkspace(PullOperationUI.java:141)
at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
Caused by: org.eclipse.jgit.errors.TransportException: https://github.*************.git: cannot open git-upload-pack
at org.eclipse.jgit.transport.TransportHttp.openFetch(TransportHttp.java:345)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:137)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:123)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1269)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:241)
... 9 more
... 14 more
It seems like the protocol_version error is commonly fixed by adding -Dhttps.protocols=TLSv1.1,TLSv1.2 to eclipse.ini. When I do that, I get prompted for a username/password. Unfortunately, we use smart cards for authentication, so I don't think I can do it that way!
I also changed http.sslVerify to false, but that didn't seem to change anything at all.
Any ideas?
FUDForum. Page generated in 0.05916 seconds
