Home » Newcomers » Newcomers » Update of the Eclipse founder's edition not possible
Update of the Eclipse founder's edition not possible [message #1807528] Sat, 01 June 2019 09:53 Go to next message
hello guys,
I am very new to eclipse under linux und for a reason I don't understand I cannot update eclipse (original version)
Please see the attached screenshot for details:
An error occurred while collecting items to be installed
session context was:(profile=_home_benjamin.brammer_eclipse_cpp-2019-032_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.core,1.7.6.v20190415-1216
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.help.ui,1.7.6.v20190415-1216
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.ui,1.7.6.v20190416-1746
No repository found containing: osgi.bundle,org.eclipse.epp.mpc.ui.css,1.7.6.v20190415-1216
No repository found containing: org.eclipse.update.feature,org.eclipse.epp.mpc,1.7.6.v20190416-1746
Re: Update of the Eclipse founder's edition not possible [message #1807529 is a reply to message #1807528] Sat, 01 June 2019 10:04 Go to previous messageGo to next message
How was this originally installed?
Re: Update of the Eclipse founder's edition not possible [message #1807531 is a reply to message #1807529] Sat, 01 June 2019 13:54 Go to previous messageGo to next message
The folder name suggests this was created with the installer. The failure suggests that one of your enabled update sites is pointing at something newer than the 2019-03 version. What update sites are listed (and enabled/check-marked) under Window -> Preferences -> Install/Update -> Available Software Sites? What specifically are you trying to update?
Re: Update of the Eclipse founder's edition not possible [message #1807538 is a reply to message #1807529] Sun, 02 June 2019 12:03 Go to previous messageGo to next message
index.php/fa/35667/0/Hello!
I did not try to update anything on my own. Eclipse just reminded me of new available updates. Please find attached a screenshot of my Available software sites tab:
Re: Update of the Eclipse founder's edition not possible [message #1807540 is a reply to message #1807538] Sun, 02 June 2019 13:29 Go to previous messageGo to next message
Trying unchecking the marketplace client site.
Re: Update of the Eclipse founder's edition not possible [message #1807560 is a reply to message #1807540] Mon, 03 June 2019 08:14 Go to previous messageGo to next message
Hey Ed Merks,
it did work :) but why is that the case?
Re: Update of the Eclipse founder's edition not possible [message #1807563 is a reply to message #1807560] Mon, 03 June 2019 11:01 Go to previous messageGo to next message
I don't think the market place client should really be putting it's update site in the list with a site that has updates newer than the release itself. I suspect there's something bogus about their update site or that it has dependencies that can't be installed into the older release. E.g., it would be bogus if the market place client has dependencies on newer bundles and it doesn't also make those bundles available in its update site; it sounds like this is the case, but I'm not really sure.
Re: Update of the Eclipse founder's edition not possible [message #1807703 is a reply to message #1807563] Thu, 06 June 2019 08:59 Go to previous message
Ok,
thanks for your answers and the help :)
Previous Topic:Running Junit suite with Junit5 version in eclipse oxygen, throwing, "No Junit5 runner found er
Next Topic:Stream.map(...).reduce() as string joiner: error "left-hand side"
Current Time: Mon Jul 21 01:09:25 EDT 2025
Powered by FUDForum. Page generated in 0.10342 seconds
