Home » Eclipse Projects » RCP Testing Tool » Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1
Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1 [message #1806154] Fri, 03 May 2019 16:45 Go to next message
When I try to run a test written with RCPTT 2.3 using RCPTT 2.4.1 the test fails with the following error:
Failed to execute org.eclipse.rcptt.core.ecl.core.model.impl.EnterContextImpl@775168bb (host: null)
Execution has timed out after 180.0 seconds
org.eclipse.core.runtime.CoreException: Execution has timed out after 180.0 seconds
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch$TimeoutInterruption.checkInterruption(BaseAutLaunch.java:245)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.computeInNewSession(BaseAutLaunch.java:277)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.internalExecute(BaseAutLaunch.java:931)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.execContext(BaseAutLaunch.java:601)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.execElement(BaseAutLaunch.java:584)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.run(BaseAutLaunch.java:560)
at org.eclipse.rcptt.internal.launching.ecl.EclContextExecutable.doExecuteContext(EclContextExecutable.java:45)
at org.eclipse.rcptt.internal.launching.ecl.EclContextExecutable.doExecute(EclContextExecutable.java:78)
at org.eclipse.rcptt.internal.launching.DataExecutable.execute(DataExecutable.java:98)
at org.eclipse.rcptt.internal.launching.Executable.executeAndRememberResult(Executable.java:127)
at org.eclipse.rcptt.internal.launching.Executable.executeAndRememberResult(Executable.java:138)
at org.eclipse.rcptt.internal.launching.Q7LaunchManager$SessionRunnable.run(Q7LaunchManager.java:147)
at org.eclipse.rcptt.internal.launching.Q7LaunchManager$ExecThread$1.run(Q7LaunchManager.java:723)
at java.base/java.lang.Thread.run(Unknown Source)
Caused by: java.util.concurrent.TimeoutException
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.createTimeoutStatus(BaseAutLaunch.java:298)
at org.eclipse.rcptt.internal.launching.aut.BaseAutLaunch.access$1(BaseAutLaunch.java:296)
... 14 more
In the Error log I see:
!ENTRY org.eclipse.rcptt.tesla.ecl.impl 4 123130 2019-05-03 16:09:33.790
!MESSAGE Timeout during execution of org.eclipse.rcptt.ctx.resources.WorkspaceContextProcessor$2@32086cb3
!STACK 0
java.lang.RuntimeException
at org.eclipse.rcptt.tesla.ecl.impl.UIRunnable.exec(UIRunnable.java:151)
at org.eclipse.rcptt.ctx.resources.WorkspaceContextProcessor.apply(WorkspaceContextProcessor.java:97)
at org.eclipse.rcptt.core.ContextTypeManager.apply(ContextTypeManager.java:101)
at org.eclipse.rcptt.core.internal.ecl.core.commands.EnterContextService$1.run(EnterContextService.java:45)
at org.eclipse.rcptt.core.internal.ecl.core.Utils.reportExecution(Utils.java:33)
at org.eclipse.rcptt.core.internal.ecl.core.commands.EnterContextService.service(EnterContextService.java:48)
at org.eclipse.rcptt.ecl.internal.core.AbstractSession.internalDoExecute(AbstractSession.java:83)
at org.eclipse.rcptt.ecl.internal.core.Session$1.run(Session.java:48)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:60)
Do you know what may cause this and how to fix it so older tests can run on RCPTT 2.4.1? If I run the test on RCPTT 2.3 I do not get this issue. I will note that our AUT runs on Photon.
[Updated on: Wed, 08 May 2019 14:13] by Moderator
Re: Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1 [message #1807195 is a reply to message #1806154] Fri, 24 May 2019 09:15 Go to previous messageGo to next message
What is the version of eclipse your application is based on? Try to update org.eclipse.rcptt.launching.ext.q7runtime to the version your working on. If you're using 2019-03 change the version to [3.5, 4.11)
Re: Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1 [message #1807477 is a reply to message #1807195] Thu, 30 May 2019 15:50 Go to previous messageGo to next message
Our application is based on older version of Eclipse (Photon) not 2019-03.
Thanks for your input on this
Re: Unable to run test written with RCPTT 2.3 using RCPTT 2.4.1 [message #1821376 is a reply to message #1807477] Wed, 12 February 2020 02:17 Go to previous message
I am getting same error. Runner is 2.4.3, version of AUT ist 2019-09.
Same happens with runner 2.5.0, or nightly.
When I run tests from RCPTT IDE 2.4.2 it is ok. But runner 2.4.2 is not working because of unrecognized target platform.
Previous Topic:Cannot Update AUT using maven runner (injection/test case with update)
Next Topic:Failed to execute org.eclipse.rcptt.core.ecl.core.model.impl.EnterContextImpl
Current Time: Sun Aug 31 01:43:32 EDT 2025
Powered by FUDForum. Page generated in 0.05761 seconds
