Home » Eclipse Projects » 4DIAC - Framework for Distributed Industrial Automation and Control » Time to real conversion in FORTE 10
Time to real conversion in FORTE 10 [message #1807439] Thu, 30 May 2019 03:43 Go to next message
I want to do mathematical operations in the form of integrals and derivations, so I need to block the conversion of data time types to real. How do you convert this data type to FORTE 10?
Re: Time to real conversion in FORTE 10 [message #1807448 is a reply to message #1807439] Thu, 30 May 2019 06:53 Go to previous messageGo to next message
IEC 61131-3 does not define such functions. From the current definitions in IEC 6113-3 it would also be rather hard to define such functions. What should be the the according time value of your 1.0 REAL value? Given the current definitions I would recommend that you give also the time values directly in REAL.
Alois
Re: Time to real conversion in FORTE 10 [message #1807450 is a reply to message #1807448] Thu, 30 May 2019 07:34 Go to previous messageGo to next message
I can run this code in FORTE 8, but I can't run this code in FORTE 10. How can I run that line of code in FORTE 10?
t_now := TIME_TO_REAL(TIME());
[Updated on: Thu, 30 May 2019 07:37] by Moderator
Re: Time to real conversion in FORTE 10 [message #1807463 is a reply to message #1807450] Thu, 30 May 2019 11:12 Go to previous messageGo to next message
Thanks for the use case.
First of all, please accept our apology that we provided means like the one you mentioned. After reviewing IEC 61131-3 this is wrong on many ways.
First of all the TIME data type should be used for time duration. TIME can never hold a value of now. For this any of the DATE, DATE_AND_TIME, or TIME_OF_DAY data types should be used.
Therefore I think we should clean-up 4diac here and also remove the TIME() function and replace it with something like NOW. However I'm not sure if the return value should be DATE_AND_TIME or TIME_OF_DAY.
Based on that There are functions for subtracting values of these date types to get TIME and for TIME introduce new functions: TIME_TO_REAL_S, TIME_TO_REAL_MS, TIME_TO_REAL_US, TIME_TO_REAL_NS. So that it is clear what the resulting value would be.
What do you think?
Alois
P.S.: May I ask why are you needing the real time in your algorithm? Currently I would mostly need it only for time_stamping and measuring things. But I don't think this is your intention.
Re: Time to real conversion in FORTE 10 [message #1807480 is a reply to message #1807463] Thu, 30 May 2019 16:08 Go to previous messageGo to next message
I want to do integral calculations
##Internal Variabel
t_now,t_last,Error_Old,Ki_in,dtOut_in (All in REAL data type)
##Variables in the FBT interface
Error(REAL), Reset(BOOL), Out(REAL)
dt := t_now - t_last;
t_last := t_now;
IF Reset THEN
	Out := 0;
	Out_in := 0;
ELSE
	Out_in := (Error + Error_Old)*0.5*dt + Out_in;
	Error_Old := Error;
   	Out := Out_in*Ki_in;
END_IF;
This code runs on FORTE 8 but does not work on FORTE 10.
Are there alternative ways to do integral calculations on FORTE 10?
[Updated on: Thu, 30 May 2019 16:12] by Moderator
Re: Time to real conversion in FORTE 10 [message #1807484 is a reply to message #1807480] Thu, 30 May 2019 18:03 Go to previous messageGo to next message
Are you invoking the FB in an E_CYCLE chain? If yes then it is a better option to specify the dt as input parameter. This has the advantage that you can also easily speed up your calculations.
Futhermore the if Reset would be better as state and event. This results in much better readable code.
Alois
Re: Time to real conversion in FORTE 10 [message #1807508 is a reply to message #1807484] Fri, 31 May 2019 08:22 Go to previous messageGo to next message
Hi all,
I support Alois here, the IEC 61131 says that TIME is only for duration, so NOW does not make any sense for this.
I like the name NOW, and it should return DATE_AND_TIME, as it is explicitly castable into DATE and TIME_OF_DAY, which would cover all data type holding times.
In principle I think such functions are needed but providing them with this kind of names would mean that there would be a lot of them as we would have to provide them for a variaty of type.
How about leaning even a little more to the CAST function of IEC 61131 and naming them TIME_IN_[S/MS/US/NS]_TO , so we could provide a *-cast version which types itself to the correct type?
Best,
Martin
Re: Time to real conversion in FORTE 10 [message #1807510 is a reply to message #1807508] Fri, 31 May 2019 09:46 Go to previous messageGo to next message
Martin Melik-Merkumians wrote on Fri, 31 May 2019 12:22
Thanks for pointing that out.
I like the naming for TIME_IN_[]_TO_xxx. Maybe we should start with a view concrete ones before doing the generic version.
Can you please submit bug reports for your suggestions?
Alois
Re: Time to real conversion in FORTE 10 [message #1807512 is a reply to message #1807510] Fri, 31 May 2019 11:00 Go to previous messageGo to next message
Sure, I try to enter the reports this evening.
Re: Time to real conversion in FORTE 10 [message #1807527 is a reply to message #1807512] Sat, 01 June 2019 08:47 Go to previous message
Thank you...
Previous Topic:How to create *.sys file with 4DAIC IDE v1.10.2
Next Topic:Group box "Create Connection" missing in 4diac 1.10
Current Time: Fri Jul 25 23:43:24 EDT 2025
Powered by FUDForum. Page generated in 0.04940 seconds
