Home » Modeling » Papyrus » Create model elements from Palette is forbidden
Create model elements from Palette is forbidden [message #1807400] Wed, 29 May 2019 04:41 Go to next message
Hi all,
I am using Papyrus 2018.12.
Currently I am not able to create an elements from the palette via drag and drop. On the contrary if I create the model on the Model Explorer it works properly, i.e. I can drag and drop the element from the tree.
You can see the attached video
Re: Create model elements from Palette is forbidden [message #1807402 is a reply to message #1807400] Wed, 29 May 2019 04:51 Go to previous messageGo to next message
Hi Luca,
Is it specific to drag-and-drop from the palette? I usually select an item in the palette (1 click) and then click again in the diagram to create it; I don't use drag and drop
Do you have any exception in your Error Log view when this happens? (I'm not able to reproduce the issue but I'm using 2019-03)
Camille
Re: Create model elements from Palette is forbidden [message #1807404 is a reply to message #1807402] Wed, 29 May 2019 05:03 Go to previous message
Hi Camille,
thanks for your reply. Well, I did the usual (almost) silver bullet action: platform update (still using 2018.12, btw) + restart and the problem disappeared. I can't reproduce the problem anymore.
As expected, I can create model element both with drag and drop and clicks.
Thanks for quick reply and support.
Luca
Previous Topic:applied stereotypes doesn't show up after applying a registered profile
Next Topic:Random behavior in the Model Explorer
Current Time: Wed Jul 23 22:59:04 EDT 2025
Powered by FUDForum. Page generated in 0.05635 seconds
