Property Section [message #1807389] |
Wed, 29 May 2019 03:12 |
I have taken on a legacy project and I have a question.
In the plugin.xml of the generated diagram module, where are following lines defined so that they are generated into the plugin.xml:
<propertySection
id="property.section.domain"
tab="property.tab.domain"
class="de.bmw.smard.modeller.statemachine.diagram.sheet.StatemachinePropertySection">
<input type="org.eclipse.gmf.runtime.notation.View"/>
<input type="org.eclipse.gef.EditPart"/>
</propertySection>
In the legacy code there were several other input types generated, but I can't get this to re-generate. (But I also upgraded to GMF Tooling, while the legacy code was generated with an older version of GMF, don't know if this might be the reason?!)
Where do I have to define that other classes should also be input types for the property section?
FUDForum. Page generated in 0.03331 seconds
