Unable to set hierarchical project presentation by default [message #1787602] |
Tue, 29 May 2018 17:19  |
I'm trying to get Project Explorer > Projects Presentation > Hierarchical set by default (as opposed to Flat) in a custom Eclipse RCP application.
We've had great luck using plugin_customization.ini for most preferences, but org.eclipse.ui.navigator.ProjectExplorer.activatedExtensions and org.eclipse.ui.navigator.ProjectExplorer.filterActivation have been causing grief.
- I start our product with new / clean workspace, exit, then create a copy of the whole .metadata structure.
- I start our product, set Projects Presentation to Hierarchical via the Project Explorer menu, then exit.
- I "diff -r" the new and copied .metadata directories. That pointed me to org.eclipse.ui.navigator.prefs, where I found org.eclipse.ui.navigator.ProjectExplorer.activatedExtensions and org.eclipse.ui.navigator.ProjectExplorer.filterActivation.
- I added the following to our plugin_customization.ini file:
org.eclipse.ui.navigator/org.eclipse.ui.navigator.ProjectExplorer.activatedExtensions=org.eclipse.cdt.make.ui.makeTargets.content\=true;org.eclipse.ui.navigator.resourceContent\=true;org.eclipse.cdt.ui.navigator.content\=true;org.eclipse.egit.ui.changeSetContent\=false;org.eclipse.ui.navigator.resources.workingSets\=true;org.eclipse.team.ui.patchSyncNavigatorContent\=true;org.eclipse.team.ui.resourceContent\=true;org.eclipse.egit.ui.RepositoriesViewContent\=true;org.eclipse.ui.navigator.resources.nested.nestedProjectContentProvider\=true;org.eclipse.jdt.java.ui.javaContent\=true;org.eclipse.jdt.ui.javaModelContent\=true;org.eclipse.remote.ui.navigatorContent.connections\=true;
org.eclipse.ui.navigator/org.eclipse.ui.navigator.ProjectExplorer.filterActivation=\:org.eclipse.jdt.java.ui.filters.HidePackageDeclaration\:org.eclipse.jdt.java.ui.filters.HideOutputFolder\:org.eclipse.cdt.ui.navigator.filters.AnonymousStructFilter\:org.eclipse.ui.navigator.resources.nested.HideTopLevelProjectIfNested\:org.eclipse.cdt.ui.navigator.filters.ForwardDeclarationFilter\:org.eclipse.jdt.java.ui.filters.HideEmptyInnerPackages\:org.eclipse.jdt.java.ui.filters.HideInnerClassFiles\:org.eclipse.ui.navigator.resources.filters.startsWithDot\:org.eclipse.jdt.java.ui.filters.HideEmptyLibraryContainers\:org.eclipse.jdt.java.ui.filters.HideImportDeclaration\:org.eclipse.jdt.java.ui.filters.HideSyntheticMembers\:org.eclipse.ui.navigator.resources.nested.HideFolderWhenProjectIsShownAsNested\:
- I rebuilt our product, ran it with a new workspace, but Projects Presentation is still Flat.
- If I manually copy org.eclipse.ui.navigator.prefs in to the workspace and restart, then I see Projects Presentation set to Hierarchical.
I isn't clear to me why those prefs aren't customizable like the other preferences we've customized. Would appreciate any assistance.
FUDForum. Page generated in 0.04435 seconds
