Eclipse freezes every time after a bit of usage [message #1807017] |
Tue, 21 May 2019 06:12  |
Since last October, I've got a new laptop Dell XPS 9570, currently on Arch Linux, Gnome 3.32, Oracle JDK 1.8.0_202 . After using Eclipse for about 20 - 30 minutes it becomes unresponsive, so that it needs to be killed and restarted.
Moving to Eclipse to v.2019-03 did not improve the situation. Tried with newer JDKs, no change. My workspace is C++ / CDT. Is there any known workaround or a way to help understanding what is the reason causing this behaviour?
Yours,
Mickey
Re: Eclipse freezes every time after a bit of usage [message #1807893 is a reply to message #1807017] |
Tue, 11 June 2019 14:04   |
Here is a stack dump
2019-06-11 20:09:07
Full thread dump Java HotSpot(TM) 64-Bit Server VM (11.0.1+13-LTS mixed mode):
Threads class SMR info:
_java_thread_list=0x00007f989c001ec0, length=32, elements={
0x00007f98e8012800, 0x00007f98e852c000, 0x00007f98e8530800, 0x00007f98e8543800,
0x00007f98e8545800, 0x00007f98e8547800, 0x00007f98e8549800, 0x00007f98e8603000,
0x00007f98e866a000, 0x00007f98e8ded800, 0x00007f98e8e41000, 0x00007f98e8e3d000,
0x00007f985c02c000, 0x00007f985c29f800, 0x00007f985c317000, 0x00007f98e8e4b000,
0x00007f98e9a2e800, 0x00007f98eb0fd000, 0x00007f97dc089800, 0x00007f97c0061000,
0x00007f97f4362000, 0x00007f97d85b2800, 0x00007f95fb4e5800, 0x00007f98e90f5000,
0x00007f95fa08a800, 0x00007f95f8993000, 0x00007f95fb1ea800, 0x00007f95fb038800,
0x00007f97d4034800, 0x00007f97e002a800, 0x00007f97d4051800, 0x00007f989c001000
"main" #1 prio=6 os_prio=0 cpu=2071468.98ms elapsed=17304.62s tid=0x00007f98e8012800 nid=0x34de runnable [0x00007f98ed315000]
java.lang.Thread.State: RUNNABLE
at org.eclipse.swt.internal.gtk.OS.Call(Native Method)
at org.eclipse.swt.widgets.Display.sleep(Display.java:5598)
at org.eclipse.ui.application.WorkbenchAdvisor.eventLoopIdle(WorkbenchAdvisor.java:371)
at org.eclipse.ui.internal.ide.application.IDEWorkbenchAdvisor.eventLoopIdle(IDEWorkbenchAdvisor.java:949)
at org.eclipse.ui.internal.Workbench$1.eventLoopIdle(Workbench.java:485)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1178)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1062)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench$$Lambda$97/0x000000080031dc40.run(Unknown Source)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:566)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:155)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:137)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:107)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(java.base@11.0.1/Native Method)
at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(java.base@11.0.1/NativeMethodAccessorImpl.java:62)
at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(java.base@11.0.1/DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(java.base@11.0.1/Method.java:566)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:661)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:597)
at org.eclipse.equinox.launcher.Main.run(Main.java:1476)
at org.eclipse.equinox.launcher.Main.main(Main.java:1449)
"Reference Handler" #2 daemon prio=10 os_prio=0 cpu=195.21ms elapsed=17304.60s tid=0x00007f98e852c000 nid=0x34e6 waiting on condition [0x00007f98b35fa000]
at java.lang.ref.Reference.waitForReferencePendingList(java.base@11.0.1/Native Method)
at java.lang.ref.Reference.processPendingReferences(java.base@11.0.1/Reference.java:241)
at java.lang.ref.Reference$ReferenceHandler.run(java.base@11.0.1/Reference.java:213)
"Finalizer" #3 daemon prio=8 os_prio=0 cpu=178.26ms elapsed=17304.60s tid=0x00007f98e8530800 nid=0x34e7 in Object.wait() [0x00007f98b34f9000]
java.lang.Thread.State: WAITING (on object monitor)
at java.lang.Object.wait(java.base@11.0.1/Native Method)
- waiting on <no object reference available>
at java.lang.ref.ReferenceQueue.remove(java.base@11.0.1/ReferenceQueue.java:155)
- waiting to re-lock in wait() <0x0000000700322ab0> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.ReferenceQueue.remove(java.base@11.0.1/ReferenceQueue.java:176)
at java.lang.ref.Finalizer$FinalizerThread.run(java.base@11.0.1/Finalizer.java:170)
"Signal Dispatcher" #4 daemon prio=9 os_prio=0 cpu=0.32ms elapsed=17304.59s tid=0x00007f98e8543800 nid=0x34e8 runnable [0x0000000000000000]
"C2 CompilerThread0" #5 daemon prio=9 os_prio=0 cpu=257219.88ms elapsed=17304.59s tid=0x00007f98e8545800 nid=0x34e9 waiting on condition [0x0000000000000000]
No compile task
"C1 CompilerThread0" #8 daemon prio=9 os_prio=0 cpu=28102.41ms elapsed=17304.59s tid=0x00007f98e8547800 nid=0x34ea waiting on condition [0x0000000000000000]
No compile task
"Sweeper thread" #9 daemon prio=9 os_prio=0 cpu=6127.81ms elapsed=17304.59s tid=0x00007f98e8549800 nid=0x34eb runnable [0x0000000000000000]
"Common-Cleaner" #10 daemon prio=8 os_prio=0 cpu=17.15ms elapsed=17304.56s tid=0x00007f98e8603000 nid=0x34ec in Object.wait() [0x00007f98b2d0f000]
java.lang.Thread.State: TIMED_WAITING (on object monitor)
- waiting to re-lock in wait() <0x0000000700314b40> (a java.lang.ref.ReferenceQueue$Lock)
at jdk.internal.ref.CleanerImpl.run(java.base@11.0.1/CleanerImpl.java:148)
at java.lang.Thread.run(java.base@11.0.1/Thread.java:834)
at jdk.internal.misc.InnocuousThread.run(java.base@11.0.1/InnocuousThread.java:134)
"Service Thread" #11 daemon prio=9 os_prio=0 cpu=0.11ms elapsed=17304.52s tid=0x00007f98e866a000 nid=0x34ed runnable [0x0000000000000000]
"Active Thread: Equinox Container: 0bf33b08-b311-43a1-b455-e9ff5bd7a551" #13 prio=5 os_prio=0 cpu=75.64ms elapsed=17303.98s tid=0x00007f98e8ded800 nid=0x34f5 waiting on condition [0x00007f987d841000]
java.lang.Thread.State: TIMED_WAITING (parking)
at jdk.internal.misc.Unsafe.park(java.base@11.0.1/Native Method)
- parking to wait for <0x000000070033f4c8> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.locks.LockSupport.parkNanos(java.base@11.0.1/LockSupport.java:234)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(java.base@11.0.1/AbstractQueuedSynchronizer.java:2123)
at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(java.base@11.0.1/ScheduledThreadPoolExecutor.java:1182)
at java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(java.base@11.0.1/ScheduledThreadPoolExecutor.java:899)
at java.util.concurrent.ThreadPoolExecutor.getTask(java.base@11.0.1/ThreadPoolExecutor.java:1054)
at java.util.concurrent.ThreadPoolExecutor.runWorker(java.base@11.0.1/ThreadPoolExecutor.java:1114)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(java.base@11.0.1/ThreadPoolExecutor.java:628)
"Framework Event Dispatcher: Equinox Container: 0bf33b08-b311-43a1-b455-e9ff5bd7a551" #15 daemon prio=5 os_prio=0 cpu=49.16ms elapsed=17303.81s tid=0x00007f98e8e41000 nid=0x34f6 in Object.wait() [0x00007f987d540000]
at java.lang.Object.wait(java.base@11.0.1/Object.java:328)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.getNextEvent(EventManager.java:403)
- waiting to re-lock in wait() <0x0000000700314d38> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:339)
"Start Level: Equinox Container: 0bf33b08-b311-43a1-b455-e9ff5bd7a551" #16 daemon prio=5 os_prio=0 cpu=497.60ms elapsed=17303.81s tid=0x00007f98e8e3d000 nid=0x34f7 in Object.wait() [0x00007f987d43f000]
- waiting on <0x0000000700377ec0> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
- waiting to re-lock in wait() <0x0000000700377ec0> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
"SCR Component Actor" #17 daemon prio=5 os_prio=0 cpu=0.49ms elapsed=17303.78s tid=0x00007f985c02c000 nid=0x34f8 in Object.wait() [0x00007f987d2b8000]
- waiting on <0x000000070035b908> (a java.util.LinkedList)
at org.apache.felix.scr.impl.ComponentActorThread.run(ComponentActorThread.java:83)
- waiting to re-lock in wait() <0x000000070035b908> (a java.util.LinkedList)
"Worker-JM" #19 prio=5 os_prio=0 cpu=60.78ms elapsed=17303.40s tid=0x00007f985c29f800 nid=0x3507 in Object.wait() [0x00007f987c19c000]
at org.eclipse.core.internal.jobs.InternalWorker.run(InternalWorker.java:62)
- waiting to re-lock in wait() <0x00000007026bab90> (a java.util.ArrayList)
"EMF Reference Cleaner" #20 daemon prio=5 os_prio=0 cpu=368.58ms elapsed=17303.31s tid=0x00007f985c317000 nid=0x3508 in Object.wait() [0x00007f981fdfe000]
- waiting to re-lock in wait() <0x0000000702665398> (a java.lang.ref.ReferenceQueue$Lock)
at org.eclipse.emf.common.util.CommonUtil$1ReferenceClearingQueuePollingThread.run(CommonUtil.java:70)
"Gogo shell" #22 prio=5 os_prio=0 cpu=14.46ms elapsed=17303.12s tid=0x00007f98e8e4b000 nid=0x350b waiting on condition [0x00007f981f8f9000]
java.lang.Thread.State: WAITING (parking)
- parking to wait for <0x000000070268fff0> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
at java.util.concurrent.locks.LockSupport.park(java.base@11.0.1/LockSupport.java:194)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(java.base@11.0.1/AbstractQueuedSynchronizer.java:2081)
at java.util.concurrent.LinkedBlockingQueue.take(java.base@11.0.1/LinkedBlockingQueue.java:433)
"Bundle File Closer" #26 daemon prio=6 os_prio=0 cpu=76.16ms elapsed=17301.46s tid=0x00007f98e9a2e800 nid=0x3526 in Object.wait() [0x00007f981f7f8000]
- waiting to re-lock in wait() <0x0000000701b80a00> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
"EventAdmin Async Event Dispatcher Thread" #29 daemon prio=6 os_prio=0 cpu=83.60ms elapsed=17297.01s tid=0x00007f98eb0fd000 nid=0x3529 in Object.wait() [0x00007f97f2ffe000]
- waiting to re-lock in wait() <0x000000070385d2e8> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
"JGit-WorkQueue" #45 daemon prio=5 os_prio=0 cpu=6.26ms elapsed=17295.91s tid=0x00007f97dc089800 nid=0x353c waiting on condition [0x00007f97f0d0a000]
- parking to wait for <0x000000070385d770> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject)
"Thread-9" #48 prio=5 os_prio=0 cpu=4030.39ms elapsed=17295.75s tid=0x00007f97c0061000 nid=0x353f waiting on condition [0x00007f97bf114000]
java.lang.Thread.State: TIMED_WAITING (sleeping)
at java.lang.Thread.sleep(java.base@11.0.1/Native Method)
at org.eclipse.equinox.internal.p2.updatechecker.UpdateChecker$UpdateCheckThread.run(UpdateChecker.java:90)
"Thread-10" #49 prio=5 os_prio=0 cpu=52.24ms elapsed=17295.70s tid=0x00007f97f4362000 nid=0x3540 waiting on condition [0x00007f97bec10000]
at org.eclipse.linuxtools.internal.docker.core.DockerContainerRefreshManager$ContainerRefreshThread.run(DockerContainerRefreshManager.java:153)
"Provisioning Event Dispatcher" #57 daemon prio=5 os_prio=0 cpu=0.23ms elapsed=17289.14s tid=0x00007f97d85b2800 nid=0x3553 in Object.wait() [0x00007f97bc3d3000]
- waiting to re-lock in wait() <0x00000007090f7220> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread)
"org.eclipse.jface.text.reconciler.MonoReconciler" #4917 daemon prio=1 os_prio=0 cpu=295.25ms elapsed=2582.47s tid=0x00007f95fb4e5800 nid=0x6a7e in Object.wait() [0x00007f97f1cf3000]
at org.eclipse.jface.text.reconciler.AbstractReconciler$BackgroundThread.run(AbstractReconciler.java:183)
- waiting to re-lock in wait() <0x000000071b800180> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
"org.eclipse.cdt.internal.ui.text.CReconciler" #4951 daemon prio=1 os_prio=0 cpu=418.18ms elapsed=1048.14s tid=0x00007f98e90f5000 nid=0x1dd8 in Object.wait() [0x00007f97f18f0000]
- waiting to re-lock in wait() <0x000000071b600180> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
"org.eclipse.cdt.internal.ui.text.CReconciler" #4971 daemon prio=1 os_prio=0 cpu=96.72ms elapsed=596.15s tid=0x00007f95fa08a800 nid=0x1ec8 in Object.wait() [0x00007f981f6f7000]
- waiting to re-lock in wait() <0x000000071b9001a0> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
"org.eclipse.cdt.internal.ui.text.CReconciler" #4977 daemon prio=1 os_prio=0 cpu=68.97ms elapsed=543.93s tid=0x00007f95f8993000 nid=0x1ed4 in Object.wait() [0x00007f97bf415000]
- waiting to re-lock in wait() <0x000000073330ea80> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
"org.eclipse.cdt.internal.ui.text.CReconciler" #4979 daemon prio=1 os_prio=0 cpu=84.84ms elapsed=514.77s tid=0x00007f95fb1ea800 nid=0x1ed7 in Object.wait() [0x00007f97f29f8000]
- waiting to re-lock in wait() <0x000000072f4830e0> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
"org.eclipse.cdt.internal.ui.text.CReconciler" #4980 daemon prio=1 os_prio=0 cpu=61.62ms elapsed=476.73s tid=0x00007f95fb038800 nid=0x1efd in Object.wait() [0x00007f97f2dfc000]
- waiting to re-lock in wait() <0x000000072c63bee0> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
"Worker-102" #4984 prio=5 os_prio=0 cpu=15.53ms elapsed=275.90s tid=0x00007f97d4034800 nid=0x1fbc in Object.wait() [0x00007f97bc7d5000]
at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.java:200)
- waiting to re-lock in wait() <0x00000007026bac18> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPool.java:242)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:58)
"Worker-103" #4985 prio=5 os_prio=0 cpu=3.97ms elapsed=129.84s tid=0x00007f97e002a800 nid=0x2026 in Object.wait() [0x00007f97f2bfa000]
"Worker-104" #4986 prio=5 os_prio=0 cpu=1.75ms elapsed=54.18s tid=0x00007f97d4051800 nid=0x2057 in Object.wait() [0x00007f97bc2d2000]
"Attach Listener" #4987 daemon prio=9 os_prio=0 cpu=0.44ms elapsed=0.20s tid=0x00007f989c001000 nid=0x2071 waiting on condition [0x0000000000000000]
"VM Thread" os_prio=0 cpu=2695.15ms elapsed=17304.60s tid=0x00007f98e8524000 nid=0x34e5 runnable
"GC Thread#0" os_prio=0 cpu=2237.08ms elapsed=17304.62s tid=0x00007f98e803a000 nid=0x34df runnable
"GC Thread#1" os_prio=0 cpu=2281.46ms elapsed=17303.63s tid=0x00007f98a0001000 nid=0x34fa runnable
"GC Thread#2" os_prio=0 cpu=2245.24ms elapsed=17303.63s tid=0x00007f98a0002800 nid=0x34fb runnable
"GC Thread#3" os_prio=0 cpu=2242.98ms elapsed=17303.63s tid=0x00007f98a0004000 nid=0x34fc runnable
"GC Thread#4" os_prio=0 cpu=2240.23ms elapsed=17303.63s tid=0x00007f98a0005800 nid=0x34fd runnable
"GC Thread#5" os_prio=0 cpu=2228.81ms elapsed=17303.63s tid=0x00007f98a0007800 nid=0x34fe runnable
"GC Thread#6" os_prio=0 cpu=2237.34ms elapsed=17303.63s tid=0x00007f98a0009000 nid=0x34ff runnable
"GC Thread#7" os_prio=0 cpu=2263.04ms elapsed=17303.63s tid=0x00007f98a000a800 nid=0x3500 runnable
"GC Thread#8" os_prio=0 cpu=2241.59ms elapsed=17303.63s tid=0x00007f98a000c000 nid=0x3501 runnable
"GC Thread#9" os_prio=0 cpu=2249.90ms elapsed=17303.63s tid=0x00007f98a000d800 nid=0x3502 runnable
"G1 Main Marker" os_prio=0 cpu=4.58ms elapsed=17304.62s tid=0x00007f98e809a800 nid=0x34e0 runnable
"G1 Conc#0" os_prio=0 cpu=270.84ms elapsed=17304.62s tid=0x00007f98e809c800 nid=0x34e1 runnable
"G1 Conc#1" os_prio=0 cpu=267.93ms elapsed=17303.23s tid=0x00007f98bc001000 nid=0x3509 runnable
"G1 Conc#2" os_prio=0 cpu=268.96ms elapsed=17303.23s tid=0x00007f98bc002800 nid=0x350a runnable
"G1 Refine#0" os_prio=0 cpu=272.83ms elapsed=17304.61s tid=0x00007f98e8453800 nid=0x34e2 runnable
"G1 Refine#1" os_prio=0 cpu=96.69ms elapsed=17303.62s tid=0x00007f98b8001000 nid=0x3503 runnable
"G1 Refine#2" os_prio=0 cpu=45.87ms elapsed=17303.62s tid=0x00007f982c001000 nid=0x3504 runnable
"G1 Refine#3" os_prio=0 cpu=21.95ms elapsed=17303.62s tid=0x00007f9820001000 nid=0x3505 runnable
"G1 Refine#4" os_prio=0 cpu=6.98ms elapsed=17303.62s tid=0x00007f9824001000 nid=0x3506 runnable
"G1 Refine#5" os_prio=0 cpu=3.20ms elapsed=17302.62s tid=0x00007f9818001000 nid=0x3510 runnable
"G1 Refine#6" os_prio=0 cpu=0.17ms elapsed=17302.62s tid=0x00007f9800007000 nid=0x3511 runnable
"G1 Refine#7" os_prio=0 cpu=0.06ms elapsed=17294.22s tid=0x00007f97fc001000 nid=0x3547 runnable
"G1 Young RemSet Sampling" os_prio=0 cpu=14298.79ms elapsed=17304.61s tid=0x00007f98e8455800 nid=0x34e3 runnable
"StrDedup" os_prio=0 cpu=386.73ms elapsed=17304.61s tid=0x00007f98e845d000 nid=0x34e4 runnable
"VM Periodic Task Thread" os_prio=0 cpu=11803.72ms elapsed=17304.52s tid=0x00007f98e8671800 nid=0x34ee waiting on condition
JNI global refs: 107, weak refs: 0
Attachment: stack.txt
(Size: 23.30KB, Downloaded 236 times)
[Updated on: Tue, 11 June 2019 14:10] by Moderator
Re: Eclipse freezes every time after a bit of usage [message #1859600 is a reply to message #1809470] |
Mon, 19 June 2023 07:02   |
I'm seeing the same issue(s) on linux very frequently recently (with most current Eclipse, throughout the past 2 to 3 releases). My observation so far:
* Happens *mostly* when switching (on GNOME) between windows using the Meta (Windows) key.
* The UI completely freezes
* BUT the stacktrace shows an idle IDE
* AND the main menu strip (File, Edit, etc.) is still working normally. It looks like the client area of the window is no longer redrawn, regardless of what I'm doing.
* Also the cursor changes while moving around hovering different areas in the IDE, so it does detect that it's over a text editor, tree, etc.
* I can still issue commands per keyboard shortcut to execute things, etc.
* When I "blindly" select text in an editor and restart the IDE using File > Restart, the selection is visible once the IDE restarted.
FUDForum. Page generated in 0.10506 seconds
