Home » Eclipse Projects » Sirius » Hierarchical List as Property View
Hierarchical List as Property View [message #1806968] Mon, 20 May 2019 06:24 Go to next message
Hey guys,
i want to have a property view for the following Metamodel:
        subtest
                                       ______
                                       v     |
Physical Asset <----- tests -------  Test ___|
Physical Asset has several test, which can be out of several subtests. This recursive pattern can have a depth of 3. (So imperative design is possible)
I want to have or build a component, which can handle this structure: A hierarchical List in the property view.
What is the best approach for that?
Bushra :)
[Updated on: Mon, 20 May 2019 06:29] by Moderator
Re: Hierarchical List as Property View [message #1807077 is a reply to message #1806968] Wed, 22 May 2019 04:58 Go to previous message
I am not sure to understand your need.
From which element select do you want this component? And when you say a hierarchical list do you mean that the selected elements should show all sub elements recursively? So if a Physical asset is selected, the properties widget will show tests items and under these items sub tests items, etc?
Previous Topic:Model explorer & diagrams label colors
Next Topic:Parent container going null in SiriusCanonicalLayoutCommand class
Current Time: Sat Jul 19 04:27:26 EDT 2025
Powered by FUDForum. Page generated in 0.04307 seconds
