Generic Editor PDE Wizard example: no access to underlying editor widget? [message #1806937] |
Sat, 18 May 2019 05:10  |
I was studying the example created by the PDE wizard "Textual editor, relying on Generic Editor" and specifically the use IDocumentSetupParticipant used from the "org.eclipse.core.filebuffers.documentSetup" extension point.
It uses an IDocumentListener to trigger parsing of text to create annotations for errors in the document. I noticed however that the example creates file markers associated with the buffer: this is a problem because they stay in the problems view even when you close the editor without saving! So if I introduce an error by typing text, the marker shows up but if I close the editor without saving it stays there (even though I modified the example to set the non-persistent attribute).
I want my IDocumentSetupParticipant to have access to the underlying text editor widget, so that it can register (for example) to the close event of the editor and react by removing the markers, but I cannot find any API to do this (I checked the extension IDocumentSetupParticipantExtension as well as IDocument and all its extensions).
How can I create truly transient (i.e. visible only while editor is open) markers for my editor in the generated ValidatorDocumentSetupParticipant? Is there any way to achieve this?
This is what the example generates:
package org.myeditor.experiment;
import java.io.StringReader;
import javax.xml.parsers.DocumentBuilder;
import javax.xml.parsers.DocumentBuilderFactory;
import org.eclipse.core.filebuffers.IDocumentSetupParticipant;
import org.eclipse.core.filebuffers.IDocumentSetupParticipantExtension;
import org.eclipse.core.filebuffers.LocationKind;
import org.eclipse.core.resources.IFile;
import org.eclipse.core.resources.IMarker;
import org.eclipse.core.resources.ResourcesPlugin;
import org.eclipse.core.runtime.CoreException;
import org.eclipse.core.runtime.IPath;
import org.eclipse.jface.text.DocumentEvent;
import org.eclipse.jface.text.IDocument;
import org.eclipse.jface.text.IDocumentListener;
import org.xml.sax.InputSource;
import org.xml.sax.SAXParseException;
public class ValidatorDocumentSetupParticipant implements IDocumentSetupParticipant, IDocumentSetupParticipantExtension {
private final class DocumentValidator implements IDocumentListener {
private final IFile file;
private IMarker marker;
private DocumentValidator(IFile file) {
this.file = file;
public void documentChanged(DocumentEvent event) {
if (this.marker != null) {
try {
this.marker.delete();
} catch (CoreException e) {
e.printStackTrace();
this.marker = null;
try (StringReader reader = new StringReader(event.getDocument().get());) {
DocumentBuilder documentBuilder = DocumentBuilderFactory.newInstance().newDocumentBuilder();
documentBuilder.parse(new InputSource(reader));
} catch (Exception ex) {
try {
this.marker = file.createMarker(IMarker.PROBLEM);
this.marker.setAttribute(IMarker.TRANSIENT, true); // ADDED THIS MYSELF TO AT LEAST NOT SURVIVE WORKSPACE RESTART
this.marker.setAttribute(IMarker.SEVERITY, IMarker.SEVERITY_ERROR);
this.marker.setAttribute(IMarker.MESSAGE, ex.getMessage());
if (ex instanceof SAXParseException) {
SAXParseException saxParseException = (SAXParseException)ex;
int lineNumber = saxParseException.getLineNumber();
int offset = event.getDocument().getLineInformation(lineNumber - 1).getOffset() + saxParseException.getColumnNumber() - 1;
this.marker.setAttribute(IMarker.LINE_NUMBER, lineNumber);
this.marker.setAttribute(IMarker.CHAR_START, offset);
this.marker.setAttribute(IMarker.CHAR_END, offset + 1);
} catch (Exception e) {
public void documentAboutToBeChanged(DocumentEvent event) {
public void setup(IDocument document) {
public void setup(IDocument document, IPath location, LocationKind locationKind) {
if (locationKind == LocationKind.IFILE) {
IFile file = ResourcesPlugin.getWorkspace().getRoot().getFile(location);
document.addDocumentListener(new DocumentValidator(file));
Re: Generic Editor PDE Wizard example: no access to underlying editor widget? [message #1807050 is a reply to message #1806937] |
Tue, 21 May 2019 15:35  |
I've resorted to setting up a "service" in my plugin that I look up using the activator. This way the document setup code simply invokes the parser (when text changes) and stores the parsed model in the service without affecting presentation at all. The latter is done by the presentation reconciler (IPresentationReconciler instance) which has access to the text viewer and its annotation model.
FUDForum. Page generated in 0.24402 seconds
