Home » Modeling » TMF (Xtext) » Semicolon optional at end of line
Semicolon optional at end of line [message #1806908] Fri, 17 May 2019 08:20 Go to next message
I would like to define a language that uses semicolons to separate statements form each other. However, I want semicolons optional at the end of a line only. If two statements (or more) are on the same line the semicolon should be required between statement 1 and 2, but not after statement 2. (Line breaks should still be allowed everywhere where whitespace is allowed.)
For example, with the trivial greeting language:
Valid:
Hello X!;
Hello Y!
Hello Z!
Hello A!; Hello B!; Hello C!
Hello K
!; Hello L!
Hello M!; Hello
N!
Invalid:
Hello X! Hello Y!
Hello A! Hello B!;
How do I do this in Xtext? It seems like I need to treat '\n' as non whitespace, but then I'd have to insert explicit '\n' everywhere in the grammar. Is there an easier way to do this?
Re: Semicolon optional at end of line [message #1806909 is a reply to message #1806908] Fri, 17 May 2019 08:23 Go to previous messageGo to next message
what about allow it everywhere in grammar and validate that it is used at line end only?
Re: Semicolon optional at end of line [message #1806919 is a reply to message #1806909] Fri, 17 May 2019 11:43 Go to previous messageGo to next message
I guess you mean: Make it optional everywhere and validate that it's there when not at a line end. That would match what I want.
That may be an option but looks a bit tedious because the validation would need to look at the node model to check for end of line. I was hoping there was something that could be done in the grammar.
Re: Semicolon optional at end of line [message #1806923 is a reply to message #1806919] Fri, 17 May 2019 11:56 Go to previous message
explicit whitespace in Xtext grammars is very slugggish and tedious so i personally would avoid it at all cost
Previous Topic:Completeness of the .ecore generated by Xtext
Next Topic:Whitespace validator in XText
Current Time: Sat Jul 19 23:48:54 EDT 2025
Powered by FUDForum. Page generated in 0.02644 seconds
