Home » Language IDEs » Java Development Tools (JDT) » Eclipse project build automation
Eclipse project build automation [message #1806885] Fri, 17 May 2019 03:05 Go to next message
I am trying to automate builds of my eclipse plugins using maven with the Tycho plugin. The issue is that my company forbids access to eclipse repositories (http://download.eclipse.org/releases/oxygen/) since it is not a secure url with https. As a consequence, maven can't get its required dependencies.
Therefore I thought I could create a local eclipse repository clone using nexus (a kind of target platform). Could this approach work ? Has anyone faced a similar issue and figured out a better solution ? And how can I deal with my issue? Any documentation is also welcome.
Re: Eclipse project build automation [message #1806888 is a reply to message #1806885] Fri, 17 May 2019 04:10 Go to previous messageGo to next message
It's not really a JDT question.
I assume the fundamental problem is that it is a composite like this:
<?xml version='1.0' encoding='UTF-8'?>
<?compositeMetadataRepository version='1.0.0'?>
<repository name='Eclipse Repository'  type='org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository' version='1.0.0'>
  <properties size='3'>
    <property name='p2.timestamp' value='1313779613118'/>
    <property name='p2.compressed' value='true'/>
    <property name='p2.atomic.composite.loading' value='true'/>
  </properties>
  <children size='3'>
     <child location='http://download.eclipse.org/technology/epp/packages/oxygen/'/>
    <child location='201804111000' />
    <child location='201803211000' />
    <child location='201712201001' />
  </children>
</repository>
So instead of using this site directly use https://download.eclipse.org/releases/oxygen/201804111000 (the final maintenance release) and https//download.eclipse.org/technology/epp/packages/oxygen instead. The latter is not a composite but an aggregate (simple) repository.
Re: Eclipse project build automation [message #1806896 is a reply to message #1806888] Fri, 17 May 2019 04:43 Go to previous messageGo to next message
Thanks for your answer.
Sorry, I didn't know where to post my issue. I will try that.
Re: Eclipse project build automation [message #1806911 is a reply to message #1806896] Fri, 17 May 2019 09:18 Go to previous message
If for any reasons you still want a local mirror, have a look at https://wiki.eclipse.org/Equinox_p2_Repository_Mirroring
Previous Topic:What are those numbers in hover-popup: "java#11.awt#55.Graphics#32603"
Next Topic:Imported Maven project can't find JUnit or Mockito artifacts, but builds from maven
Current Time: Mon Jul 21 09:16:33 EDT 2025
Powered by FUDForum. Page generated in 0.03069 seconds
