Configuring my IDE to work on Linux [message #1806698] |
Tue, 14 May 2019 03:23  |
I am going to try and keep this short.
I run a linux distro MXLinux where I currently have 2 side by side installations (of Eclipse) including the one from package manager, and 1 installed from source using the eclipse-installer, tarball, x86_64 build. I think while installing this newer build it broke the older installation, which I don't really care much about.
What I want is to fix some issues with the new installation, which is overall working pretty well, and I like it. The quirkiness going on...with user profiles is that files in the /root folder are being used and I would like to avoid that. Also I can't install plugins with a regular user, and have to end up exiting and relaunching as root (which launching as root is something I want to avoid).
When I first installed via the eclipse-installer script I recall having some issues that caused me to have to reinstall in first place.
But now in terms of the permissions issue for install, and the files in /root is there anything that can be done to make it all accessible via a regular user.
Please help!
Re: Configuring my IDE to work on Linux [message #1806847 is a reply to message #1806844] |
Thu, 16 May 2019 05:06   |
Well I've gone ahead and repeated installation this time choosing the location for a pool that was different (I placed it into my Developer folder in my /home/username directory. I hope that won't conflict but seems like a better place for it than in root, which I don't understand how come that was chosen in the first place.
The installation was tricky, but it seemed to go fine.
When I fired up the new IDE, here's some little log errors I'm getting now, could someone please help me to understand? I know from working with operating systems in general it is often unrealistic to assume that no error messages will be logged, but with this particular feature is this something to be concerned about?
!ENTRY org.eclipse.mylyn.bugzilla.core 4 0 2019-05-16 01:56:02.920
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.mylyn.bugzilla.core [265]
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.commons.xmlrpc; bundle-version="[3.8.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.mylyn.commons.xmlrpc; bundle-version="3.24.2.v20180904-2231"; singleton:="true"
org.eclipse.mylyn.commons.xmlrpc [282]
Unresolved requirement: Require-Bundle: org.apache.xmlrpc; bundle-version="[3.0.0,4.0.0)"
-> Bundle-SymbolicName: org.apache.xmlrpc; bundle-version="3.0.0.v20100427-1100"
org.apache.xmlrpc [54]
Unresolved requirement: Import-Package: javax.xml.bind
at org.eclipse.osgi.container.Module.start(Module.java:452)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1784)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1763)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1726)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1657)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:233)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:343)
!ENTRY org.eclipse.mylyn.bugzilla.ui 4 0 2019-05-16 01:56:02.923
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.mylyn.bugzilla.ui [267]
Unresolved requirement: Require-Bundle: org.eclipse.mylyn.bugzilla.core; bundle-version="[3.8.0,4.0.0)"
-> Bundle-SymbolicName: org.eclipse.mylyn.bugzilla.core; bundle-version="3.24.2.v20180905-0003"; singleton:="true"
!ENTRY org.eclipse.mylyn.commons.xmlrpc 4 0 2019-05-16 01:56:02.924
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.mylyn.commons.xmlrpc [282]
!ENTRY org.eclipse.egit.core 1 0 2019-05-16 01:56:42.460
!MESSAGE Using Apache MINA sshd as ssh client.
!ENTRY org.eclipse.mylyn.tasks.core 4 0 2019-05-16 01:56:46.548
!MESSAGE Unexpected error while loading repository template extensions
!SUBENTRY 1 org.eclipse.mylyn.tasks.core 4 0 2019-05-16 01:56:46.548
!MESSAGE Could not load repository template extension contributed by 'org.eclipse.mylyn.bugzilla.ide' with connectorKind 'bugzilla'
Re: Configuring my IDE to work on Linux SOLVED [message #1806851 is a reply to message #1806847] |
Thu, 16 May 2019 05:21  |
I was able to look up the stack trace in the error log, and find a fix online involving downloading some files to place into the dropfiles folder in the installation directory.
Amazing that web works to make all the potential answers available.
I know that others might be experiencing problems, but rather than to spam more links or info, if someone wants to know the solution to this they should be able to do as I did and simply copy paste the exact first line of the trace into google and get an answer. I would like to mark this thread as solved!
FUDForum. Page generated in 0.08997 seconds
