Home » Eclipse Projects » Eclipse Titan » TTCN3 Ethernet TCP Socket program(Trying to run a server client socket program using internal local host threads)
TTCN3 Ethernet TCP Socket program [message #1806781] Wed, 15 May 2019 03:01 Go to next message
Hi ,
I have been trying to set up a communication through LAN, using socket programming. I have the C++ drivers working for the server and client, independantly.
So I mapped the same way as the Serial Port Test Project was configured. But as i placed the server in the send(), and client in the receive() used localhost port , the program hangs and i do not get any response like i should. Is there anything i am missing or doing wrong. TTCN3 is fairly new to me.
Thank you.
Re: TTCN3 Ethernet TCP Socket program [message #1806782 is a reply to message #1806781] Wed, 15 May 2019 03:05 Go to previous message
Hi Anupan,
I'd recommend you to use the LANL2 test port:
https://github.com/eclipse/titan.TestPorts.LANL2asp
which is exactly for LAN communication;
C++ and socket programming are interesting , but they are not strictly related to TTCN-3 and Titan.
Best regards
Elemer
Previous Topic:Using TITAN for a LED game :)
Next Topic:Reg. GCC versions
Current Time: Mon Jul 21 07:29:09 EDT 2025
Powered by FUDForum. Page generated in 0.25146 seconds
