Home » Modeling » TMF (Xtext) » How scoping works on Ecore Editor ?
How scoping works on Ecore Editor ? [message #1806538] Fri, 10 May 2019 05:10 Go to next message
I have a metamodel that is generated by Xtext from a syntax of DSL named DSL1.
Within this DSL I make a cross reference to another DSL say DSL2.
Now, I created a dynamique instance in the Ecore Editor of DSL1. I also created a dynamique instance of DSL2 in the Ecore Editor.
When I want to specify the cross reference in the Editor, it is empty (I guess there is nothing in the scope). In Xtext, the scoping is handled in the ScopeProvider.
How can I achieve that in the Ecore Editor ?
Re: How scoping works on Ecore Editor ? [message #1806543 is a reply to message #1806538] Fri, 10 May 2019 05:28 Go to previous messageGo to next message
You need to load the resource you want to reference into the resource set of the editor. You can do that via the context menu, Load Resource, or by dragging and dropping the file from the workspace onto the open editor.
Re: How scoping works on Ecore Editor ? [message #1806544 is a reply to message #1806543] Fri, 10 May 2019 05:38 Go to previous messageGo to next message
I tried that but it does not work, and it makes sense because there is no scope provider in the Ecore Editor ?
Re: How scoping works on Ecore Editor ? [message #1806549 is a reply to message #1806544] Fri, 10 May 2019 06:40 Go to previous messageGo to next message
you would need to have a resource service provider for xmi files
is there any reason you dont create yourdsl files?
Re: How scoping works on Ecore Editor ? [message #1806555 is a reply to message #1806549] Fri, 10 May 2019 06:54 Go to previous messageGo to next message
I got my dsl file, if you mean an Xtext project. But I use the metamodel in another project and I want to apply some transformations using ATL on the instances.
How can make a provider for xmi ?
Re: How scoping works on Ecore Editor ? [message #1806558 is a reply to message #1806555] Fri, 10 May 2019 07:10 Go to previous messageGo to next message
why do you need an xmi at all.
the mydsl file i an emf resource and can be fed into any emf based tooling
Re: How scoping works on Ecore Editor ? [message #1806562 is a reply to message #1806558] Fri, 10 May 2019 07:19 Go to previous message
Ok I see I will try that. Thanks a lot for your help
Previous Topic:Left Recursion Problem in xText
Next Topic:How to change the directory of the generated metamodel ?
Current Time: Mon Jul 21 08:22:49 EDT 2025
Powered by FUDForum. Page generated in 0.05279 seconds
