Home » Eclipse Projects » GEF » 50% "Shading" figures
50% "Shading" figures [message #180653] Mon, 09 May 2005 12:40 Go to next message
Originally posted by: Craig.OfficeExtend.com
I'm building a form designer and have a reason to 50% color various figures
in my diagram. What I mean by that would be to have the figure paint itself
normally and then drop 50% shading (half-transparent) over the the result.
Best approach?
Re: 50% "Shading" figures [message #180684 is a reply to message #180653] Mon, 09 May 2005 13:38 Go to previous message
Originally posted by: eclipse.officeextend.com
I think I may have found my answer in the SelectorFigure class using a
single pixel image with a SetAlpha of (55) and then drawing that image
over the figure's bounds.
Re: 50% "Shading" figures [message #180693 is a reply to message #180653] Mon, 09 May 2005 13:33 Go to previous message
Have you looked at the thumbnail in the outline for the logic example?
That's probably the best way to do it. Look at
ScrollableThumbnail.SelectorFigure. It creates a one-pixel image with the
desired alpha, and then stretches it over the desired area.
SWT has new API in 3.1 that allows you to do this (so you wouldn't have to
create an Image), but I believe there are some serious problems with that.
It enables GDI+ (on Windows; might not work on other platforms), which
incurs huge performance hits (among other things). Randy would be able to
give you a more accurate report about using this feature. We might not
expose that new API for 3.1.
"Craig Fransen" <Craig@OfficeExtend.com> wrote in message
news:d5o49r$heu$1@news.eclipse.org...
figures
itself
> Best approach?
Previous Topic:sharing objects between models
Next Topic:Making GEF's EDiagram extensible
Current Time: Sat Jul 26 21:28:28 EDT 2025
Powered by FUDForum. Page generated in 0.03524 seconds
