Home » Eclipse Projects » NatTable » Date cell editor - set null(for date column i want to set null date , but date picker does not show up if we do not set any date value)
Date cell editor - set null [message #1806414] Wed, 08 May 2019 12:19 Go to next message
i have a nattable with a column having date cell editor. the column is not mandatory so it should support empty value.
if i set null to the cell data by default, the date picker does not set the next selected date value. if i set current date to the variable in data object for the cell, then the date picker works fine, but in this scenario, i cannot clear the selected date.
can anyone help me with how can i have empty values in date cell in nattable.
Re: Date cell editor - set null [message #1806435 is a reply to message #1806414] Thu, 09 May 2019 01:11 Go to previous message
the javadoc of the DateCellEditor has the following note:
 * Note: This is an example implementation for a Date editor. As the SWT
 * DateTime control has some serious issues like it is not nullable, has issues
 * on setting the focus programmatically and it is not possible to open the
 * dropdown programmatically, we suggest to rather use some Nebula widget or a
 * custom widget for date editing.
It is quite a while that I worked on that area, but IIRC SWT DateTime and null does not work. I therefore created the CDateTimeCellEditor in the Nebula Extension that can deal with this. So I suppose you need to use the CDateTimeCellEditor to support that use case.
Previous Topic:Duplicate elements created on sorting a tree implemented using Nattable
Next Topic:Ad a overlay such as a "glaspane" over the whole table
Current Time: Wed Nov 05 14:11:09 EST 2025
Powered by FUDForum. Page generated in 0.03570 seconds
