Home » Eclipse Projects » Oomph » What's wrong with my setup file ?
What's wrong with my setup file ? [message #1806142] Fri, 03 May 2019 09:04 Go to next message
I'm trying to author a project model setup for an eclipse project : a simple maven java project called msi
But when I try to install a new eclipse instance including this msi project, I can't select it on the wizard. (see snapshot in attachement)
Msi project appears, but the corresponfing icon looks very simple without any decorator. And most of all, I can't select it...
My setup file is attached to this post
  • Attachment: Msi.setup
    (Size: 2.51KB, Downloaded 181 times)
  • Attachment: pboomphmsi.png
    (Size: 88.67KB, Downloaded 136 times)
Re: What's wrong with my setup file ? [message #1806346 is a reply to message #1806142] Tue, 07 May 2019 23:32 Go to previous message
Your Project does not specify any Streams. Only Streams can actually be selected in the wizard. A Project without Streams is only useful if it contains sub-Projects. The decoration you see in the wizard (and the editor) reflects this fact: the blue folder icon is used for a Project with at least one Stream while the yellow folder icon is used for a Project without Streams.
Previous Topic:Setup gets broken for unsupported target platforms
Next Topic:Installation of IU dependent on Eclipse platform
Current Time: Sun Jul 20 22:07:57 EDT 2025
Powered by FUDForum. Page generated in 0.29407 seconds
