Home » Eclipse Projects » Sirius » Issue on adding meta model - Add from registry is not showing packages.
Issue on adding meta model - Add from registry is not showing packages. [message #1806262] Tue, 07 May 2019 03:35 Go to next message
Hi all,
I created one viewpoint specification project. And I have a model. I created one diagram and when I try to add meta model the packages not showing in list. I added the dependency in META-INF. When I create diagram in Domain Class the class is showing. But in meta model why I can not add any packages!
Re: Issue on adding meta model - Add from registry is not showing packages. [message #1806382 is a reply to message #1806262] Wed, 08 May 2019 05:44 Go to previous messageGo to next message
The issue is coming after updating, that is from
Sirius 5.1.2 to Sirius 6.1.2
Eclipse neon to oxygen
In the before version of Sirius(Sirius 5.1.2) when I select add metamodels I was getting all packages related to my model. After updating above version I am getting the issue. Changing the version will effect anything?
Can I get any help?
[Updated on: Wed, 08 May 2019 05:45] by Moderator
Re: Issue on adding meta model - Add from registry is not showing packages. [message #1806533 is a reply to message #1806262] Fri, 10 May 2019 04:49 Go to previous message
The issue is solved.
Thank you Sirius Team! new features of Sirius are really good.
Previous Topic:Preview Style tooltip
Next Topic:How to access other instances in Sirius while defining semantic constraint ?
Current Time: Mon Jul 21 00:32:30 EDT 2025
Powered by FUDForum. Page generated in 0.05964 seconds
