Home » Eclipse Projects » RCP Testing Tool » Unable to run RCPTT tests using pom.xml for eclipse 4.9 application(Unable to run RCPTT tests using pom.xml for eclipse 4.9 application)
Unable to run RCPTT tests using pom.xml for eclipse 4.9 application [message #1806065] Thu, 02 May 2019 00:55 Go to next message
Hi, we are using RCPTT to automate our eclipse application (not rcp), test cases created successfully and can be run from rcptt successfully, however when we tried to run them using pom.xml, the AUT gets opened successfully, however failing to do any actions after that. It is failing by saying that
[INFO] Trying to use VM from application's ini file: C:/Progress/OpenEdge121/jre/bin/javaw.exe
Please find the logs attached.
Thanks in Advance
Brahma
  • Attachment: pom.xml
    (Size: 1.49KB, Downloaded 99 times)
  • Attachment: autlog.txt
    (Size: 1.18MB, Downloaded 126 times)
Re: Unable to run RCPTT tests using pom.xml for eclipse 4.9 application [message #1806361 is a reply to message #1806065] Wed, 08 May 2019 03:37 Go to previous message
What version of Eclipse platform does your application use?
Did you try Runner 2.4.1 or 2.4.2-SNAPSHOT ?
Previous Topic:Invoking MenuDetectListener in a StyledText
Next Topic:Feature Injections not working in 2.4.2 nightly builds
Current Time: Mon Jul 21 00:27:32 EDT 2025
Powered by FUDForum. Page generated in 0.30323 seconds
