Home » Modeling » TMF (Xtext) » Xtext Web: generate and save(The requested generator artifact was not found.)
Xtext Web: generate and save [message #1805453] Mon, 15 April 2019 09:50 Go to next message
Hi again.
I try to generate my dsl and save it on disk via xtext web-editor and 'generate' button. The File-name is created in the generator.
fsa.generateFile(e.getName() ,e.compile)
i have to pass a folder but when i press the generate button i get the following message: "The requested generator artifact was not found."
I read s.th. in https://www.eclipse.org/forums/index.php/t/1076582/ but the addition of artifact : 'foo' and other things like filename and path doesn't work.
Where I have to implement the persistence of the generator or is it already there? How does it work?
Thanks again,
Markus
Re: Xtext Web: generate and save [message #1805454 is a reply to message #1805453] Mon, 15 April 2019 09:52 Go to previous messageGo to next message
i am not sure if i can follow you. nothing has changed since that post.
and there is no to-disk. you dont even say which disk (server, client) you mean
Re: Xtext Web: generate and save [message #1805455 is a reply to message #1805454] Mon, 15 April 2019 09:54 Go to previous messageGo to next message
besides that: is always helps to read and debug code.
GeneratorService in this case.
Re: Xtext Web: generate and save [message #1805456 is a reply to message #1805455] Mon, 15 April 2019 10:23 Go to previous messageGo to next message
I need a "to disk" on client side.
Debugging is difficult. I exported it and in the runtime env i have no sources, just compiled jars.
I send the request with jquery:
jQuery('#generate-button').bind("click", function(e) {
var data = {
serviceType: 'generate',
artifact : $("#PolWi").val(),
resource: $("#PolWi").val() + '.mydsl',
project: $("#PolProj").val(),
fullText: editor.getValue(),
contentType: 'text'
console.log(data);
jQuery.post('http://localhost:84/polarion/xtext-service', data, function(result) {
console.log("xxx");
I look for a way to save the generated file on a folder on client side.
Re: Xtext Web: generate and save [message #1805457 is a reply to message #1805456] Mon, 15 April 2019 10:28 Go to previous messageGo to next message
i still cannot follow you.
the service allows you to send the generates to the client.
does this work. does it not?
please debug the generator service.
this should be a nobrainer with the launcher main
see also https://github.com/eclipse/xtext-web/blob/e865e71effc149f3c2255bded0c8674afb2fdce8/org.eclipse.xtext.web/src/test/java/org/eclipse/xtext/web/server/test/GeneratorTest.xtend
i also dont see what the values for artifact etc as
[Updated on: Mon, 15 April 2019 10:31] by Moderator
Re: Xtext Web: generate and save [message #1805464 is a reply to message #1805457] Mon, 15 April 2019 11:46 Go to previous messageGo to next message
I got it with the artifact. it's the name of of the generated file.
I have result in the response of my browser. But it doesn't compile properly, i get s.th. like
testcase �domainmodel.gName()�()
//PreCondition
�FOR pre : domainmodel.eAllContents.toIterable.filter(PreCondition)�
�FOR fun: pre.function�
�fun�
�ENDFOR�
�ENDFOR�
�FOR ts : domainmodel.eAllContents.toIterable.filter(TestStep)�
//Teststep �ts.number�
�ts.compile�
�ENDFOR�
It worked when i tested my dsl in eclipse and it's editor
Re: Xtext Web: generate and save [message #1805468 is a reply to message #1805464] Mon, 15 April 2019 12:30 Go to previous messageGo to next message
are you sure your encoding is correct when you compile the generator on command line?
how do you build it.
what is the default encoding on your machine?
[Updated on: Mon, 15 April 2019 12:32] by Moderator
Re: Xtext Web: generate and save [message #1805898 is a reply to message #1805468] Sat, 27 April 2019 02:42 Go to previous messageGo to next message
I compile with this instructions on a windows 7 machine to get a war, which i import in my project. I don't find out default encoding for my machine. Just Google results
Sorry for the delayed answer, i was busy.
1) create new project
(2) deselect eclipse
(3) select web
(4) select gradle
(5) go to org.xtext.example.mydsl.parent
(6) ./gradlew clean build -x test (might need workaround for eclipse/xtext: Fehler-Nr. 1231)
(7)go to org.xtext.example.mydsl.parent/org.xtext.example.mydsl.web/build/libs
(8) get a war
Re: Xtext Web: generate and save [message #1805900 is a reply to message #1805898] Sat, 27 April 2019 05:18 Go to previous message
https://github.com/xtext/xtext-gradle-plugin/blob/3ec57eafa93a4ba79df58427656694c828ed3a08/xtext-gradle-plugin/src/main/java/org/xtext/gradle/XtextBuilderPlugin.xtend
You can set it explicitly in the java or the plugin options
Or you set a platform encoding somehow (win specific)
Previous Topic:On using XtextAntlrGeneratorFragment2 in work flow getting java.lang.IllegalStateException
Next Topic:How to let Quick Outline differ from Outline?
Current Time: Fri May 02 06:57:14 EDT 2025
Powered by FUDForum. Page generated in 0.06524 seconds
